Results 1 to 15 of 15
    Jul 2018
    Back on the bike after 25 years!
    Hi all! First time poster here. Originally, I was looking to buy a mountain bike to get back into riding, but instead dusted off my vintage 1987 Cannondale SR500 road bike which I bought new 31 years ago. I road it for about six years, then got into other hobbies, and hung it up for 25 years.
    Cleaned it up, lubed it, made some minor adjustments, and been riding it for the last several days. It is working great, and I am having a blast, although the hills are killing me, but it is getting better!
    Reputation: Lombard's Avatar
    May 2014
    Hi Pilot and welcome back to this wonderful sport!
    A few things to look at specifically if you haven't touched that bike for 25 years. If that chain has any rust on it, replace it. Check your tires carefully for cracks (dry rot). If you see any replace them. Other than that, it sounds like you're good to go!
    If this is the first ride in 25 years, sure the hills will kill you! Keep riding those hills and they will get easier!
    All the best!
    Jul 2018
    All the best!
    Thanks! No dry rot on the tires, and the chain is in good shape. I do plan to get new tires, and tubes very soon, as I don't want flats or worse, even though I do carry a spare tube, and tools.
    Jul 2012
    I was going to say replace the tires regardless. They've been sitting for 25 years.
    Jul 2018
    Quote Originally Posted by Methodical View Post
    Absolutely! Going out today to pick some up at my LBS!
    Nov 2009
    Could be the hills are tough because back then the gearing wasn't very low, I had the same bike and stock it was very tall geared.
    Oh my, a troll who doesn't know the difference between your and you're. What will they think of next?
    Jul 2018
    I wish I kept my first road bike that I purchased 25 years ago.
    Sent from my SM-N950U using Tapatalk
    Sep 2011
    welcome back brother!
    Nov 2009
    pmf
    pmf is offline
    I had a seven speed Cannondale R400 years ago. Had the '3.0' frame. Probably the most uncomfortable bike I ever owned.
    a real member's member
    Jul 2016
    a bike that hasn't heen ridden in 25 years needs a full overhaul. it's easy, and, with a few tools, you can do it yourself.
    Jul 2018
    Quote Originally Posted by blackfrancois View Post
    I hear you. I will do it gradually though. It was well stored, and is riding great. I am replacing the tires and tubes today. I will get to the Bottom Bracket, cables, derailleurs, etc., over the summer. Everything is working as it should, however, smoothly, and so far reliably.
    jkc
    jkc is offline
    Jun 2014
    I would also, and did, change the brake pads. Mine was basically set aside for 23 years before I got started again.
    Reputation: GlobalGuy's Avatar
    Jun 2015
    Welcome back! By the way simply FYI. The road isn't any harder than it was 25 years ago. But should you have the misfortune to fall or crash onto the payment your body will swear to you the roads today are much harder than they were 25 years ago!
    Be safe!
    Jul 2018
    ^^^^^^^Thanks guy. Yes, I will try to keep my body off the road, as I don't want to test your theory which I am sure is fact!
  1. Back after 20 years
    By bikenut65 in forum General Cycling Discussion
    Last Post: 04-19-2016, 02:40 PM
  2. Back back back back!
    By texasnewb in forum The Lounge
    Last Post: 07-17-2013, 12:31 PM
  3. Back to Back Century Rides, Back to Back Near Death Experiences
    By Wood Devil in forum General Cycling Discussion
    Last Post: 10-12-2011, 02:39 PM
  4. Back on after four years,
    By Baba in forum Beginner's Corner
    Last Post: 06-06-2008, 12:02 PM
  5. Flat after flat after flat after...
    By PaulCL in forum Wheels and Tires
    Last Post: 10-04-2005, 08:56 AM
