Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
  1. #26
    Jul 2014
    Hi spdntrixi!
    Did you buy the eecyclworks brake? How is it working? Could you give a quick review? I have trouble changing rear wheels on my Felt AR2 because the Tektro 750 brake-arm (or bridge between the brakes?) does not give me enough clearance to pull the wheel out without the wheel getting caught on it. Does the eecycleworks brake have a better "reach" - That is, do the eecyclworks brake arms have a little more depth that makes changing the rear wheel easier?
    Thanks
  2. #27
    3T Cycling
    May 2009
    Quote Originally Posted by joeiphd View Post
    Hi spdntrixi!
    Thanks
    On paper the ee brake has 2.8mm more clearance at the top but that all depends on the rim width and tire size you are using. I've got a 27mm tire on my AR1 that still contacts the ee brake when I try to remove the tire, but I've just become accustomed to knocking it out forcibly.
    A 23mm tire would have clearance I'd wager.
    -SD
  3. #28
    Jul 2014
    Thank You SD!
    I use 23 mm Continental Grand Prix 4000 S II tires on the 3T Accelero 40 Team wheels (that came with my AR2) and on my HED Jet 6 wheels. Both wheels are 23 mm wide. Changing wheels requires a bit of nudging. The extra 2.8 mm would reduce or eliminate this nudging.
    Again, Thank You for the information - very helpful!
    Joe
  4. #29
    Aug 2011
    Quote Originally Posted by SuperdaveFelt View Post
    There are many more brake in development that will also work which should hit the market shortly before/after Eurobike and Interbike.
    Dave - can you point to these?
    thanks
  5. #30
    3T Cycling
    May 2009
    Quote Originally Posted by dbf73 View Post
    thanks
    No, I'm afraid I cannot until the manufacturer authorizes the OEM to do so.
    SD
  6. #31
    Reputation: TehYoyo's Avatar
    Sep 2012
    Thank goodness for the Garmin Vector S. I get 20% off through my team, which is a perfect option to fix this annoying problem and get a power meter that is actually more versatile than a Stages.
    Zach
  7. #32
    Aug 2011
    Any one know if the new 4iii power meter will clear? It appears to mount closer to the bottom bracket and not extend as far radially as the Stages
  8. #33
    3T Cycling
    May 2009
    Yes, it will fit the frame.
    No, it will not clear the Shimano brake.
    SD
  9. #34
    bkw
    bkw is offline
    Pedal Faster!
    Aug 2014
    Anyone know if the TRP T922 or T925 will work on the bike and with the Stages power meter? Are there any other brakes out there besides the Tektro and EE that'll work?
  10. #35
    Aug 2011
    SD
    Dave - any update on available alternative brake solutions?
  11. #36
    Jan 2015
    any updates? Looking to get a stages for my fsa 386 and am curious on options!
  12. #37
    3T Cycling
    May 2009
    Quote Originally Posted by tickyboy View Post
    Yes, there are several new options from TRP and Tektro as well as the FSA Direct mount aero brake that will fit the direct mount chainstay position and stages and Pioneer left-side inboard Powermeters.
    -Dave
  1. 2011-up brake pad compatibility
    By tom_h in forum Campagnolo
    Last Post: 04-12-2014, 09:00 AM
  2. Why is it front brake is stronger than rear brake?
    By nolight in forum General Cycling Discussion
    Last Post: 01-08-2013, 07:50 PM
  3. Brake compatibility
    By deviousalex in forum Components, Wrenching
    Last Post: 08-18-2010, 07:27 PM
  4. 9 Speed STI/Brake Compatibility
    By tomato in forum Shimano
    Last Post: 03-24-2010, 03:04 AM
  5. Brake cable compatibility
    By orange_julius in forum Campagnolo
    Last Post: 03-21-2007, 07:55 AM
