good thread - I've started a couple of threads with questions (and received helpful answers) but this centralized thread should be the place from here on
Is there a way to get the accessories and clothing delivered to the UK either through my company or by private sale.
I would love these bottles and cages to match my lovely Felt bike.
Best regards
I assume you mean via the US website? Since we are the US distributor, we are only able to ship product to US addresses. In order to get P/A in the UK you would need to order via our UK distributor. Here is their contact info:
Saddleback Ltd.
Unit 10,
Easter Court,
Woodward Avenue,
Yate,
Bristol, BS37 5YS
UK
If run externally, you will need Shim part number 7970-Di2, front wiring harness, and I would get the large size rear harness for a 58cm frame. EW-7970L
For internal routing, choose rear harness IEW7975. This is the better option, as the FC is internal compatible for 2012
Wow. This is great. I want to get a 3 speed Claire type cruiser for my 9 year-old daughter, but here's the catch. I want a plain unpainted bike.....like the Felt Cruiser Frame is offered.
My daughter is an aspiring artist and she would love to paint her own design on the bike.
Any chance I can order a bike in the raw....or do I need to get a bike and have it stripped?
Thanks! BTW....my new DA3 is at the shop being built as we speak and I'm going into get fit first thing tomorrow AM. My first Felt!!!
Currently the only unpainted option we have available is the Canvas Cruiser, so that would be your best option. Please be aware that stripping and repainting the Claire, or any of our painted bikes, will void the manufacturer's warranty.
Thanks wpcouch! I had a feeling that would be the case. I think the style/geometry of the Claire is much better suited for a 9 year-old girl, so I think I'll get her the Claire and if she wants to paint it....then I'll go from from there. I feel much more comfortable voiding the warranty on the Claire than on my DA3!
However....I also plan to get a Canvas Cruiser for me and I can just let her paint my bike if she wants!
I have a 2011 F4 with the standard double gearing (53/39) crankset. Two questions:-
1. Can I simply change the rings on the crankset to 50/34 (compact gearing), or do I need to buy a new crakset?, and,
2. If I make that change will I need to modify chain length or use different rear derailleur?
Damian,
Thank you for your business, the F4 is a great machine, a workhorse in the F-series line. The standard 53/39t crankset uses a 130mm bolt circle diameter (B.C.D.) This size only allows for chainrings down to 38t, any smaller and the attachement bolts will interfere with the chain/ring interface. If you want to swap to compact gearing you'll need at least, the drive side crank arm and chainrings. You don't need a complete new crankset with bottom bracket and the left crank arm although it may be difficult to source just the drive side. The "compact" on the 50/34t crankset refers not just to the smaller rings but also the B.C.D. which is 110mm on the Shimano Ultegra cranks.
If the only change you make is to go to 50-34t then you'll also want to shorten the chain.
One option you might consider is a new cassette. The stock 11-25t cassette could be changed to a 12-28t or 11-28t and Shimano recently introduced a 12-30t option as well. Techically speaking the 30t exceeds the current "28t max" cog size on the Ultegra RD but it remains within the published capacity. It might be worth a try at your locall Felt Dealer to verify the function with a 12-30t cassette. That would be the most affordable alternative to get a lower gear range.
One change you'll see on Felt's 2012 models is the use of "performance compact" gearing with more models using the 52/36t chainring size on compact 110mm BCD. This has proven more versatile for many of our consumers. This option will be found on many 2012 Felt models and you'll see it being used from more brands in the industry in 2013.
Question: I am planning to purchase a Felt F75 within the U.S. What colors are available for this model? Ive seen matte black & gloss white, Black & dark blue, lighter blue & white... Also the model posted on the website is that a 2011 or 2012? thanks
If you are buying in the USA you'll get the F75 with the 2-tone paint job using Matte Black with Gloss White along the top tube. It is pictured here on our 2012 website.
The F65x (and all SRAM 'Cross cranks) used 130mm B.C.D. Now (2013 model year) we've been able to get them to make 46t x 36t 110mm BCD rings + BB30 cranks. F65x now uses this custom crankset exclusively created for Felt.
-SD
I am looking at a used Felt F75. It looks to be in excellent condition. The color scheme is the matte black, white lettering and yellow trim. I know colors vary from year to year. He says it's an '08' but I can't find pics of an '08 to try and confirm the model year. Thanks, Bill
Simon-
Felt's website lists the F65x w/ a S300 BB30, 46/38t. What I find odd is Sram's lack of detail about the S300, no tech info at all and only one pic. And that pic shows a 50/34t 110bcd.
Don't even have the bike yet and I'm already researching upgrades. It's a sickness, I tell ya!
Was looking to upgrade to some DEVOX carbon handlebars after the holidays and I am not seeing to much DEVOX parts at all on there will more be coming soon? Also, how does felt measure handlebars, is it center to center? Thank you!
I'm wondering the same thing. When can we see some Devox parts, or are they no longer? I have the stem and bars, and would love a seatpost option to complete the look.
My LBS told me to bring my new ride (Z4) in for a checkup to tighten things up after 500 miles. Ive got about 700 miles on her and everything is still perfect. Shifting, braking, everything is spot on. I take meticulous care of her between rides so it looks as new as the day I brought her home. So my question is is it really a necessity to go see my LBS already? Ive got free maintenance for the first year so that gives me until next October.
Most LBS's will use 500 miles or 30 days as a general guideline. If you don't feel that your bike needs it yet, there should be no problem in waiting, especially if your LBS provides you with 1 yr free service.
On the other hand, it's FREE service, so it can't hurt. Also, it should be noted that shops will generally check things during a tune-up that you may not notice or feel while riding and/or cleaning your bike.
That said, routine and thorough cleaning is one of, if not the, best preventative measure you can take to keep the bike running smoothly and properly.
There is a shim available without an eccentric that simply reduces the inner I.D. to 28.6mm. Of course you've got the headset spacers below the stem to adjust the bar position also.
Still trying to get a concrete ship date for the F65x cx bike? All my lbs could get was "January".
Anyone?
Bueller?
Related Threads
Road Bike, Cycling Forums
5.4M posts
205K members
Since 1990
