Page 1 of 3 123 LastLast
Results 1 to 25 of 64
    eminence grease
    Reputation: terry b's Avatar
    Bibstraps - over or under your base layer?
    Never thought about it until today. What's correct?
    You'd be better off with a netbook, they do everything better.
    My travel blog: http://tbaroundtheworld.blogspot.com
    PIITWhat?
    Reputation: Love Commander's Avatar
    Aug 2009
    Baselayer over bib straps. Having a base layer tucked into my shorts feels wrong and looks dorky.
    (edited for clarity)
    Reputation: eekase's Avatar
    Nov 2009
    Over...
    ...so I can clip my phone, pager, pens, pocket protector to the straps and just unzip my jersey some to access an item
    2011 Look 695 Campy 11
    2009.5 Cervelo R3SL TdF SRAM LTE Red
    2011 Specialized S-works Tarmac SL3 Campy 11
    2012 Specialized S-works Tarmac SL4 New Sram Red
    2013 C'dale Super6 EVO
    You need to go over unless you want to completely strip down to go to the bathroom.
    Still On Steel
    Reputation: Allez Rouge's Avatar
    Dec 1969
    Quote Originally Posted by Love Commander View Post
    I go over. Having a base layer tucked into my shorts feels wrong and looks dorky.
    Maybe I'm misunderstanding, but those two sound mutually exclusive. I put my bib straps over my base layer so the base layer WILL be tucked into my shorts, by default so to speak, rather than peeking out from under my jersey.
    Allez Rouge
    Reputation: ddimick's Avatar
    Aug 2011
    Quote Originally Posted by Allez Rouge View Post
    Same, I put base layer under the straps.
    Dec 2005
    ^^^Makes no sense. How can you wear your bib straps over a base layer and not tuck the base layer in?
    OP: straps over the base layer. Have never seen it done any other way.
    Jul 2008
    Bib straps go over my base layer, but under jersey, jacket, vest, or backpack.
    I like my base layer on the bottom to avoid the straps chafing my shoulders and nipples. Some bibs are worse than others at this -- a couple pairs, I have to ride with a sleeveless base layer all the time, even in the heat of the summer, or I'm not feeling well. Also, if the base layer is right against skin, it will wick moisture better.
    haole from the mainland
    Reputation: jorgy's Avatar
    Oct 2005
    Pros do the bibstraps over their base layers. YMMV
    PIITWhat?
    Aug 2009
    What I wrote made no sense. I've gone back and edited. I meant to say I keep my base layer over my bib straps.
    Only time I wear a base layer is for cold weather, so they're usually fairly substantial. I don't like the feeling of the fabric bunching up under my bib shorts.
    Aug 2008
    Base layer under. If it's bunching under your bibs, buy a smaller baselayer!
    Hucken The Fard Up !
    Reputation: Salsa_Lover's Avatar
    Jul 2008
    If your base layer bunches, then you got one or 2 sizes too large.
    Base layer tight fit and under straps
    Quote Originally Posted by zank
    They're just bikes. Ride 'em in the rain, salt, snow and crap to fully appreciate them.
    Quote Originally Posted by Sean Kelly
    The thing about the cold is that you can never tell how cold it is from looking out a kitchen window. You have to dress up, get out training and when you come back, you then know how cold it is.
    PIITWhat?
    Aug 2009
    It's sized right.
    Reputation: Kai Winters's Avatar
    Aug 2009
    Base layer under my bib straps...when I wear clothing when riding that is...
    Reputation: minutemaidman's Avatar
    Jun 2010
    I dont use a base layer. Never have. So, I dont know and it wont matter in my case.
    A while back I decided to ride a bike as often as possible. These are my observations from the saddle, one pedal stroke at a time, on my way to being a better cyclist.
    Aug 2005
    Base layer under...especially important if you have sensitive nipples. Oops, was that too much information?
    FTR
    FTR is offline
    Burn baby, burn.
    Reputation: FTR's Avatar
    Sep 2006
    Quote Originally Posted by dozer5 View Post
    Agreed.
    Especially during winter the idea of having to get completely naked if you get caught out would tell me that bib straps over the base layer is the way to go.
    Reputation: 32and3cross's Avatar
    Feb 2005
    Base layer under the straps always.
    Travels by Map
    Reputation: nate's Avatar
    Jun 2004
    If it's over your bibs, it's no longer a base layer.
    eminence grease
    Quote Originally Posted by nate View Post
    Sure it is, at least everywhere but where it's blocked by the straps.
    Steaming piles of opinion
    Reputation: danl1's Avatar
    Quote Originally Posted by terry b View Post
    Base under in winter, over in summer.
    Because.
    A good habit is as hard to break as a bad one..
    FTR
    FTR is offline
    Burn baby, burn.
    Sep 2006
    Quote Originally Posted by danl1 View Post
    Because.
    I think you should just tuck in the front and leave the back hanging out.
    Sort of like a mullet.
    Banned forever.....or not
    Aug 2002
    Straps go over, to keep the base layer tucked in.
    Dogbert.
    I>U
    Reputation: onlineflyer's Avatar
    Aug 2005
    Whatever meets your fancy. da!
    If you focus on the past, you will never see the future.
    Every day I wake up is a good day!
    "I don't need another bike"
    - Anonymous
    PIITWhat?
    Aug 2009
    Base layer tucked into bib shorts is on the same level of dorkiness of tucking your t-shirt into your underwear. NERRRRDS!
  1. Base layer funk
    By filtersweep in forum General Cycling Discussion
    Last Post: 01-14-2010, 06:01 PM
  2. Base Layer 4 Cooling
    By lx93 in forum Commuting, Touring and Ride Reports
    Last Post: 06-17-2009, 08:14 AM
  3. Base layer and hot rides...
    By BenWA in forum General Cycling Discussion
    Last Post: 08-01-2006, 02:59 PM
  4. Base Layer question
    By slamy in forum General Cycling Discussion
    Last Post: 05-17-2005, 05:34 AM
  5. Cheap Base Layer
    By fredstaple in forum General Cycling Discussion
    Last Post: 12-31-2004, 08:14 AM
