Page 7 of 7 FirstFirst ... 567
Results 151 to 164 of 164
Thread: VR Series
  1. #151
    Reputation: rochrunner's Avatar
    Jul 2006
    In the "here we go again" department, I'm thinking of looking for a different seat for my VR5. I actually changed out the seat before I even took delivery of the bike, so I do have the OEM seat in a box along with a couple of other seats from years past. Any comments on the OEM seat? I might just try a couple of the seats that I have since I no longer remember where they came from or why they're laying around in my workshop. But I think that my physique and riding style have changed a lot over the years and something else might work better for me now.
    On a negative note, the dealer where I bought my bike is going out of business. Really unfortunate since they were the only Felt dealer around and were one of the very few shops in this area that promoted road bikes (this is mostly a MTB/Trail/Hybrid area). They specialized in triathlon bikes and gear, so maybe that ended up not working out so well.
  2. #152
    T.R., conservationist
    Reputation: jerman's Avatar
    Jan 2005
    Anyone have a problem with chain-drop in the front jamming between the crank assembly and the frame?
    My wife's VR5W did this and the bottom bracket had to be loosened to free the chain. It was impossible to remove the chain by hand, stranded on the ride.
    I emailed Felt and was told to adjust the fr derr and, from the pics I sent the customer service guy, he said it looked OK to him.
    The frame was gouged from the pretzel-twisted chain that had jammed.. jammed so tight it was impossible to remove without loosening the BB.
    This happened about 8 mos ago and I had the derr adjusted then the bike didn't get ridden. Now with the dtr's wedding over my wife's taken her bike out and the second ride out the exact thing happened again, we were stranded and had to be sagged in.
    Here's Felt's email reply from last Sept...
    'Frame scratch From the photo the frame does not look permanently damaged. My suggestion is when you take it to the shop to make sure the front derr. is adjusted correctly, have them take a look in person to access it. From the photos it looks OK to me.
    I hope this helps.
    Thanks,
    Alan Foster - Felt Bicycles
    Consumer Relations'
    He said 'the frame DOES NOT LOOK PERMANENTLY DAMAGED.' Trust me, the frame is permanently marred. I have owned 6 other brands of bikes: Trek, Look, Merlin, Serrotta, Orbea and GT. None have ever exhibited a problem like this when a front chain was dropped. I did have a problem with my Look frame and they upgraded me to their better frame for cost and gave me all kinds of Look swag. When Alan stated he 'didn't feel the frame was damaged' and then that's-that, I don't feel Felt addressed this situation adequately. This is just a side-note on the customer service you can expect from Felt.
    I took the bike back in and had a chain catcher installed on the derr. Just a word of warning about the chain-drop and my experience with Felt's CS...
  3. #153
    Feb 2017
    Quote Originally Posted by rochrunner View Post
    In the "here we go again" department, I'm thinking of looking for a different seat for my VR5. I actually changed out the seat before I even took delivery of the bike, so I do have the OEM seat in a box along with a couple of other seats from years past. Any comments on the OEM seat? ...
    With my OEM saddle I was also not satisfied. Tried it on the Felt and even on my MTB. Was ok, but not good and is now in a box with all the other saddles.
    Good look finding the right seat,
  4. #154
    Feb 2017
    Quote Originally Posted by jerman View Post
    Anyone have a problem with chain-drop in the front jamming between the crank assembly and the frame?...
    I had that Problem.
    Also had to remove the drive side of the crank to get the chain out.
    I don't know the root cause exactly, but I think it was a mixture of
    - wrong shifting
    - chainrings (FSA)
    - front derailleur adjustment.
    Since I adjusted the front derailure and changed the shifting I didn't had the problem anymore. Also change the chainrings and chain when worn out.
    Additionally I used MarshGuard slapper tape to protect the frame. It also narrows the gap, that the chain will not fit anymore between the chainring and the frame, like a chainguard.
  5. #155
    Jan 2005
    The problem is not the chain dropping, it's that the chain jams fully when dropped that the only way to free it is pull the crank. You are stranded.
    No tape, but I noted in my original post I had a chain catcher installed after this second.. we will see.
  6. #156
    Jul 2006
    Sorry to hear about this, and now I'm getting paranoid about it so might look into the chain catcher and/or tape. One thing I'm glad of is that I swapped out my crank assembly last year (for a FSA 46/30) and the work was done by a TdF-level mechanic at the shop where I bought it. No shifting problems whatsoever since then (although, given where I ride, the bike stays on the big ring almost all the time).
  7. #157
    Feb 2017
    Ok, I got it. You are not looking for a solution, you just wanna blame someone.
  8. #158
    Feb 2017
    Sorry to hear about this, and now I'm getting paranoid about it so might look into the chain catcher and/or tape. ....
