Results 1 to 4 of 4
    Jan 2017
    25mm upgrade on AR5
    Just ordered a 2016 AR5. Forgot to ask the bike shop if I could change out the 23mm wheels/tires for 25mm. Seems like there might be clearance issues from some other related posts I've read.....
    Jan 2017
    I'm not up on the latest specs but my friend fitted 28mm Vittoria Open Pave's to his 2013 AR5 with no problems.
    Jul 2014
    Should be no problem unless the wheel tire combo runs extremely wide, like 29+ mm mounted. I've used 25 mm gp4000s2 on Flo 60 carbon rims (18mm internal width) and Pacenti sl23v2 rims (20.3mm internal width) with no issues on my 2016 AR1. The tires measure between 27 and 28 mm mounted and inflated on those rims.
    Jan 2017
    Thanks!
  1. 23mm tire on 25mm mm rim or 25mm tires on 20.5 rims - questions
    By littlepitboy in forum Wheels and Tires
    Last Post: 01-09-2017, 05:37 AM
  2. hongfu fm069 + 25mm wide carbon wheels + 25mm gp4000s?
    By hernluis in forum Bikes, Frames and Forks
    Last Post: 05-05-2015, 10:23 AM
  3. Upgrade, upgrade, upgrade... but when to consider the frame and fork?
    By OldZaskar in forum Bikes, Frames and Forks
    Last Post: 08-14-2014, 06:37 PM
  4. Can EPS fit 25mm tire?
    By CCRoadRider in forum Colnago
    Last Post: 11-12-2010, 08:50 AM
  5. Wheel upgrade or Bikes Direct/Frame upgrade
    By flat ark in forum Bikes, Frames and Forks
    Last Post: 04-07-2007, 12:05 PM
