Results 1 to 5 of 5
    Jan 2010
    Determining bottom bracket spindle size
    Im switching out my octalink bottom bracket with a square taper to accommodate a new compact crank. I took off the cranks measure the spindle and it is only 94mm end to end. Is there a square taper equivalent? How do i determine proper spindle length otherwise? Any help appreciated!
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    You buy/spec the bottom bracket to fit the crankset. Retail cranks will state the intended chainline and desired taper and spindle length...generally you'll want JIS taper (unless Campag or something vintage)...but spindle length varies with brand and tier and spec of crank from year to year even within the same OEM.
    Said another way...the spindle length of an octalink crank has zero bearing on your sq-taper purchase.
    You might need a 102mm spindle or a 122mm spindle or anything in between, and it might need to be symmetric or asymmetric depending on the sq taper crank you buy.
    'brifter' is a lame word.
    Quote Originally Posted by sjmdic1973 View Post
    And you should be posting obviously component based questions in the proper forum section.
    I work for some bike racers
    and a bunch of skateboards
    Jan 2010
    Thanks for the info and admonishment jk!
    Whip me, beat me, make me write bad checks?
  1. Vintage Zeus Bottom Bracket Spindle
    By gmvgmvgmv in forum General Cycling Discussion
    Last Post: 02-10-2013, 06:09 PM
  2. Determining spindle length
    By shudson16 in forum Components, Wrenching
    Last Post: 02-23-2011, 01:49 PM
  3. Bottom bracket spindle, 111 or 115>
    By Guy A in forum Components, Wrenching
    Last Post: 10-26-2010, 11:16 AM
  4. need help determining correct wheel size?
    By Lipton in forum Wheels and Tires
    Last Post: 04-26-2006, 06:28 PM
  5. Miche bottom bracket spindle question
    By Auriaprottu in forum Fixed/Single Speed
    Last Post: 04-14-2005, 10:15 AM
