Page 4 of 4 FirstFirst ... 234
Results 76 to 84 of 84
  1. #76
    Reputation: OldZaskar's Avatar
    Jul 2009
    Not sure - I took a couple pics of the headlight mount...
    (ignore the little notches - my attempt to eliminate the light from rattling in that mount)
  2. #77
    Reputation: WheresWaldo's Avatar
    Nov 2005
    Been doing a lot of little things for the Madone 9 Series as well as Wahoo ELEMNT mounts for Bontrager Blendr equipped bar and bar/stem combinations. Click the link in my signature to see more stuff.
  3. #78
    Nov 2005
    Mail came at 2 pm and then spent the rest of the day modeling the new mount for the Cycliq Fly6 Gen 2. Variations are now up for Specialized SWAT, Fizik ICS, GoPro as well as the Trek Madone Series 9. You can see them all here.
  4. #79
    Reputation: ddimick's Avatar
    Aug 2011
    Quote Originally Posted by WheresWaldo View Post
    @OldZaskar
    Does the Cygolite headlight use the same bracket as their tail lights? If so I can do something for you, otherwise I could do something in a week or so. Can you tell me specifically which headlight you have.
    I have done a bunch of interfaces for the K-Edge Garmin mounts, Di2, Garmin Virb, etc. I would probably do something that uses the K-Edge as a base.
    I have a Cygolite headlight bar mount that I'll donate, if you want it. I can't use it with my bars anyway. The helmet mount that came with my Expilion 850 was very easily modified to work with the K-Edge combo Garmin/GoPro mount, I just reamed out the holes to 5mm and good to go.
    3D Printed Accessories / Parts / Mounts-20161016_103230.jpg
  5. #80
    Oct 2014
    Quote Originally Posted by OldZaskar View Post
    I'd LOVE to be able to mount my Cygolite headlight in front of and under the Garmin Mount. Cygolite's mount is straight out of the '80s - large hinged clamp, long threaded rod and knob to tighten it - and the actual mounting plate with tab is bolted to the clamp.
    WheresWaldo, I have an extra one of these I'd be happy to send you.
    I have a small interest in mounting my Cygolite headlamps on a gopro style mount as well.
    Let me know where to send it if you are interested.
  6. #81
    Aug 2011
    Worst-case scenario you can do what I've done. Get a Cygolite helmet mount (ExpiliOn helmet kit), which works with Expilion, Metro, Streak, and Pace lights. You can't see it in their photo, but the upper half of the mount that the light clips to uses tabs that are a physical match for a GoPro mount, except Cygolite used a smaller 4mm screw. Drill the holes out to 5mm and it's a perfect fit.
  7. #82
    Crank Addict
    Mar 2014
    I have a request, that I think would be fairly easy to do because it seem like you already have the designs for some of the other parts. Could you make a mount that holds a Di2 junction box and mount to the two rear Tri-pod mounts on the Specialized Sitero Saddle?
    ___________________________
    2016 Pactimo Brand Ambassador
    www.Crankaddicts.cc
    www.skratchlabs.com
    www.hilltopbicycles.com
    2015 S-Works DSW Allez
    2015 Specialized Venge Pro
    2016 Specialized Fatboy Comp
  8. #83
    Crank Addict
    Mar 2014
    Quote Originally Posted by TricrossRich View Post
    Actually, scratch that... What about a mount that would allow you to mount a di2 junction box between saddle rails. Saddle rails are all basically a universal dimension, so you'd really only have to do round or 7x9. I'm thinking a Di2 mount with a small wing off either side that allows to clamp around each rail.
    www.Crankaddicts.cc
    www.skratchlabs.com
  9. #84
    Nov 2005
    I am sending you a PM with my email address so we can discuss this.
  1. Cannondale Specific 3D Printed Accessories
    By WheresWaldo in forum Cannondale
    Last Post: 06-14-2016, 04:53 AM
  2. 3D Printed Mounts For Felt Aero Road Bicycles
    By WheresWaldo in forum Felt
    Last Post: 03-10-2015, 08:54 AM
  3. Parts and accessories on the web...where?
    By Shogunade in forum Pinarello
    Last Post: 10-06-2014, 07:53 AM
  4. 20% off Specialized Parts and Accessories
    By CyclingVirtual in forum Hot Deals
    Last Post: 08-12-2014, 04:53 AM
  5. Replies: 31
    Last Post: 04-17-2010, 08:45 AM
