Results 1 to 25 of 38
    Reputation: yuris's Avatar
    Oct 2011
    base layer - what are you preferences?
    Hi guys, what do you use as base layer for winter riding? Compression or looser base layer? Sill, polyester, any other hints?
    Thanks
    Reputation: dcorn's Avatar
    Sep 2011
    'Compression', meaning really fitting stuff without actual squeezing. I usually use under armour, heat gear when its just a tad cold out and cold gear when it's below maybe 55-60. This year, I'm thinking about going with something integrating Gore Windstopper so I don't have to wear a vest or jacket on top.
    Dec 2005
    I've tried the windproof base layer with a regular jersey and it didn't work very well. I get wet and cold underneath. I prefer a Windstopper jersey with or without a Craft Pro Zero Extreme base layer when it's cool, and a Windstopper jacket with a Craft Pro Zero base layer when it's cold.
    Idiot at large
    Apr 2010
    I look to my snowboarding stuff... so Hot Chillys for the base layer shirt
    2010 Specialized Secteur Elite upgraded with 32T cassette and does not have Stan's (yet)
    2009 Specialized Rockhopper Comp 29er upgraded with 36T cassette and Stan's Arch EX rims and tubeless
    2013 Cannondale CAADX-6 Tiagra upgraded to 32T cassette and Stan's Alpha 400 rims and tubeless
    2008/2009 Burton T6 156cm with Burton Triad Bindings & DC Judge boots
    Reputation: pedalruns's Avatar
    Dec 2002
    I wear PI's 'barrier' baselayer and it works great for me.
    waterproof*
    Reputation: Creakyknees's Avatar
    Sep 2003
    I have a mesh top, not suitable for use by itself but very functional.
    * posted by Creakybot 2013 all rights reserved.
    * not actually waterproof.
    irony intended
    Reputation: carlislegeorge's Avatar
    Mar 2004
    Craft pro zero for me, Not compression but not loose either....works fine for what it it's supposed to do, but...would like to try something else. I'm a heavy sweater, even with breathable layers, I still get wet in almost every situation when its cold and not evaporating quickly.
    Jul 2012
    I use Pearl iZUMi Transfer Long Sleeve Baselayer, I went riding last week, 34 degrees outside. Wore this baselayer and long sleeve jersey and never felt cold.
    Trek 2.3 - 2012
    Trek Madone 5.2 - 2012
    Sep 2011
    Quote Originally Posted by yuris View Post
    Thanks
    Where do you live? Alaska, Houston, Siberia? Everyone's tolerance is different. I live in the midwest (Illinois). When it's close to freezing temps, I will wear my Pearl Izumi Transfer Long Sleeve Baselayer. In colder or even windy conditions, Pearl Izumi Thermal Zip Neck Long Sleeve Baselayer.
    - Ed
    2012 Trek Madone 6.7 SSL
    2013 Specialized Tricross Comp disc
    2011 Trek Top Fuel 9.9 SSL
    2012 Salsa Mukluk 2
    Jul 2010
    Merino wool - Arcteryx
    Jun 2012
    Another vote for Hot Chili's.
    Reputation: OldZaskar's Avatar
    Jul 2009
    UnderArmor's Cold Gear (or something like that). Never on sale. Always $49.99. I've tried a handful of others... won't try again. I'll just keep added to the pile of UA base layers... oh, they seem to last indefinitely too.
    Master debator.
    Reputation: nOOky's Avatar
    Mar 2009
    None of your darn business. What I wear is comfortable and warm, it makes riding more of a joy than a chore. Figure it out for yourself like I had to!
    http://us.icebreaker.com/Bodyfit-150...26%20Baselayer
    Cheese is my copilot
    Reputation: wooglin's Avatar
    Feb 2002
    Wool. No contest.
    Life is better in the big ring.
    http://theclemencyblog.blogspot.com/
    Reputation: partyofone's Avatar
    Feb 2012
    Quote Originally Posted by OldZaskar View Post
    Same for me. Got some at the outlet for $20. Nice and warm.
