Results 1 to 25 of 35
    Aug 2012
    Crank length Funtime
    https://youtu.be/bjrNuPjACnU
    So I'm trying to figure out what crank length to use on my next bike. After much research it seems there's no good answer. I'm sure I'll get the "have a pro fit you" , but everything I've read says that doesn't necessarily work either. Or really does anything?
    I'm on 170mm now. Sometimes I feel I'd like to go longer. Not really sure why. I think it dates back to bmx days when a short crank wasn't good. Of course there were no gears.
    So I'd like some opinions as I've read many different ones from pro riders. For instance Sagan used 172.5 and so does Quintana, despite their height and I presume leg differences. Many others don't fit the traditional mold and many ametuers are the same.
    Different articles mention different terrain as a factor as well.
    I'm 5"10" and ride flats and climbs about equally.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    To quote the great Lennard Zinn:
    Quote Originally Posted by Lennard Zinn
    I could go on for hours about how no decent crank length test has ever been done by anyone and why it is actually virtually impossible to do a definitive one. Rider adaptation to the crank over time is required for each crank length to ensure optimal performance, but, if adaptation is allowed, it then becomes impossible to ensure that the subjects have exactly the same fitness level for the testing of each crank length. And a proper scientific test is double-blind, so the subject doesn’t know what they are testing. But with crank length, the subjects can feel the difference, and the bike has to be set up differently and the cadences used have to be adjusted for the different crank lengths. So the test riders are tipped off, which can also skew the results and make it not stand up to scientific scrutiny.
    So a clearly-explained logical examination of crank length and its relation to rider size may actually be about as good as can be done. There simply will never be a definitive test that will tell riders exactly what crank length will make them fastest.
    Technical FAQ with Lennard Zinn: When it come to crankarm length - no easy answers | VeloNews.com
    This is one of those topics where the answer you hear tells you more about the fitter/builder/speaker than about the equipment "best" for you.
    Aug 2012
    Thanks. That's kind of what I've gathered as well. Despite the fact some seem confident shorter is better and one pro, who I can't reminder, uses 180mm and swears by them and he wasn't overly tall.
    I think I'm moving up. The question is 175 or 172.5
    Reputation: Lombard's Avatar
    May 2014
    You didn't say what size frame you ride, but if you're 5'10", I'll assume you ride a road size 56 or maybe a 54. That would be around a 17 mountain bike size.
    Most road bikes in this size category come with 172.5 crank arms. Some touring bikes in this same size category come with 170 due to a lower BB. Mountain and some hybrids come with 175.
    Personally, I think there are better ways of separating yourself from extra cash than to change the length of your crank arms. If you really feel compelled to get longer crank arms, I wouldn't go any longer than 172.5. Longer may work for the pros. For the rest of us, it would probably only result in knee problems due to a sharper bend on the upstroke.
    -- Warren Buffett
    Cycling Addict
    Nov 2013
    My generalized rule of thumb is the more you spin, the shorter you want your cranks to be. Longer crank arms allow you to apply more force to the pedals, which is generally done at lower RPMs. YMMV
    Life is short... enjoy the ride.
    Aug 2012
    This will be for my new bike which is a 54. My current is a Giant tcr advanced sl in a medium. That's the one with the 170's.
    I'm more of a masher not a spinner so that's why I'm thinking of moving up a little in length.
    Feb 2002
    This is a perfectly excellent summary! Crank length is totally personal and very adaptable, with the "spinners like shorter" being just about the only "fact" that holds up to scrutiny.
    Feb 2013
    Unless you are one of those guys can easily touch your butt with your heel I would be careful going with longer cranks. I am 6'5 with long legs and recently went down to 170's due to lack of range of motion from multiple surgeries.
    a real member's member
    Jul 2016
    there's a reason track cranks are 165.
    i like pedaling through turns too. so no longer than 172.5 for me.
    Dec 2005
    I have 172.5's on my road bike and 165's on my TT bike. The put the 165's on to move the seat up a touch and keep the hip angle open. When in position and going hard breathing is easier which is awesome! Due to the stoic pacing of ITT's the shorter length was easy to get used to. Honestly I don't recall having to get used to anything save maybe slightly different gearing.
    With that said the 165's on the road bike would be a total disaster (for me at least). Sprinting or continuous hard accelerations would be a difficult to generate power so the 172.5's are staying. I'd say stay with what you're used to. I've borrowed 170's and 175's from friends and once you adjust saddle height and setback the difference was not noticeable. Again maybe slight gearing selection but that's it.
