Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
  1. #26
    gazing from the shadows
    Jan 2003
    Quote Originally Posted by gazoome View Post
    What type of regular cleaning products should I use (stuff you can find in any store) ?
    Take all you have, start trying them, mild to harshest. Try a small spot. WET WIPE OR RINSE THE THING OFF WHEN YOU ARE DONE WITH EACH ONE.
    Either you will find one that works, or you won't. So long as they don't sit on the saddle, you won't ruin it. And the saddle is cheap even if you do, really.
    Good luck.
  2. #27
    Reputation: Lombard's Avatar
    May 2014
    Gazoome,
    As you can see from most opinions here including mine, this is not worth fussing over.
    If it bothers you that much, get the black version. Otherwise, just ride your bike and enjoy it!
  3. #28
    May 2014
    Oxy works well, for what it works on. Which is not anything (not great with grease for example). It releases sodium peroxide as the active agent, so relatively mild and eco friendly as these things go.
    A larger box of powder, not all that costly for how long it lasts, can be mixed from mild to paste strength.
    Fixed.
  4. #29
    Jan 2003
    Fixed.
    Please don't put your words under my name.
    I know it is common, and this example is not a big deal in the larger scheme of things, but I don't like it when it looks like I wrote something I didn't. Please correct your post so you are not distorting my words, which will save me the hassle of sending a PM to Coolhand. Thanks.
    Oxy works great on grass stains (on clothes and shoes), and on mildew on lawn furniture, to name two examples.
  5. #30
    May 2014
    Quote Originally Posted by QuiQuaeQuod View Post
    Note that I bold faced what I changed in your post. No offense intended.
    My experience with Oxy has been different. For me, it never removed any stains or for that matter, didn't do anything that clear water couldn't do. Scam.
  6. #31
    Jan 2003
    I did not think you intended such. But it still looks like it is coming from me, after all it is a quote by "me". I've been around long enough that I have seen "quotes" come up months or even years later. I would rather not have to figure out if any such quotes are by me or not after a lag time.
    Take my name out, just leave it without an author. That would be fine with me as well. The meaning will still be clear in this thread.
  7. #32
    May 2014
    Done.
  8. #33
    Jun 2008
    Looks to me like a couple of doses of Kaopectate before the ride may have prevented this "stain".
    Quote Originally Posted by mtrac View Post
    Meanwhile ...
    Attachment 320473
  9. #34
    Jan 2003
    Done.
    A civil conclusion to a minor issue... don't let the rest of the internet know!
    You have my thanks.
  10. #35
    May 2016
    Lacquer thinner will clean it real good
  11. #36
    May 2014
    You have my thanks.
    No problem! I won't tell if you don't tell.
  1. Replies: 24
    Last Post: 01-08-2009, 10:27 AM
  2. Those dirty, dirty Pubs.
    By MR_GRUMPY in forum Politics Only
    Last Post: 10-31-2006, 08:26 AM
  3. Mark V is a dirty dirty. . . . bike porn
    By StageHand in forum Fixed/Single Speed
    Last Post: 03-02-2006, 05:27 AM
  4. Flat after flat after flat after...
    By PaulCL in forum Wheels and Tires
    Last Post: 10-04-2005, 08:56 AM
  5. O'Reilly is a dirty-dirty old man.
    Last Post: 10-14-2004, 09:00 AM
