Results 1 to 7 of 7
    Jun 2005
    Ongoing Bottom Bracket Frustration 2015 F2
    Hi all,
    Yet again my FSA BB30 w/ 24mm spindle reducers is making noise and it's driving me crazy, mostly that this is an annual problem. I found a thread I started about two years ago, and did a search, but don't see a solution to this concern. I want a bottom bracket that isn't a pain in the butt. The Praxis conversion kit two years ago wasn't compatible with the F2 BB shell. Anyone know of anything new in the past couple of years?
    Thanks,
    Bradley
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    You're S.O.L.
    I think you have a 2014, not a 2015? I don't know of any other manufacturer doing what felt has. (It's actually a good idea over using retaining rings) But creates a compatibility problem. No one is going to come up with a BB adapter for just a few frames that are now 4-5 years past.
    Your options are:
    Remove and grease your BB regularly.
    Get a new crank with a 30mm spindle.
    https://praxiscycles.com/wp-content/...RAME-GUIDE.pdf
    FELT F1, F2, AND Z1 - 2011-2014 versions of these frames used Feltís custom Carbon BB30 with a non-removable carbon sleeve/lip. Also ďFRDĒ versions (see photo) This custom shell prevents installation of the Praxis Conversion BB.
    2015 F1, F2, AND Z1 models of these frames now use regular
    aluminum BB30 and are good for installation.
    Jun 2005
    It's a 2015, but if memory serves me right, basically the same as the 2014. Otherwise, I fear you are right about my options. I emailed Praxis to ask if they had anything that would work.
    Bradley
    Reputation: FeltF75rider's Avatar
    Feb 2012
    I had the issue you are having but only once. Itís been flawless since. I do keep it clean and pull it apart maybe twice a year and re grease it. I donít find it that big an inconvenience and most likely would do this with any bike.
    Jun 2005
    Thanks. Sadly, I drove over the bike last week in my garage. It was a 2014 as tlg thought, not 2015. Looking at crash replacement with an FR1, but it ain't cheap.
    Bradley
    Feb 2005
    Sorry about to hear about your bike, but I'm posting in case this is helpful to others.
    Based on this post from a few years ago I purchased a KCNC bottom bracket adapter for my Felt which also has the inner carbon shell and came stock with BB30 bearings and spindle reducers.
    BB30 bottom bracket solution For Felt F1
    It installed easily and so far it's been working great.
    Jun 2005
    And it just might be the thing if the FR1 (shipped Friday!) has the same concern. Thanks.
    Bradley
  1. Replies: 33
    Last Post: 11-05-2016, 10:40 AM
  2. 2015 Z1 Bottom Bracket question
    By jemsurvey in forum Felt
    Last Post: 01-22-2015, 03:00 AM
  3. Bike purchase - ongoing internal saga
    By FxdGearHeadNYC in forum Bikes, Frames and Forks
    Last Post: 05-15-2007, 09:30 AM
  4. The ongoing success story that is NCLB...
    By Marc in forum Politics Only
    Last Post: 08-19-2005, 10:04 AM
  5. ongoing search problem
    By tomletsinger in forum SiteFeedback/Issues
    Last Post: 07-22-2005, 11:47 AM