    Reputation: JCavilia's Avatar
    Sep 2005
    Stuff I find cheap from Sierra Trading Post, made of any wicking synthetic. All the microfiber polyester fabrics are pretty similar IME. Reasonably tight fit (no flapping) but not compression tight.
    May 2012
    Patagonia Capilene-I still wear light and medium weight underlayers I bought in 1989. However, YMMV with the newer Made in China versions.
    Reputation: BostonG's Avatar
    Apr 2010
    Quote Originally Posted by JCavilia View Post
    Same here.
    I don’t rely on the base layer for warmth, but for wicking away the sweat. For me, a form fitting athletic shirt (running shirt or anything like that) works well and costs much less.
    In the mid 30’s, my trunk is perfectly comfortable with that base layer, a long sleeve jersey, and a good windstopper jacket (which is the important part IMO).
    I ride mostly in the honorable pursuit of being kissed on both cheeks at the same time by one blond and one brunette. But not redheads, they scare me.
    Sep 2005
    Quote Originally Posted by BostonG View Post
    Same here.
    Well, the base layer provides warmth, too. I have them in several weights for different conditions. But I ride (at least commuting) down to 10 degrees or so. I agree with the layering concept. Outer layer is a simple shell of tightly-woven polyester microfiber (the one I use most I got from Performance for about 20 bucks, about 20 years ago). For the coldest days it's shell, fleece vest, two longsleeve layers. Plus big gloves and fleece balaclava, of course,
    Sep 2012
    In NJ we have Marshall's that has all sorts of Brand Name Active Wear. I just picked up several Under Armor Short and Long Sleeve Shirts (Heat/Cold Gear, Compression/Fitted). Half Price or less.
    Teach me how to Bucky
    Reputation: Brad the Bold's Avatar
    Jun 2010
    I have several Hot Chilly and Under Armor base layers. All are black, moisture wicking, fast drying of various types. I just wear them under a short or long sleve jersey.
    They go from biking and running in the spring and fall, to the ski slopes in winter. And they also go deer, elk , duck , goose and turkey hunting too!
    "Why don't these people grow up, bicycles are for children, & trained animals. Get off the roads, and you won't get run over. These freaks with their space clothes speeding down the streets hit people all the time. I won't drive in your bike lane, you stay the hell off the road." Mervin Bell of Galloway, OH.
    -Special thanks to osteomark for the avatar
    Oct 2009
    Cheap $20 stuff from Target. Think it's called Tech Gear (?). Not compression, but not loose either. Polyester.
    I use them for mountain biking and road riding (and motorcycle riding, and walking my dog, and.....).
    Work great, comfortable, cheap.
    Jun 2012
    Well, the base layer provides warmth, too. I have them in several weights for different conditions. But I ride (at least commuting) down to 10 degrees or so. I agree with the layering concept. ...big gloves and fleece balaclava, of course,
    Holy Crap!!! 10 degrees???!!!! I'm worrying at 50 degrees. At 40, I'm not sure I'm riding, and at 35, we're having record lows.
    Wait. Is that 10 degrees F or C?
    Edited to ask whether metric or U.S. (I think we're the last country using Fahrenheit.)
    Jul 2007
    SS base layer is a Smartwool t-shirt
    LS base layer is silk, LL Bean I think.
    After that, I have poly pro underwear of different weights.
    Lower body, 3 weights of tights ending with windstopper. If that doesn't do it, poly pro long johns, again of differing weights.
    (I have a lot of skiing and hiking gear.)
    I've heard about compression stuff, don't really know what it is, though. Don't think I'd want anything compressing my upper body.
    wyrd bið ful ãræd
    Reputation: c_h_i_n_a_m_a_n's Avatar
    Mar 2012
    Last week when I went out it was 8-10°C (that is 45-50°F for you over the pond) and I had the Endura merino wool baselayer, short jersey and a softshell gillet + arm warmers. After about 8 miles it was quite warm ...
    Marino wool baselayer +1
