Results 1 to 4 of 4
    Nov 2005
    TK1 replacement drop out screws
    I drove home Sunday from Masters track nationals (9 hours drive, 8 in the rain) and just discovered one of the dropout screws has fallen out while the bike was on top of my car. Does anybody know how to get them or a part number to order them? Super Dave? Thanks for any help!
    3T Cycling
    May 2009
    Quote Originally Posted by wkwong View Post
    You can get the set screws from McMaster-Carr I'm pretty sure they are M4 x 0.7mm. The length required is really dependent on your gear selection.
    If you strike out finding some online, shoot me an email.
    I resigned from Felt after wrapping up the 2017 model year development in February but I've got a few of the track frames and can send you a set screw.
    Hope you weren't rained out at track natz.
    -SD
    Nov 2005
    Dave, thanks a million! I found them on MC. I'll get the Stainless version since the OEM ones I had were starting to get a little rusty.
    Unfortunately my main events (200m & TS) got rained out completely. Frustrating but there's nothing you can do about it. Tom Mahoney & crew did a great job of trying to make it work. I appreciated that.
    Best of luck on your next endeavor. You're a fountain of knowledge and I'm sure it'll be a good place.
    3T Cycling
    May 2009
    Be careful with stainless, it's a bit softer. Don't try to get away with using a ball-end hex key.
    bummer about the weather, you coming out here for Worlds next year? It'll be 74 degrees and bone dry inside Hope to catch you at the track if you do although I certainly won't be contesting any sprint events.
    I landed at 3T and will be working on the next generation of products there with Gerard Vroomen. Pretty excited to have such an incredible resource. The first new item was our adjustable Apto stem, then Discus Plus 650B road wheels, most recently we introduced the worlds first high performance multi-surface bike.
    Cheers,
    SD
  1. Campy replacement Hi/Lo screws
    By BirdLikeClimber in forum Components, Wrenching
    Last Post: 03-17-2014, 08:23 AM
  2. Where 2 get replacement derailleur adjust screws?
    By samh in forum Components, Wrenching
    Last Post: 09-22-2009, 07:07 AM
  3. Shimano replacement limit screws
    By eodusa in forum Components, Wrenching
    Last Post: 01-16-2008, 06:36 AM
  4. Rear drop out adjustment screws
    By gizzard in forum Components, Wrenching
    Last Post: 01-02-2007, 07:54 PM
  5. Replacement Cleat Mounting Screws
    By S2H in forum Components, Wrenching
    Last Post: 11-05-2005, 03:24 PM
