Results 1 to 25 of 35
    Jul 2009
    bike frame size......
    so now that i'm ready to pull the trigger on a bike, I find they are out of my size. I was looking at the mercier kilo wt from bikesdirect.com. it's a wide tire, cro mo single speed. I was looking for the 53cm. i'm 5'10" but my legs are on the short side. they have the bike in 56cm and that's just the slightest bit on the tall side for me. I had my heart set on this bike and nobody has anything even remotely similar. what would you do??? HELP?!?!?
    Cycling Addict
    Nov 2013
    Sorry, Charlie...
    couldn't resist
    Life is short... enjoy the ride.
    The Slow One.
    Reputation: Alaska Mike's Avatar
    Sep 2008
    Ask them when the next shipment is.
    WA outdoor enthusiast
    Mar 2002
    BD -- wait a week for next shipment, don't be color specific. Or, a new model in 2 months with similar specs. If you know your fit, stick with it; especially on a frame that has many comparable competitors.
    Jul 2009
    unfortunately this bike has no competition. only thing I can find that comes close is the steamroller, which will handle a smaller tire and the frameset is almost as much as the kilo. I hope they're getting more in but in my limited experience with bikesdirect, when it's out it's out. in terms of fit, this willo be my second road bike. my first was a 56cm that I couldn't ride because it had tiny little tires and I weigh almost 300 pounds. this is why I need the larger tires.
    What the what???
    Jul 2009
    As a fellow Clyde, I generally like my frames a little bigger. Too small and I feel like I'm all over the bike. I'd say get the 56. You can swap a 0 setback seat post and a shorter stem if necessary.
    Nothing in all the world is more dangerous than sincere ignorance and conscientious stupidity. - MLK
    a real member's member
    Jul 2016
    you can buy a vintage, lugged chromoly bike and convert it to single speed for the same cost, and then have something nicer and more interesting now and more valuable years from now.
    Feb 2017
    I would say get the 56cm and be done with it. If that isn't going to work for you the only other option is one of these.
    Reputation: Lombard's Avatar
    May 2014
    Fit is the most important thing. IMO, I would NEVER buy a bike that doesn't quite fit and try to make it fit.
    If it doesn't fit, you musta quit.
    -- Warren Buffett
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by charliethetuna View Post
    What makes you think the 56 cm is "the slightest bit on the tall side" for you? The 53 cm has a 547 mm effective top tube. For most people 5'10" tall, that would be too short. Bikes have to fit in the horizontal dimension as well.
    Jul 2009
    well, I had a dawes sst which had the slight compact style top tube and when standing over the bike it was pretty much up there. I didn't stand on my toes or anything but I would hate to hop off the thing during a quick stop and jam my balls on the top tube. I think i'm gonna pull the trigger on the taller bike. I believe it will give me a more relaxed fit, which as a larger rider I think would be better for me.
    wim
    wim is offline
    Feb 2005
    Very few people hop or come off a bike so that both feet hit the ground simultaneously. The ones that do are usually in their first week of learning how to ride a bike. I'm 5'10 with relatively short legs (82 cm floor-to-crotch), the top tubes of all my horizontal-top tube bikes have all contacted my balls with both feet flat on the ground, and I've never suffered from this in decades of riding. Don't size a bike by standover, it's a bogus concern.
    Apr 2011
    Quote Originally Posted by wim View Post
    32.2" for 5'-10" height is about average leg length.
    May 2014
    Quote Originally Posted by bvber View Post
    That's what I was thinking. I have the same dimensions and I've never mashed the twins on the top tube of a 56cm frame - not even the one bike I have with a horizontal top tube.
    -- Warren Buffett
    Apr 2011
    56cm frame w/ horizontal TT?
    Were you wearing these by any chance?
    bike frame size......-2015-ladies-creepers-platform-shoes-vintage-lace-up-flat-shoes-women-casual-solid-creeper-shoes.jpg
    May 2014
Name:	2015-Ladies-Creepers-Platform-Shoes-Vintage-Lace-up-Flat-Shoes-Women-Casual-Solid-Creeper-Shoes.jpg
    LOL! Good one! Answer: No.
    -- Warren Buffett
    Jul 2009
    see, i'm not quite sure how to measure my standover. I stood against a wall and put an angle between my legs and flat on the wall. but i'm not sure whether I should just put the horizontal of the angle kind of casually up to my nuts or if I should jam it up there, so I came up with a couple different measurements. in any case I think the 56cm is gonna work out for me. I've been doing this for a while and I know how to ride a bike. just that this will be my first "real" road bike. I've always ridden mtn bikes and I know how they should fit me.
    Nov 2009
    Jul 2016
    if i'm not mistaken, the monster wore these same cycling shoes at the '39 Transylvania 100 in that historic win.
    wim
    wim is offline
    Feb 2005
    ... i'm not sure whether I should just put the horizontal of the angle kind of casually up to my nuts or if I should jam it up there, so I came up with a couple different measurements.
    If the angle you used was a thin piece of steel (like a carpenter's square), your reading may be off quite a bit. Use something that's about one inch wide, like the spine of a book large enough to reach the wall behind you.
    Move your package out of the way and bring whatever you use up hard enough where it will approximate the pressure of a saddle at low speeds or while coasting. That's quite a bit--you should feel contact with the pubic bone. "Cram" is the word here.
    You getting different measurements is normal. Depending on thickness of the horizontal up against you and your accuracy in squaring up the angle or book, that measurement can be 3 or more centimeters off. To get a good reading, do the procedure three or four times and use the average from those readings.
    is riding in MOPP4
    Reputation: Tachycardic's Avatar
    Mar 2013
    I don't feel good about this purchase charlie. I think you would be better off going to a reputable LBS. You will likely pay more, but you will end up with a bike that actually fits well.
    Wake me up when it's alarm green.
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by Tachycardic View Post
    With some shops, yes. With other shops, even if "reputable," not so much. Looks like it's all moot for now--the bike he wants is sold out in all colors and sizes. Mike Spratt writes "More in November."
    Feb 2010
    You should buy a bike that fits when you are on the bike riding it. Not when you are off the bike standing over the top of it, standing next to it, or standing across the room from it.
    For you, buying a bike online seems like a really bad idea. You don't actually know what fits.
    wim
    wim is offline
    Feb 2005
    I don't know, a serious fitting seems like a lot of thought, time and money invested for a $450 Bikes Direct "Track" bike that most likely won't see long rides, or, in spite of its description, track use. It's just a fixie. The 56 cm would have worked fine for him, IMO.
    Jul 2009
    this bike will pretty much be my "everything" bike. the trouble with a LBS is this is a very specialized bike. it's a steel single speed wide tire bike. the only other one I could find is the steamroller. chain reaction cycles has a really nice bike but out of my price range. I've bought 2 other bikes from bikesdirect and have been very happy. i'm pretty good at self fitting. I've done a lot of research and know what to do and what to look for. as of now I cant seem to find a bike that fit my criteria.
  1. Looking for a bike/ frame size help
    By Roam in forum Beginner's Corner
    Last Post: 09-20-2011, 09:06 PM
  2. frame size for TT bike
    By d26818 in forum Bikes, Frames and Forks
    Last Post: 08-03-2010, 07:37 PM
  3. Bike frame size
    By compsysathlete in forum General Cycling Discussion
    Last Post: 04-15-2010, 02:41 PM
  4. New Bike, Frame Size
    By cebelletete in forum Beginner's Corner
    Last Post: 05-07-2008, 11:04 AM
  5. Bike frame size and handling
    By JRF in forum Components, Wrenching
    Last Post: 10-08-2005, 03:14 PM
