Results 1 to 17 of 17
    Mar 2018
    2007 Cannondale system six upgrade?
    Hi there. I just bought a used 2007 Cannondale system six with Ultegra 6800 components. Anybody think it would be a good idea to upgrade the bike with Ultega R8000 or Dura Ace R9100, or should I save for a new bike? Is this still a decent bike? Thanks, Bill
    Attached Thumbnails Attached Thumbnails 2007 Cannondale system six upgrade?-00o0o_jobpxhr3pik_1200x900.jpg
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by billoved7 View Post
    #1 that bike does not have Ultegra 6800 on it.
    #2 what's wrong with the group that you want to upgrade
    #3 what do you expect to gain with an upgrade
    Mar 2018
    #1 Sorry, new to the game, don't quite know what I am talking about. Closer look reviels Shimano Ultegra RD-6700A-GS
    #2 Bike shop notes read: rear derailleur,big chain ring,cables/housing.
    chain tool indicates chain is in good shape, cassette looks relatively fresh
    brake pads and tires in good shape
    #3 Expect to gain smoother shifting, hoping for a greater power transfer.
    Thanks for your feedback!
    Reputation: Lombard's Avatar
    May 2014
    A new groupset will not improve your power transfer.
    Smoother shifting? Is the shifting bad or could it just be better? If this bike is a 2007, I would be willing to guess it has 6600, not 6700 unless parts have been changed. The 6600 is a perfectly good groupset and since this is before Shimano went to shift cables going under the bar tape, it will not suffer from the "chewing shift cables problem" that later Shimano shifters have. I have a 5600 bike and I have no complaints about its shifting.
    tlg
    tlg is online now
    May 2011
    I would be willing to guess it has 6600, not 6700 [/QUOTE]It's definitely 6600 (or 5600). You can see the side shift cables in the photo.
    Slowski
    Reputation: eboos's Avatar
    Mar 2011
    Sorry, but what is going on with that steerer tube/stem setup? If you haven't already, I would ditch the steerer tube extension and just get a stem with more rise if needed. That has to give some funky handling.
    Switching to 6800 or later would require new wheels since right now you have a 10 speed wheelset. There are some who prefer 6600 vs 6700 shifters due to the cable routing on the 6700 causing more friction. I would say if the groupset you are using is working fine, keep it.
    I have a 03 Cannondale R800 which came with a 105 9 speed (5500) group. I replaced it with a 10 speed 5700 group only because I broke my shifter and couldn't find a replacement. In hind sight, I probably should have bought a newer bike, but I still ride it now. Weigh the cost before taking the plunge.
    May 2014
    It's definitely 6600 (or 5600). You can see the side shift cables in the photo.[/QUOTE]
    Yes, I see that now.
    You can't see the RD in the pic, but it's possible someone changed it at some point.
    pmf
    pmf is offline
    It's a 10+ year old bike -- I wouldn't change a thing. OK, maybe peel the Livestrong decal off the top tube and put a longer stem on it if that short one that's on it makes you feel too scrunched up on the bike. Then just ride it and save your money. Upgrading the components would cost a lot of money and not really get you much in return. If you're new to road biking, one of two things will happen by next year: (1) The bike will be in the basement gathering dust and you can use the money you saved to fund whatever the next hobby is, or (2) You'll be lusting after a new, shiny plastic bike with 8000 components. So just get out and ride (if it ever warms up) and discover if road biking is your thing or not.
    Mar 2018
    I saw the bike mechanic moving the rear derailer back and forth saying it has too much play. He showed me another bike's derailer that had hardly any side to side movement. The only other thing is the big chain ring is a bit shark toothed. So maybe I'll just do those things, and like you said, get out, ride, and see if it's my thing. Thanks.
    Mar 2018
    I'll check into the stem. Thanks for the advice.
    May 2014
    Yikes! Sounds like you bought a bike with a lot of miles on it. I hope you didn't pay too much. Are ALL the teeth in the big ring shark toothed? I say this because some teeth are designed to be sharper and shorter than others in order to make upshifts smoother.
    If rings are worn, chain and cassette are likely worn too unless they were changed recently.
    Mar 2018
    Yeah the shifting is not good. I had a mechanic look at it, and he was trying to adjust it, and gave up. The rear derailer has a lot of side to side movement. He recommended replacing it with Shimano Ultegra RD-6700A-GS 10-Speed Medium Cage Rear Derailleur Gray. That is what he wrote up, not sure if that is what should be done though. Anyway, Thanks for the advice!
    Mar 2018
    Here are the notes on the work up from the bike shop:
    rear derailleur
    big chainring
    cables/housing
    brake pads and tires in good shape.
    Do you think if I replace the derailer with a dura ace that it will produce even better shifting than Ultegra, or waste of money?
    May 2014
    rear derailleur
    big chainring
    cables/housing
    Cables and housings will probably do more to improve your shifting performance than anything else you can do. I would replace those on any used bike. If you do nothing else, replace your cables and housings.
    OK, at least those are two things that were replaced by the previous owner.
    WASTE OF MONEY. If I were you, I would put a new 105 mid-cage derailleur on it. Trust me, you won't be able to tell the difference between a 105, Ultegra or Dura-Ace. And your wallet will be happier.
    If you want to upgrade you should upgrade the fit.
    Not to sound like an alarmist but that steer tube set up may not be safe. It's definitely an indicator that a race bike such at that is not the best suited for your preferred riding style/position.
    As already said, get a stem with much more rise as opposed to that set up though.
    May 2014
    I would definitely agree with this. Not to mention, the fact that your stem is pointed down negates some advantage of the steerer extension.
    Lose the steerer extension and get one of these. Much safer:
    https://www.trekbicyclesuperstore.com/product/bontrager-elite-stem-40-degree-rise-236836-1.htm
    Slowski
    Mar 2011
    You gotta flip that puppy to -40 and be totally slammed.
  1. 2007 System Six or 2011 Super Six Hi-Mod: Which one?
    By tranzformer in forum Cannondale
    Last Post: 07-03-2011, 08:45 AM
  2. Wanted Cannondale System Six / Super Six tapered fork
    By Terra in forum Bikes, Frames and Forks
    Last Post: 11-29-2009, 11:51 PM
  3. Cannondale Six, System Six , Six 13
    By g_5706 in forum Cannondale
    Last Post: 04-18-2009, 04:38 PM
  4. Cannondale System Six or Super Six?
    By g_5706 in forum Bikes, Frames and Forks
    Last Post: 12-10-2008, 01:15 PM
  5. Cannondale Weight: CAAD 8, Six 13 team or System Six
    By distant ride in forum Cannondale
    Last Post: 04-16-2007, 09:46 PM
