Results 1 to 18 of 18
    May 2006
    Chain Keeper/Guard for fixed gear cog?
    Some of my fixed gear road riding buddies over the last few years have experienced a nasty rear wheel lock up after their chain jumped off the rear cog and jammed in-between the hub flange and fixed gear cog. Lately I've seen 2 guys crash after their chains jumped and locked up the rear wheel. This weekend it happen to a buddy on a bumpy and steep down hill at 38-39 mph, he fish tailed for 50-60 yards before dumping it . During super high cadence (175-200+) the chain can exhibit some weird gyrations that can cause it to jump off the cog....even with proper tension and alignment , but a dual-sided cog guard should eliminate this.
    Does any one make a chain keeper/guard for a fixed gear cog? I've seen some of the belt drive SS CX/MTB bikes using them but those are wimpy SS bikes.
    A local machinist might have a solution.
    Not a rocket surgeon.
    Reputation: tihsepa's Avatar
    Nov 2008
    How could a good chain jump off a good cog?
    If there was a need for something to prevent it someone would make it.
    There isnt so they dont.
    Me thinks we have a set up problem here.
    No Crybabies
    Reputation: Fixed's Avatar
    May 2005
    should not need it
    With correct chain tension, this should never happen. A chain tensioner, or chain tug, helps. It will maintain tension, even if the axle nuts loosen a little. I've done a whole lot of fixed gear riding in just about every road condition, and never had a chain jump. Did break a cog once, but that's something else.
    [SIGPIC][/SIGPIC]
    When my fist clenches, crack it open
    Before I use it and lose my cool
    When I smile, tell me some bad news
    Before I laugh and act like a fool
    Reputation: PdxMark's Avatar
    Quote Originally Posted by tihsepa
    Chain tensioner is one possible solution. A slip of the rear hub in the dropout loosens the chain tension and allows the chain to come off the cog. A chain tensioner prevents the slippage, and hence the dropped chain.
    Old and Fixed, Moderator
    Jan 2002
    Quote Originally Posted by PdxMark
    What he said.....a good chain tensioner....
    Dave Hickey/ Fort Worth
    May 2006
    Isn't fixed gear back-pedal pressure an issue with chain tensioners?
    Jan 2002
    Quote Originally Posted by OffRoadRoadie
    wrong type of tensioner...
    They need this
    May 2006
    Most of us are riding top-end steel bike from the 80's and 90's (mine is a 89 Serotta Nova Special SLX frame with horizontal drop outs). I'm running a 42x16 and a White Industries Eno Flip Flop hub, others are using a track hub with axle nuts, but a few are running re-dished free-wheel wheels with QR. The last jammed chain was on Surly Steamroller with investment cast Surly track dropouts and a single dropout chain tensioner.
    I check my tension before every ride. Some of the rollers we spin down are bumpy, so with a slightly out of round chain ring (DA) and hitting a cadence of 190-209 on these rollers is a concern (gotta keep up with the coasters). I'm sure a few of the jammed chains were cause by poor maintenance (worn cog and chain), loose chain or improper alignment, but seeing a chain's wild gyrations at 190-209 rpms sure makes me want a cog guard.
    May 2006
    Cool. They might slow up a flat tire wheel removal but should hold the chain tension better than a QR or axle nuts.
    May 2006
    Who makes these chain tensioners?
    No Crybabies
    May 2005
    Mks
    http://www.universalcycles.com/shopp...hp?category=55
    I like the MKS. Have several.
    [SIGPIC][/SIGPIC]
    The chain tensioner actually supplements the axel nuts - to keep them from slipping after they've been tightened. The tensioner isn't a substitute for the nuts. Often a tensioner on just the drive side would be enough. The usual/best chain tensioners presuppose track ends, rather than road-style drop outs. I think there are tensioners, of sorts, for road-style drop outs, but I'm not sure which of those works best.
    I'd think QR would be a particularly bad fit for the conditions you describe.
    Nov 2010
    it doesn't matter how top-end your bikes are, for your group to be experiencing such a rash of chain-jumping on fixed gear bikes it must mean you guys are not setting something up properly. & why is the guy on the steamroller with trackends using a tensioner? i know a couple guys that have riden fixed for thousands of miles (& they ride hard & fast)...when i asked them earlier about this they told me it has never happened to either of them.
    anyway, here is different style chain-tug that i am using:
    (edit)
    i may be wrong but i think surly's tuggnuts come with a qr adaptor
    May 2006
    I do suspect improper set-up, and or lack of chain tension/adjustment monitoring for one guy . Worn cog on the Steamroller looks to be the cause there.
    I still think a cog guard would add some security for the type of riding I do and the bumpy roads we use.
    May 2006
    Yup...supplement the axle nuts.
    Nov 2010
    ...The last jammed chain was on Surly Steamroller with investment cast Surly track dropouts and a single dropout chain tensioner...
    ...Worn cog on the Steamroller looks to be the cause...
    i don't mean to beat a dead horse OffRoadRoadie, & i may be arguing semantics, but as you brought up the steamroller again...
    when you mentioned that he uses a chain tensioner, do you mean a chain-tug like the couple pictured above? or what i think is more properly defined as a tensioner, something like this:
    if your buddy is actually running 1 of these on his steamroller & it is fixed gear, not singlespeed...
    it is probably the reason for his accident, make him take it off immediately!
    those tensioners are absolutely not meant for use on fixed bikes, they cannot handle any back-pedal pressure. many of them include a product warning that they are only to be used with ss, never on fg.
    good luck...
    May 2006
    Yes, chain-tug. Pretty sure he is using a Surly Tuggnut Tensioner on the drive-side but I could be wrong (we haven't seen him on the fixer since his chain jam crash).
    Nov 2007
    Quote Originally Posted by markaitch
    good luck...
    Steamrollers don't have derailleur hangers, has to be a tug nut.
