Anyone know of an online (or formula, for that matter) to calculate chain length if you know the number of teeth of your ring and cog, plus chain stay length? All I care about is for fixed gear. I can't find anything. Thanks.
I know I've seen one somewhere, but I didn't have much interest in it and don't remember where. Might be www.sheldonbrown.com
Beware the risk of overtechnologizing, though. Couldn't you just stretch the chain around the gears and pull it tight?
I've converted a road frame to fixed with an ENO eccentric fixed hub. The eccentric offset, with my current gears, is in the 6 oclock position; ideally, it would be closer to 9 or 3. So, I want to determine if different ring/cog combinations that are close to the same gear ratio would place the offset where I want it, given the chain length. It seems much simpler to me to do this mathematically rather than buying and experimenting with 50 different combinations.
Thanks.
Doug
Each tooth added or subtracted to the total equals 1/4 inch of chain. The wheel will move forward or back by approximately 1/8" for each tooth. If you have the bike setup, you have a baseline length to go from.
You-eth be right-eth, if-eth you don't care-eth...
about the gear inch-eth.
The Fixed Innovations software is handy if you set it up to generate a chart -- it tells you visually which different gear/sprocket combos you can use to come up with the same gear inches for a given chainstay length.
Related Threads
Road Bike, Cycling Forums
5.4M posts
205K members
Since 1990
