Results 1 to 5 of 5
    Aug 2013
    What 12-28T cassette is on a 2013 Felt Z2
    Greetings,
    I won't be home for a little more than a week. I'm in need of 12-28 cassette. I'm having a tough time finding a 12-28 cassette. I wanted know the model and make
    Thanks for any help.
    Forever a Student
    Mar 2014
    Just buy a Shimano Ultegra 6700 11-28 cassette, yours has a 12-28 by Shimano but I'm not sure which level, doesn't matter though.
    And yes, it will fit perfectly.
    use a torque wrench
    Aug 2013
    I assume no new chain or adjustments to the Di2 anything else either moving from the 12-28 to the 11-28?
    From what I read a few times is that gearing could be too close on the 11-28?
    Also I've read that the 11-28 can give faster speeds in the flats?
    Do I loose much on hills with the 11-28?
    Reputation: rochrunner's Avatar
    Jul 2006
    Quote Originally Posted by knezz View Post
    Not sure what someone would mean by "too close."
    The 28-tooth gear is what you will use when climbing, so you will lose nothing on the hills. The 11-tooth will be the "top speed" gear and is technically faster than the 12-tooth, but you have to be a pretty good rider to be able to spin out in the highest gear!
    The chain length should be OK unless they sized it in an unusual way. Make sure to try the 11-tooth sprocket with the smaller chain ring and see if it shifts into and out of that gear without any interference.
    Cranky Old Bastard
    Reputation: Randy99CL's Avatar
    Mar 2013
    A couple of years ago the only 10-speed 12-28 cassette I could find was a Tiagra.
    Shimano Tiagra CS-4600 10-Speed Cassette
    "When you know absolutely nothing, anyone who knows 1% more than nothing sounds like an expert."
  1. Replies: 8
    Last Post: 01-10-2015, 05:30 AM
  2. Felt 2013 z85
    By lin013190 in forum Felt
    Last Post: 05-02-2014, 11:58 PM
  3. Felt f1 2013
    By petercaro in forum Felt
    Last Post: 09-27-2013, 01:50 PM
  4. Replies: 3
    Last Post: 07-18-2013, 03:44 PM
  5. UK 2013 Felt Z6
    By davegregoire in forum Felt
    Last Post: 02-28-2013, 09:03 AM