    Don't be paranoid.
    If you don't have shifting problem, the chain will not drop. And if the chain is not dropping, it will not jam.
    If your chain drops, it is just important immediately to stop pedaling. It only jams if you keep on pedaling. And if it jams to have the right tool with you to remove the crank.
    When I jammed my chain, it was in a group ride and it was my fault, that I continued pedaling. But with my multi tool I could losen the crank and free the chain in minutes.
    To prevent that happen again and protect my frame, I closed the gap between frame and inner chainring, so the chain can not jam anymore.
    But like I said before, the root cause was a bad adjusted front derailleur. And since I fixed that, the chain never dropped again.
  9. #159
    Jan 2005
    Quote Originally Posted by Tobsn View Post
    What part of my response was assigning blame? Honestly, I did it as a warning. If the chain-catcher that was installed fails then the more severe measure of replacing components will be done, then replacing the bike. This is unacceptable.
    But since you mentioned blame, I believe Felt's design department deserves quite a bit. Chain drop is not 100% preventable. I just saw occurrences at the TdF, and it's happened on my other five brands of bikes I've owned. I go to the best mechanics within a reasonable driving distance, within an hour. These are well respected people in the Dallas-Fort Worth Metroplex... Fort Worth Cycling and Jason, Hilltop Bicycle with Jeff, to name a couple.
    In addition, I do not feel Felt's CS met the level I have experienced with other brands of bikes I've owned. That is an important factor to me when making a significant purchase like this. Unfortunately, I have to say I'm underwhelmed and, in hind-sight, I would have bought another brand.
    Bottom line, loosening the bottom bracket with a multi-tool when you are on a group ride 15 miles out of town, making them stop and wait, is not a reasonable option. I've ridden a lot in the last 15 years and never once experienced anyone doing anything to the bottom bracket other than tighten it.. once.. maybe.
    This is a design flaw that others need to be warned about so precautions, like adding a chain-catcher, may be taken. Blaming does no good Tobsn, I'm just offering a friendly warning.
  10. #160
    Menace
    Reputation: Harley-Dale's Avatar
    Sep 2011
    FWIW, I put a K-Edge chain keeper on all my bikes, just in case. Even with meticulous DI2 dial-in and precise chain line adjustment I have had very occasional chain drop up front. I know what you mean by chain getting stuck--the first time it happened on my AR2 I tore off the metal stay protector just to get the chain unstuck miles from home.
    The K-Edge works very well, and I will caution you to check the adjustment of them occasionally, as they will drift with vibration/use. But, I only had one chain drop in all the years of using one--hence my advise to ensure its properly adjusted now and then.
    https://k-edge.com/product-category/chain-catchers/
    2017 Felt IA16 - DI2 Ultegra
    2016 Felt FRD F1X - DI2 XTR
    2015 Felt Rail 29 Cruiser
  11. #161
    Jul 2006
    Looking at the latest VR models, I noticed one subtle change. When I got my first-year VR5, most of the VR series (Shimano-based models) had 46/30 chainrings (the VR5 had 48/32, which I later changed out for the 46/30 setup). Now I see that they all are coming with 48/32s. Not much difference, but maybe the 46/30 combo was just a bit too low for some people.
  12. #162
    Jul 2006
    Anyone know what the practical max width tire is that will fit the VR5? I've got 700x32s now but am thinking about a second set of "gravel grinding" wheels with more aggressive tires. What might fit?
    Sent from my BTV-W09 using Tapatalk
  13. #163
    Jan 2005
    roch.. how much room do you show left with your 32's mounted? I just put Gatorskin Hardshell 32's on my VR4 and still looks like room. I thought I had read online about wider tires used so looked and I just found this on Bike Forums... 'A recent reviewer says he installed 35mm Schwalbe-G-Ones.'
  14. #164
    Jan 2005
    Happy to announce the chain-catcher installed on wife's VRW5 has worked flawlessly, she's had no further problems.
    I have been so encouraged by this I am committing to my VR4, so switching out the single front to SRAM eTap and making it a double. Going with a compact 50/34 in the front and 11x32 in the rear as pretty flat around here.
  1. Replies: 13
    Last Post: 01-10-2016, 04:34 PM
  2. Replies: 13
    Last Post: 07-12-2012, 05:52 PM
  3. 2011 Trek Madone 5 series vs 6 series comparison (weight)??
    By kiwidj in forum Bikes, Frames and Forks
    Last Post: 09-25-2011, 08:14 PM
  4. Replies: 5
    Last Post: 07-23-2011, 08:48 PM
  5. 6000 series al vs. 7000 series al frames
    By team_sheepshead in forum General Cycling Discussion
    Last Post: 11-24-2004, 10:35 AM