    Reputation: nova_rider's Avatar
    Sep 2005
    If that's the case, and you find 170 is inadequate, then perhaps you should consider 175 instead of 172.5. You may not notice 5mm, but will definitely notice 1cm.
    Nov 2009
    too bad there isn't 5 million other crank length threads all over the internet to read up on.
    Sep 2005
    But there are plenty of non-contributing posters.
    Sent from my XT1575 using Tapatalk
    hfc
    hfc is online now
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    I have several bikes with crank lengths of 170 to 175 and while ere might be a difference in the ride quality/characteristics introduced by those differences between bikes, I'm not sure what they are and I couldn't tell you what the length of the crank is when I'm on the bike. Remember, 2.5 mm = 1/10 inch; not that much. Crank lengths < 180 and > 165 only matter to me for cornering clearance.
    Nov 2014
    I'm 5'11" and I run 165. More aero and can corner harder. May not be relevant to most.
    Nov 2014
    I'm not a spinner.
    More and more triathletes and time trialists are moving to shorter cranks because it allows you to get more aero without decreasing hip angle.
    That's the primary reason for the big push to shorter.
    That and relative measurements for shorter riders would mean many people riding 49 and 52s would be on 160s and the like.
    Nov 2014
    Quote Originally Posted by woodys737 View Post
    That makes no sense, not from a physiological perspective nor a physics perspective.
    Reputation: jason124's Avatar
    Jul 2006
    5'10 with a 31" inseam checking in. One bike came with 170 crank arms, my other 2 has 172.5. For me the 172.5 felt like I was slogging. I switched one of my 172.5's for 170 cranks and am much happier.
    Apr 2011
    Quote Originally Posted by jason124 View Post
    Are you a spinner or gear masher?
    Dec 2005
    Quote Originally Posted by pedalbiker View Post
    I have no coherent rebuttal. Just a short amount of time experience. I love them on the tt bike but, perhaps I just need to be in a higher gear on the road bike while sprinting etc...higher foot speed v. higher torque type thing.
    Feb 2002
    Since only a small fraction of cyclists are triathletes and time trialists, it is unlikely that's "the primary reason for the big push to shorter." There was a "everybody should go longer" thinking that came along with the MTB use of longer cranks, and now many have realized it didn't translate to the road that well.
    Not sure what your "relative measurement" comment is based on. Once again: there is no valid research showing the benefit of longer or shorter cranks associated with body measurements.
    Jul 2006
    Quote Originally Posted by bvber View Post
    I am a spinner.
    May 2014
    I am a spinner.
    Spinner on uphills, somewhere in between spinner and masher on flats.
    -- Warren Buffett
    May 2007
    Between the range of widely available cranks it doesn't matter what you run when you're an average size man. Pick the ones on sale.
    I find the really short cranks, like the modified ones, cobb or rotor really appealing. Using the 9.7% formula <5'4 riders should be on ~145mm cranks. A frame built around those proportional cranks (and proportional wheels) can have a ~240mm BB height, over an inch lower, with the same lean angle as a 56cm 700c bike. Sweet!
    Nov 2014
    Nah, pretty sure that the vast majority of posts I've read over the last few years about shorter crank arms center on that very reason. So yes, in terms of public perception and knowledge about the subject, it's a valid assertion.
    And relative meaning relative. A 5'2" rider will be on a significantly smaller bike than a 5'11" rider, yet said bikes likely come stock with 170 and 172.5mm cranks, respectively. It's completely disproportional.
    I don't know why you're going all fallacious about valid research. It's pretty cut and dry that crank length is a bike position issue, the same as stem length and top tube length and everything else.
    But if you want to argue about valid research concerning position, well, a wall would be a more interested audience.
  1. Replies: 15
    Last Post: 06-04-2014, 10:10 AM
  2. Road crank length vs MTB crank length
    By gthcarolina in forum Components, Wrenching
    Last Post: 04-05-2010, 03:42 AM
  3. 175 Crank Length VS 172.5 Length
    By saddle tramp in forum Components, Wrenching
    Last Post: 06-26-2008, 11:53 AM
  4. relation between top tube length vs. stem length
    By NoMSG in forum General Cycling Discussion
    Last Post: 03-20-2004, 05:29 PM
  5. Stem Length, Top Tube Length Ratio
    By purple puma in forum Cyclocross
    Last Post: 02-25-2004, 08:02 AM
