Results 1 to 5 of 5
    Mar 2012
    Spacer Under Stem
    Do I have to have a spacer between my stem and headset cap on a 2016 Z85?
    Thanks
    Forever a Student
    Mar 2014
    No.
    The "headset cap" or "conical spacer" or "bearing cover" is needed to protect the bearing from dirt and water and sweat and such.
    The stem can sit directly on top of it in almost all cases.
    There should be nothing above the stem besides the top cap for the compression plug. In some cases a 5mm spacer above the stem is used, but that's the max allowed unless you're using a special compression plug.
    use a torque wrench
    Mar 2012
    Thanks. That's what I figured but wanted to be sure.
    3T Cycling
    May 2009
    Quote Originally Posted by felton View Post
    Thanks
    If you are using the stock VA stem you only need the shim that fits into the stem clamp.
    You're free to #slamthatstem otherwise.
    -SD
    Mar 2012
    Thanks Superdave. On a side note, what a great bike. The Z85 is by far the best bike I have ever ridden!
  1. Spacer between "Cone spacer" and stem.
    By jhowmah in forum Beginner's Corner
    Last Post: 09-23-2013, 10:43 PM
  2. spacer above stem????
    By jermsmith in forum Specialized
    Last Post: 09-19-2011, 01:03 PM
  3. Spacer above the stem necessary?
    By 32and3cross in forum Components, Wrenching
    Last Post: 06-10-2011, 05:51 PM
  4. Spacer above stem.
    By danielc in forum Components, Wrenching
    Last Post: 04-27-2010, 09:17 AM
  5. Spacer for ITM stem
    By pdsrms in forum Components, Wrenching
    Last Post: 06-22-2007, 03:48 AM
