Results 1 to 3 of 3
    Jul 2004
    Why not use a singleator with vertical drops?
    Why couldn't i convert my bike with vertical drops to a fixed gear by installing a surly singleator chain tensioner?
    -dM
    Reputation: zapp's Avatar
    Apr 2002
    Quote Originally Posted by laxguy86
    -dM
    As long as you go forward it is ok, when you back pedal the chain will become taught on the botton(where the singulator is) and slack on the top. Loose chain bad
    Bianchi Pista 48X18
    Arrogant roadie.....
    Reputation: Dave_Stohler's Avatar
    As Zapp said, when you slow, your chain on top will go slack. Then it will jump off. Maybe it will get jammed between the ring and the crank? Maybe it will get jammed between the cog and the spokes or the dropouts? Oh, boy, won't that be fun!!! Can you say faceplant? Sure you can!
    We are the 801
    We are the central shaft
  1. The drops
    By Flip Flash in forum General Cycling Discussion
    Last Post: 07-11-2004, 09:39 AM
  2. vertical storage
    By girishji in forum Fixed/Single Speed
    Last Post: 04-25-2004, 12:48 PM
  3. bullhorns vs. drops
    By chicagochix in forum Fixed/Single Speed
    Last Post: 04-06-2004, 05:53 PM
  4. Replies: 12
    Last Post: 03-24-2004, 10:31 AM
  5. Riding in the drops - not workin'.........
    By 10kman in forum General Cycling Discussion
    Last Post: 03-15-2004, 08:36 AM
