Results 1 to 20 of 20
Thread: Cooling Fan
    Sswitzky
    Sep 2018
    Cooling Fan
    Does anyone have a cooling fan for indoor training that they really like?
    Thanks!
    Reputation: Akirasho's Avatar
    Quote Originally Posted by sswitzky View Post
    Thanks!
    Yep, it's called central air.
    Reputation: OldZaskar's Avatar
    Jul 2009
    Do you have a Dura-Ace budget or a Sora budget? ;-)
    Wahoo's new HeadWind looks pretty badass - fan speed tied to heart rate, 30 mph wind, and other cool features:
    Name:  Screen Shot 2018-10-02 at 4.44.53 PM.png
    Lasko's fan has 3 speeds
    Russian Troll Farmer
    Sep 2016
    If you REALLY sweat, get one of these:
    https://www.mscdirect.com/product/details/33869413
    "L'enfer, c'est les autres"
    The Slow One.
    Reputation: Alaska Mike's Avatar
    Sep 2008
    I've had good luck with the Lasko 4914, which is more or less like the 4905
    I like the ability to direct the air. Some people like the windstorm effect of a larger blade fan.
    Reputation: Srode's Avatar
    Aug 2012
    I have a portable AC blowing right on me in my trainer room. The exhaust blows out a spare dryer duct. Another small fan blows on my face / front.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Thanks!
    Any large pedestal fan with a remote works for me. Just pick one up at The Walmart; no need to overthink it
    Feb 2002
    One box fan on a stand directly in front. One on the floor off-center and angled toward the rider. One behind and off to the side tilted back to direct flow up the back. A desk fan on the reading stand directed at my head. Room kept at 65 or less (only used in cold weather). My wife sometimes opens the window to let cold air in if the room gets too warm.
    Sep 2009
    This is pretty much what I have. Okay, I think mine is only a 20" but otherwise similar.
    I usually run it on low with it about 15' away.
    Apr 2011
    Quote Originally Posted by DaveG View Post
    ^ This.
    flinty-eyed moderator
    Reputation: Coolhand's Avatar
    Jul 2002
    I just bought a big box fan from Lowes.
    Dr. Cox: Lady, people aren't chocolates. Do you know what they are mostly? Bastards. Bastard-coated bastards with bastard fillings. But I don't find them half as annoying as I find naive bubble-headed optimists who walk around vomiting sunshine.
    Reputation: Lombard's Avatar
    May 2014
    I like the Patton high velocity fans:
    Patton® PUF1410C-BM 14" High Velocity Fan
    They're small, move a lot of air and tilt up and down.
    Apr 2006
    The floor ones like that are better than the pedestal ones. Remember cold air sinks so these low fans force the cooler air up from the floor instead of just stirring up the hotter air.
    Sent from my SM-G950W using Tapatalk
    gazing from the shadows
    Jan 2003
    For fans, pay attention to the volume moved, CFM. One big one can move as much air as several small ones. I can see doing either, but one just seems a lot less hassle.
    May 2014
    Quote Originally Posted by QuiQuaeQuod View Post
    This is true. I have tried the 9" HV fans and they aren't very effective. 12" or more provides good volume on an HV fan.
    Big box fans take up a lot of space and usually can't be tilted.
    Nov 2013
    More things to be taken into consideration when buying a fan...
    • Noise: I found that cheap box fans are typically very noisy, which is annoying if you want to listen to music or a podcast while riding.
    • Remote: When I start riding in the basement, it's usually cool enough that I don't want the fan on. However, a few minutes into the ride I want the fan crankin'. W/o a remote, I can't adjust the speed of my floor fan w/o getting off the bike :-(
    As stated earlier, central air is probably the best solution. If it's 85 degrees in your house and your riding a training, a little blowing air isn't going to do a whole lot to cool you down (although it helps a little.)
    Jul 2007
    Seriously?!?
    wut?
    Reputation: Clipped_in's Avatar
    May 2011
    Quote Originally Posted by OldZaskar View Post
Name:	Screen Shot 2018-10-02 at 4.45.21 PM.jpg
    I use one of these. I have it elevated right in front of me and it works well.
    There I was...
    May 2014
    Quote Originally Posted by D&MsDad View Post
    Seriously?!?
    We're very serious here on RBR.
    Jul 2012
    I hate being on any trainer, but in those rare cases, I use the Lasko type fans, otherwise I get cool air on the road.
    Central AC alone is not enough for me.
  1. brain fry, cooling solutions? Neck wrap?
    By mandovoodoo in forum General Cycling Discussion
    Last Post: 01-28-2018, 05:29 AM
  2. Rollers/Spinning: Fan or no fan?
    By MisterMike in forum General Cycling Discussion
    Last Post: 12-16-2008, 05:13 PM
  3. Global Cooling is here
    By MikeBiker in forum Politics Only
    Last Post: 04-16-2008, 12:57 PM
  4. source for computer cooling fans?
    By iopturbo in forum The Lounge
    Last Post: 04-18-2007, 04:22 AM
  5. Cooling Vest?
    By wolfereeno in forum Pro Cycling - Tour de France
    Last Post: 06-29-2004, 11:11 AM
