Sooo....the mount that came with my Topeak RaceRocket HP broke (the rubber-band thingy), and I have no problem carrying it in my jersey pocket, but on long rides I just found myself carrying too much. So I started playing around with mounting under my saddle...the height of the B17 creates enough distance from the rails to be able to hold the pump. I started with zip ties, which hold on tightly but obviously need to be cut and replaced when the pump is needed. So I then moved on to velcro straps, which have worked nicely. One way is having run the length of the seat, where it is completely invisible, but a bit harder to removed and put back. The other way is width-wise, which is held super tight and is really fast to remove and put back. 2013-02-19 13.24.15.jpg
Here are a few more pics. This is with some tape around the pump for protection, and with the pump zip tied rather than velcroed. I know zip ties aren't as convenient, but I haven't had a flat in 7 or 8 months, and the pump is a back-up for my co2 (in the bag). I threw a couple small zip ties in the bag now as well. It took about 12 seconds to zip tie the pump on, so its not an inconvenience (from my perspective).
