Results 1 to 3 of 3
    Reputation: Lou3000's Avatar
    Aug 2010
    Felt Hubs (2011 F5 - CXP22 Wheelset)
    I've been running the stock wheelset on the F5, and though I have a "race" wheelset on the way, I had planned on keeping this as my heavy trainer. However, I keep having the rear hub loosen (excuse my complete lack of technical knowledge in this area, my expertise doesn't extend past contact points and drivetrain). A good bit of wobble has developed and gets so bad that the hub rattles back and forth and the rim contacts the brakes. The wheelset isn't out of true (I know what that is). It is clearly the hub. My Felt LBS has had the wheel once, and tightened it, but that only lasted about 2 rides.
    Its gotten some pretty heavy mileage this year, but it shouldn't be wobbling this soon. Anyone else had problems with these hubs? Any suggestions? Or should I just ditch this entry level wheelset?
    "I'm a real athlete, I'm not trying to be the best at exercising." - Kenny Powers
    Reputation: Dray3573's Avatar
    Jun 2010
    If it's not worth the hassle of a warranty type repair, then maybe try and find a decent hub for a good price that will last longer and just rebuild the wheel with the new hub. That might be more cost effective than ditching the entire wheel set for a new trainer set. Lace up that rear wheel with a entry level power tap...
    Nov 2009
    Probably have the shop tighten them again and put a little loctite on the threads.
  1. Felt Z85 2011 or Giant TCR 2 2011
    By kamrankhan in forum Beginner's Corner
    Last Post: 03-23-2012, 09:42 AM
  2. Felt F4 2010 or Felt F5 2011?
    By Pete bike in forum Felt
    Last Post: 02-04-2012, 06:42 AM
  3. 2011 Felt Z2
    By AnthonyL88 in forum Felt
    Last Post: 08-26-2011, 10:59 AM
  4. I want a 2nd wheelset - Aksium vs Open Pro vs CXP22
    By pedalpedalpedal in forum Cyclocross
    Last Post: 01-24-2010, 07:39 AM
  5. Just Received: BWW Mavic CXP22 SS/FG Wheelset
    By zriggle in forum Wheels and Tires
    Last Post: 01-02-2010, 06:18 PM
