Results 1 to 2 of 2
    Jan 2006
    Will This Razesa Track Bike Accept A Front Brake?
    I have an 80's era Razesa track bike and would like to know whether the existing fork will accept a front brake or if perhaps I need to replace the fork for one with a larger crown area if I choose to go with a front brake. There is approximately 1cm of available crown space.
    I guess I also need to be concerned about a brake caliper fitting properly onto the fork so it aligns with the wheel too.
    Thanks.
    Attached Thumbnails Attached Thumbnails Will This Razesa Track Bike Accept A Front Brake-mini-razesa1.jpg   Will This Razesa Track Bike Accept A Front Brake-mini-razesa2.jpg
    Done with winter.
    Reputation: asterisk's Avatar
    Oct 2003
    Just by looking, probably not. Some hotshot machinist might try but I don't think there is room to sit it high enough to maintain adjustment in the pads. Also resell value would go down.
    Better plan: find a replacement road fork with similar rake. That way it can be swapped out if you decide to sell or take it to the track.
