Results 1 to 25 of 35
Thread: Chainring swap?
    Apr 2017
    Chainring swap?
    Hello I'm currently running 10 speed Sram Red. My crankset is 53/39t I'm wondering if it's possible to swap out my smaller chainring for a 36t?
    Not sure if this would cause any problems or if it's even possible.. I'm just looking for a better gear ratio for my riding style.
    Thanks!
    Crank Addict
    Mar 2014
    Quote Originally Posted by Brock4 View Post
    Thanks!
    Its probably possible, and should work fine, although I think that most manufacturers don't recommend more than a 16 tooth gap between big and little ring.
    ___________________________
    2016 Pactimo Brand Ambassador
    www.Crankaddicts.cc
    www.skratchlabs.com
    www.hilltopbicycles.com
    2015 S-Works DSW Allez
    2014 S-Works Shiv TT
    2015 Specialized Venge Pro
    2016 Specialized Fuse Comp
    Apr 2017
    Quote Originally Posted by TricrossRich View Post
    That's my main concern, if the large gap would cause problems with the derailleur or something...
    HERKWO
    Reputation: Herkwo's Avatar
    Nov 2002
    The problem you'll find is that you have a 130 BCD (Bolt Circle Diameter) for your existing SRAM crankset. Finding a 130 BCD 36t chainring is gonna be tough. 130 BCD x 38t is the smallest I've seen available...
    I think you'll have to invest in a compact crankset to go smaller... or change your cassette to a 28t to ease the climbing or swap derailleurs to one of the SRAM wifli derailleurs which should allow you to go to a 32t cassette and achieve what you are after??
    HERKWO
    ____________________________
    2005 Airborne Manhattan Project
    2010 Colnago CX-1
    'brifter' is a lame word.
    Wrong. You can't mount a 36t (110mmBCD) chainring on a 130mm BCD crank.
    And yes, the gap between 53 and 36 is beyond the spec of the front derailleur. It would work if you could do it, but not well.
    Op...please post in the proper section of the forum, don't just drop everything in General.
    I work for some bike racers
    and a bunch of skateboards
    Apr 2017
    Quote Originally Posted by Herkwo View Post
    What if I were to change both chainrings? Would I still be able to use my existing arms? Or is that where the BCD measurement comes into play? Sorry if these questions are lame.
    Also I have already changed my rear cassette from 11-23 to 11-28.
    Mar 2017
    Relax. Bro.
    No...you can't mount a 36 on a 130mm crank. Changing the big ring isn't going to change this. Look at your crank where the rings mount and it should be obvious. If you want a 34 or 36 you have to have a 110mm crank. Unless you're using Shimano cranks, which you aren't. As posted above 38 is the smallest ring you can mount on a 130 crank.
    Apr 2017
    Bummer! Thanks for the help guys!
    Cheers
    Quote Originally Posted by eder10986 View Post
    Relax. Bro.
    I'm not your 'bro' and I'll post how I please. This is your first post here, you really could have tried a little harder to contribute to the actual issue.
    Sep 2012
    i'm not your 'bro' and i'll post how i please. This is your first post here, you really could have tried a little harder to contribute to the actual issue.
    Bro
    Fred-li-ness is not a virtue, it's a way of life.
    Embark on Fredly endeavors.
    Reputation: arai_speed's Avatar
    Aug 2003
    ...I'll post how I please...
    If you can post how you please. Others can too.
    i.e. I'll post in whatever forum I want!
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Relax. Bro.
    He said please. How much more relaxed do you want your Bro to be?
    Reputation: OldZaskar's Avatar
    Jul 2009
    Quote Originally Posted by arai_speed View Post
    Really? You put cxwrench's post - the actual definitive answer to the OP's question - on par with the one-post troll's useless comment?
    Don't give up cxwrench - for every arai_speed, factory feel and eder10986, there are scores of us who really value your input.
    Aug 2003
    Quote Originally Posted by OldZaskar View Post
    No.
    I put his relentless dribble about posting in the right section on par with every one-post troll comment.
    You can bundle me in the to the "troll" category if that makes you feel better. I would value his input a lot more if he gave up on his compulsive disorder to request that everyone do as he says. Really.
    a real member's member
    Jul 2016
    use a gear calc like this one: Mike Sherman's Bicycle Gear Calculator
    you'll find changes to your cassette make a bigger impact than changes to your chainrings.
    Mar 2017
    My apologies for my un welcomed first post.
    Truthfully I LOVE the sport. Love my bike. And everything about it all. Y'all don't know me and I don't know you so we shouldn't judge one another.
    Simply put I thought it rude to call someone out who was asking for help. But all forums are like this anyhow.
    Again. Sorry. And sorry for taking away from the TRUE purpose of this post which I read in its entirety to learn and progress.
    Nov 2009
    blome, bro
    Reputation: Srode's Avatar
    Aug 2012
    Welcome to the forum - thick skin is required sometimes here as it can get a bit dramatic.
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Jul 2009
    Quote Originally Posted by factory feel View Post
    blome, bro
    Okay, that was funny
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    This needs to be added to the faq thread because bros have asked this question at least a hundred times.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't %^&* like that since I was an altar boy" Hank Moody
    Feb 2002
    As cxwrench so accurately pointed out, all you have to do is look at your smallest chain ring as mounted on the crank and you can clearly see that there is no way to fit a smaller ring on that crank. You need a new crank to mount smaller chain rings or a wider range cassette. The new cassette would be cheapest and the new crank would be a better solution because you wouldn't end in with such big tooth jumps on the cassette. It's your money so you get to choose which works better for you.
    Nov 2010
    Relax. Bro.
    Cxwrench is cranky at times, but has the most mech. knowledge of anyone on the forum
    You will learn to appreciate him.
    Just don't use "brifter"
    No.
    It's not that I want people to do what I say, it's the way the forum is set up. You think I have some kind of compulsive disorder, I think you're a slob. Not really a big deal, but if the forum has different sections to keep things organized and you don't use them what does that suggest? The idea is to post your questions in the appropriate place, not lump them all into the first section that ends up in front of you.
    Nov 2009
  1. Switching chainring/spider from 110 to 130, chainring questions
    By veloci1 in forum Components, Wrenching
    Last Post: 05-17-2014, 07:38 PM
  2. chainring swap; 34t to 38t (?)
    By sbglax13 in forum Components, Wrenching
    Last Post: 05-07-2009, 12:30 PM
  3. Two chainring questions: D.I.Y. chainring bolt tool; grease?
    By RedRex in forum Components, Wrenching
    Last Post: 06-05-2007, 03:45 PM
  4. Older Dura Ace Chainring swap?
    By DannyG in forum Components, Wrenching
    Last Post: 08-09-2006, 07:48 AM
  5. swap chains when you swap wheels ?
    By fraser in forum Wheels and Tires
    Last Post: 09-20-2004, 07:35 AM
