Results 1 to 2 of 2
    Mar 2018
    BR-6810-R Under BB Brake on DA4
    Will BR-6810-R work on a 2012 Felt DA4? I'm really getting tired of frequent adjustments necessary to keep the stock under BB rear brake working.
    Reputation: SilverStar07's Avatar
    May 2011
    I don't know that frame, but from looking at the Felt web site the rear brake on that bike is listed as a linear pull and integrated so I would say no, without actually trying it. I do have the 6810 brakes on my AR mounted in a similar location and their foot print is bigger than what looks like what's on the DA, so there might be some clearance issues. The BR-6810-R are a side pull brake as well and the cable arm sticks out quite a bit, so you might have some problems with the cable routing.
    The stock brakes look to be a proprietary design with their arms being part of the chain-stay, if that is correct you maybe out of luck. Or at least a lot of trial and error may be required. I would look at eecycleworks or TriRig Omega x direct mount options they may have a small enough profile that they may work.
    Sorry I couldn't be more helpful.
    SS-
    My quest for 140.6 and passion for all things cycling https://multisportunleashed.blogspot.com/
    2015 Felt AR3 upgraded to Ultegra 6870 Di2
    2011 Specialized Secteur Elite Apex -Just about how I want it
    2005 Iron Horse MK3 Expert - many years of trail duty and still my go to Mt. Bike.
  1. Shimano Aero Brakes (9010/6810/5710)
    By nemorino in forum Shimano
    Last Post: 03-13-2014, 01:22 PM
  2. high gas prices under Bush = bad, under Obama = good
    By Andy69 in forum Politics Only
    Last Post: 06-26-2012, 10:49 AM
  3. Brake alignment issue with Tektro brake?
    By crestlinefarm in forum Components, Wrenching
    Last Post: 04-14-2006, 03:04 PM
  4. Zero gravity brake or Ax ligntness carbon brake
    By Tony Shih in forum Components, Wrenching
    Last Post: 09-14-2005, 08:48 AM
  5. Replies: 2
    Last Post: 04-14-2005, 08:54 PM
