Results 1 to 4 of 4
    Apr 2013
    Crank arms stripped... what now?
    I put my pedals on when I got the bike. They went on totally easy. Before anyone asks, it was the drive side, which is righty-tighty/lefty-loosey. I put them on correctly.
    I finally went clipless on my mountain bike and LOVED the SPD platform so I went to put a set on my road bike. As I was taking them off, it was clear something was wrong. I had to muscle them off and when I finally got them off the threads were stripped.
    What caused this? How do I fix it? Tap/die, helicoil, new crank?
    Not a rocket surgeon.
    Nov 2008
    Quote Originally Posted by Alias530 View Post
    Did you grease the threads when you installed them?
    Now for the fix. A tap wont work if the material is gone. There is an insert available. Its an insert though, not a helicoil. Its much better. That being said, i would replace the crank.
    Nov 2008
    Jan 2010
    Agreed that it is rarely worth doing. The kit is now $134. And unless OP is familiar with using a tap, then paying someone else to do it adds to the cost.
    Amazon.com: Var Crank Repair Kit For Pedal Thread: Sports & Outdoors
    And in case you were wondering, it's an unusual thread, not found much in the outside world. Helicoil don't make an insert in this threading.
    There's sometimes a buggy.
    One.
  1. Crank arms are too long?
    By brujenn in forum The Lounge
    Last Post: 10-02-2008, 08:49 AM
  2. mix n match crank arms?
    By zeytin in forum Components, Wrenching
    Last Post: 07-07-2007, 11:08 AM
  3. stripped bolt on crank
    By saccycling in forum Components, Wrenching
    Last Post: 10-10-2006, 03:14 AM
  4. Stripped crank threads!
    By AnyWeather in forum Components, Wrenching
    Last Post: 09-16-2006, 09:20 PM
  5. Cottered Crank Arms
    By kirrill in forum Retro-Classic
    Last Post: 06-02-2005, 06:34 AM
Sea Otter Classic
Contest
