Results 1 to 9 of 9
    Aug 2008
    Steamroller - Which carbon fork
    I have been wanting to get a carbon fork for the Steamroller. Any suggestions? I'll be running 23-26 tires, so does not need to have the clearance the stock forks has (something with standard reach calipers, though). I do like the stock fork angle/rake, so something similar?
    Thanks.
    duh...
    Jan 2005
    don't know any specifics, but you'll want to match the angle/rake/offset and a-c length (and obviously steerer)... one or the other is prob easy to find, both will have limited choices
    Quote Originally Posted by mikagsd
    Fat tire Fred....you are the bike god of the universe and unless someone agrees with your reasoning they are just plain stupid
    m_s
    m_s is offline
    oh lonesome road for you
    Reputation: m_s's Avatar
    Nov 2007
    Using a high stack headset might make up a little bit of axle to crown. I think Chris King does this with a 5mm base plate if you want to shell out the dough. Without knowing the steamroller's geometry, a cyclocross fork may actually be closest in measurments but you would have to use a cantilever brake.
    duh...
    Jan 2005
    Quote Originally Posted by m_s
    aren't most cx forks gonna have more that 38mm rake tho?
    Number 2 on the course.
    Reputation: PeanutButterBreath's Avatar
    Dec 2005
    400 a-c, 44 rake. Per the Surly site.
    Dec 2005
    Quote Originally Posted by FatTireFred
    Not really. I'm seeing most in the 43-47 range. Note to self: First coffee. Then post.
    duh...
    Jan 2005
    Quote Originally Posted by PeanutButterBreath
    per the surly site:
    Axle-To-Crown (1" steerer): 368mm
    Axle-To-Crown (1-1/8" steerer): 375mm
    Rake: 38mm
    http://surlybikes.com/parts/steamroller_fork/
    43-47>38... whether is matters much is another question
    Dec 2005
    Thanks!
    per the surly site:
    Rake: 38mm
    Evidently, I have Crosschecks on the brain.
    Baltic Scum
    Reputation: seeborough's Avatar
    I pondered the same question a few years ago and postponed a decision because I could not find a fork with specs close the original. As you know, "Fatties Fit Fine" on Surlys, not on bikes with carbon forks.
    A few weeks ago, I just put an old Look carbon fork on my Steamroller and went with it. Other than being considerably lighter and maybe a little smoother, it did not make a difference. In other words, don't over-think this.
    http://forums.roadbikereview.com/images/attach/jpg.gif
    Attached Thumbnails Attached Thumbnails Steamroller - Which carbon fork-img_0832.jpg
    Was juckt es die stolze Eiche, wenn sich ein Schwein an ihr kratzt?
Sea Otter Classic
Contest
