Results 1 to 3 of 3
    Oct 2015
    Rivet failure on a Z6 Frame
    Unfortunately the rivets that attaches front derailleur mounting bracket to the frame got too loose, that my front shifting no longer works. The applied cable tension to move the derailleur cage is pulling the derailleur all together. I contacted to the Felt distributor here in Turkey and they seemed interested in resolving the issue. They had contacted Felt with the photos and videos of the issue I had provided them. But for about a month, they are still waiting for Felt to respond.
    Hopefully someone from Felt will see this? I've already tried the "Ask Felt" topic months ago, but noone replied. My bike's warranty is almost over, so I am in a bit hurry.
    May 2014
    Hi, I don't know for sure but it seems that no one from Felt checks on this forum any more. If your distribution comes from Felt in Germany (I think it probably does), it might be worth emailing them directly, mentioning that you have gone through your local distributor. That way, there can't be any doubt that this happened within your warranty period.
    Good luck.
    Oct 2015
    Yes, you are right! Our distribution should be via Felt, Germany. It might be a good idea to email them directly. Thanks!
  1. Trek not liable for failure to warn of carbon fiber failure
    By RichardT in forum General Cycling Discussion
    Last Post: 03-21-2015, 05:56 PM
  2. Broken rivet in cable guide on aluminum frame - how to fix?
    By armstrong in forum Components, Wrenching
    Last Post: 03-14-2014, 01:40 PM
  3. Frackin Hard Drives. . .Failure on Failure
    By Ridgetop in forum The Lounge
    Last Post: 05-21-2010, 09:46 AM
  4. Bianchi Axis or Novara Rivet
    By beungood in forum Bikes, Frames and Forks
    Last Post: 10-21-2004, 01:14 PM
  5. Source for Campy shift lever rivet?
    By bimini in forum Components, Wrenching
    Last Post: 10-20-2004, 06:22 AM
