Results 1 to 17 of 17
    Old and Fixed, Moderator
    Jan 2002
    Fixed verticle dropout solution
    I saw this on eBay this morning..... Interesting concept....
    It's not pretty but it would work....$40.00 shipped
    Fixed Gear Fixie RoadToPista track dropout adaptor | eBay
    Attached Thumbnails Attached Thumbnails Fixed verticle dropout solution-roadtopista02web.jpg
    Dave Hickey/ Fort Worth
    Decrepit Member
    Reputation: Scooper's Avatar
    Mar 2007
    I see an added benefit for the track; it gets the BB higher. It also steepens the STA and HTA a little.
    -Stan
    my bikes
    Cumudgitude
    Reputation: UrbanPrimitive's Avatar
    Jun 2009
    I hope there's some knurling on the inside of that second drop. Otherwise I'd be nervous about people not tightening the nut enough and allowing it to rotate under stress, dropping the chain. Could work, but still leaves me a bit nervous.
    Mar 2002
    Quote Originally Posted by UrbanPrimitive View Post
    I agree. Maybe bolt and weld can keep it in place. Maybe.
    Yo no fui.
    Reputation: Pablo's Avatar
    Jul 2004
    Would you have to saw off the hanger if not removeable?
    "It is better to conquer yourself, than to win a thousand battles." -Dhammapada
    "Fact is only what you believe; fact and fiction work as a team." Jack Johnson
    "A true cyclist sometimes has to bite the dust before he can reach the stars. Laurent Fignon
    Cumudgitude
    Jun 2009
    Quote Originally Posted by Pablo View Post
    It looks to me like that's what was done on the bike above. But I also just noticed the axle nut itself. Check the attached washer. That flat side didn't come that way. Not to mention the potential need to re-space your hub. That's a lot of modification and dinking around to get a questionable fix to work.
    *** Just looked at the listing. No knurling or tooth anywhere. The bolts that attach to the frame are normal machine bolts with nylock nuts. Thanks but no thanks. It's an interesting idea but looks to me like the follow through lacked experience and know-how.
    Reputation: turbomatic73's Avatar
    How do you keep the adapter from rotating if the axle isn't centered right in the middle of the dropout?
    corning my own beef
    Reputation: JustTooBig's Avatar
    Aug 2005
    interesting concept, yeah. But also full of issues:
    fugly as h3ll.
    all sorts of problems with rotation -- around the old dropout, in the new horizontal one, etc.
    would necessitate re-spacing the dropouts at least 4-6mm wider
    People who say, "Laughter is the best medicine.." have never been on the receiving end of a morphine drip..
    ноожеяз ай вщоw?
    -VaughnA
    A fool and his money were damned lucky to have bumped into each other in the first place.
    Jan 2002
    Quote Originally Posted by JustTooBig View Post
    fugly as h3ll.
    I don't think respacing is an issue....Assuming the frame is 130mm...the plates look to be about 2mm... that leaves 126mm.....most Formula hubs can easily be spaced to 126..
    The rotating certainly can be an issue ....and it is ugly as hell...
    Trigger Warning
    Reputation: Local Hero's Avatar
    Jul 2010
    On the track? No f-ing way.
    For a jenky fixter? Hell yeah.
    duh...
    Jan 2005
    so to summarize:
    only $40
    not pretty to fugly
    potential for slippage/rotation
    slightly alters geometry- angles and bb
    need removable or broken derailleur hanger
    might need to grind axle nut
    changes spacing (maybe a good thing)
    no effin way on track
    mmm, no thanks...
    Quote Originally Posted by mikagsd
    Fat tire Fred....you are the bike god of the universe and unless someone agrees with your reasoning they are just plain stupid
    Feb 2006
    I've seen a few vertical dropout frames made to work with a half-link. A steel LeMond comes to mind.
    That looks seriously "Mickey Mouse."
    Anyone who believes there are no stupid questions never worked in a bike shop.
    Jan 2002
    Quote Originally Posted by Richard View Post
    If I build a fixed gear with vertical dropouts, I'd try one of these...
    They cost about $25.00
    Attached Thumbnails Attached Thumbnails Fixed verticle dropout solution-chan100861.jpg
    Cumudgitude
    Jun 2009
    Ha! Dave's bling-ing out with the half link chain. I want video of bar spins and unnecessary bunny hops.
    Jan 2002
    Notice I said "IF"........ no bar spins for this guy......
    Jul 2010
    Just saw this today, interesting concept and something i had in my head for the last 20 years (no kidding), there is a way to have those dropouts to dont move no more. Thats the reason they have a tiny hole in there, probably a tiny screw would to the trick.
    Actually those dropouts are 5 mm in thickness. Have a busted frame moving around, this tihng would save me a lot of money because i want a nice track frame since long time ago, even they can be glued or tigged to the road dropouts and then maybe use carbon and wrap it to make it look way better. Hmmm wonder if i can convert my old bmc to track, that bike sprints like crazy monkey.
    No Crybabies
    Reputation: Fixed's Avatar
    May 2005
    ooo
    That looks scary. I think I'd rather find a cheap $100 fixed frame and start with that.
    [SIGPIC][/SIGPIC]
    When my fist clenches, crack it open
    Before I use it and lose my cool
    When I smile, tell me some bad news
    Before I laugh and act like a fool
  1. Pego, Dave, Fixed, et al: Tips for long distance fixed rides?
    By Hollywood in forum Fixed/Single Speed
    Last Post: 12-14-2009, 06:08 PM
  2. Std sliding dropout & hooded sliding dropout
    By lawrence in forum Bikes, Frames and Forks
    Last Post: 04-22-2008, 07:09 AM
  3. Cheap fixed gear contest over at the fixed forum
    By Dave Hickey in forum General Cycling Discussion
    Last Post: 11-01-2006, 07:45 AM
  4. Wheel slips in dropout-solution?
    By jroden in forum Components, Wrenching
    Last Post: 12-06-2005, 11:32 AM
  5. Is this a proper dropout for a fixed?
    By zeytin in forum Fixed/Single Speed
    Last Post: 02-22-2005, 10:37 AM
