Results 1 to 5 of 5
    Feb 2009
    Should I get the '09 or the '10 F-3SL
    I don't know which bike I should get. I can the the 09 for under 3k in a couple of days or I can get the '10 in a couple of weeks for 3.5k. Which one should I get? Is there that much difference between the model years.
    kytyree
    Guest
    Can't the shop clarify this for you?
    And unless the specs were different enough or one color suited you a lot better I would keep in mind that after you've bought it and ridden it they'll probably be worth within $100 of each other if the spec is similar.
    Felt Bicycles
    May 2009
    Quote Originally Posted by absolutsooner
    F3 for 2010 gets an upgraded frame, new improved custom color Fulcrum Racing wheelset and lighter Bar/Stem.
    The bike is better bike in 2010 for sure, lighter frame, lighter wheels, etc. but saving $500 is significant as the drivetrain remains basically unchanged for SRAM and their RED group in '10.
    You most likely won't be able to tell the difference in a parking lot test ride.
    -SD
    Mar 2006
    Quote Originally Posted by SuperdaveFelt
    -SD
    +1. The frame and wheels seem to make it worth the extra $500 but you should ride both (on a good 10-15 minute ride) and judge for yourself.
    Jan 2009
    While on the subject of the F series, why no 2010 F2?
