Results 1 to 4 of 4
    Oct 2010
    IRO Mark V... should I buy?
    I have a chance to buy a used IRO Mark V complete bike for $500
    Here iare the specs...
    IRO Mark V frame/fork, 56cm. Cromo construction. 2006ish model, more
    aero tubing / lighter thn newer builds.
    Velocity Deep V wheels Red, formula hubs, dt competition blk spokes.
    Crank Origin 8 46T 170mm, RW 18T flip/flop w/ bmx freewheel thats
    never really been used
    Bottom Bracket Shimano UN53 Sealed
    Chain KMC Red
    Lock Ring Formula
    Pedals Twisted PC, cut out to support SOMA double straps or REload
    foot straps (both available for $$)
    Headset IRO
    Stem IRO, 110ish mm
    Handle Bars NITTO MINI BULLHORNS, ANODIZED RED
    Grips long 17cm black w/ small amount of glitter track grips
    Seat Post Kalloy 27.2 sil
    Seat Selle Italia C2 Trans Am
    Brake Lever Campy (removed, available for $$)
    Brake Campy Veloce (removed, available for $$)
    Tires Maxxis Refuse 700 (brand new rear tire)
    Tubes 700 LV Presta
    He says that it is in great condition with minimal scatches.... Is that a good deal? Should I go for it?
    Attached Thumbnails Attached Thumbnails IRO Mark V... should I buy?-theiro.jpg
    Old and Fixed, Moderator
    Jan 2002
    It's not a bad price considering some of the upgrades....It's not a screaming good deal but if you like it, go for it......
    Dave Hickey/ Fort Worth
    Oct 2010
    True, thats what I was thinking but I was debating on going for it or going for a brand new SE Lager or Felt Brougham for just a bit more. I like the idea of getting a brand new one more then used obviously. What other ss/fixies are in that general price range and what do you think about those two?
    Cumudgitude
    Reputation: UrbanPrimitive's Avatar
    Jun 2009
    The Brougham isn't a bad bike. Unfortunately you missed the sale Nashbar had on the SE Lager frame/fork set in September. They were going for $80, but now they're at $150. Still, if you're interested in doing a build that might be worth thinking about. Check it out here.
Sea Otter Classic
Contest
