Results 1 to 2 of 2
    Jan 2012
    Felt FC frame from Di2 back to mechanical
    I have a Felt FC frame that was used with Di2 I want to go back to mechanical I have the cable stops but my question is at the bottom of the bb shell there is a hole now that was used for the Di2 and now I can't bolt the cable guides that go in the bottom of the bracket since the home took out the shreds for the bolt. I was thinking I could just use a little bit of silicone to hold the cable guide in place. Any help would be appreciated.
    Reputation: sandiegosteve's Avatar
    Mar 2004
    You might need the small parts kit. I have an FC with mechanical, had to add an inline cable adjust for FD too. The bottom cable guide piece might be snap in, I don't remember. I do know the cable for the FD threads through the frame a little.
    Rodie wobbling along after 2 knee surgeries and 1 back surgery.
    Felt FC
    Litspeed Ghisallo
    Key Largo Beach Cruiser
    www.sandiegosteve.info
  1. Converting a Di2 only frame to mechanical
    By Soundtallica in forum Bikes, Frames and Forks
    Last Post: 10-08-2015, 04:52 PM
  2. Switching back from electrical Di2 to mechanical. Unheard of?
    By FutureTriathlonKiller in forum General Cycling Discussion
    Last Post: 03-04-2015, 02:55 PM
  3. 2014 AR2 Frame-Mechanical Compatible?
    By woodys737 in forum Felt
    Last Post: 11-01-2014, 04:58 AM
  4. DI2 Back to Mechanical
    By Bevo in forum Components, Wrenching
    Last Post: 02-15-2014, 07:13 AM
  5. Felt DA1-Can you run mechanical???
    By RobbMaxx in forum General Cycling Discussion
    Last Post: 11-30-2012, 04:16 PM
