Results 1 to 12 of 12
    Aug 2010
    Rear skewers with adjustable tension
    Does anyone know what the rear skewers that have adjustable tension are called? The ones that sit on the end of the horizontal dropouts so you can make small adjustments to the chain tension. I'm also wondering if anyone knows where to buy them, preferably not QR ones.
    Jul 2010
    Snail cam?
    Aug 2010
    Hmm I looked those up and that's not what I'm thinking. These are attached to the rear skewers. They have a threaded part that comes out with in the horizontal dropout with nuts on the end that you can adjust to change the tension.
    biker boy
    Jul 2010
    chain tensioner
    surly sells tuggnut chain tensioners that work well with solid nutted axles and it also comes with an adaptor for QR axles
    Cumudgitude
    Reputation: UrbanPrimitive's Avatar
    Jun 2009
    Quote Originally Posted by bb1mina View Post
    chain tensioner
    For the win. Enjoy if you want 'em. Personally I've never bothered with them. Then again I'm not racing either, so a grain of salt may be necessary here.
    Reputation: JCavilia's Avatar
    Sep 2005
    Yeah, I think you're talking about tensioners like the surly Tuggnut. Your terminology is slightly confused, which is what threw prople off. These devices don't attach to the "skewers." They slip over the axle end, and pull the axle into the position you want before you tighten the axle nut. They are most often used with solid axles, which use nuts instead of a quick-release, and so have no skewer at all.
    Aug 2010
    The surly one is quite expensive, like $30 on amazon when you can get no-name ones for $3.
    Sep 2011
    but the surly one is a beer opener on the end!
    Roll Model
    Reputation: krustyone's Avatar
    Apr 2010
    Quote Originally Posted by ss junkie View Post
    I love fixie stuff, almost everything is a beer opener!
    "Science has proven that if you have one flat on your bike, you will have another one, sooner or later. This is the reason that you should always buy a new bike when you get a flat." Mr Grumpy
    Carbon Fiber = Explode!
    Reputation: CleavesF's Avatar
    Dec 2007
    $27 dollars for a bottle cap opener is definitely worth it in certain situations.
    '09 Voodoo Wazoo
    '08 Pedal Force RS2
    '06 Raleigh Cadent 5.0
    '01 Trek 4300 MTB
    '93 Norco Nitro SS MTB
    '88 Schwinn Prelude Fixie
    1 hour of running = 1 hour of wasted time when you could have been riding. - Alaska Mike
    Roll Model
    Apr 2010
    Agreed!
    I really like Surly stuff, too.
    duh...
    Jan 2005
    the surly will work w/ a qr skewer
    Quote Originally Posted by mikagsd
    Fat tire Fred....you are the bike god of the universe and unless someone agrees with your reasoning they are just plain stupid
  1. Swapping rear wheel skewers
    By bradsmith in forum Components, Wrenching
    Last Post: 04-09-2011, 05:54 PM
  2. 80kgf tension rear wheel
    By samh in forum Wheels and Tires
    Last Post: 03-08-2011, 01:52 PM
  3. SL3 rear drop out and Zipp Skewers: Issue??
    By mdutcher in forum Specialized
    Last Post: 03-01-2011, 12:06 PM
  4. 11 spped rear der tension questions
    By veloci1 in forum Campagnolo
    Last Post: 07-08-2010, 03:36 PM
  5. Rear Skewers
    By MystA RavE in forum Beginner's Corner
    Last Post: 08-27-2007, 12:20 PM
