Page 2 of 8 FirstFirst 1234 ... LastLast
Results 26 to 50 of 177
  1. #26
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Coolhand View Post
    The disc hater thing is funny, and seemingly fact-proof.
    Yes, amusing how something like this is a religion for so many.
  2. #27
    The Slow One.
    Reputation: Alaska Mike's Avatar
    Sep 2008
    I'm not a disc hater, I'm just waiting for a real standard for road discs to emerge and solidify. That's the real obstacle for the pro ranks. QR or thru axle? 160mm vs 140mm? Eventually finding someone to perform neutral support is going to be near-impossible because of all of the standards they will have to carry on the cars.
    UCI needs to step up and say, "this is the standard wheel configuration" and be done with it. However, they won't, because the manufacturers can't agree.
    If I was a pro rider in this environment, I wouldn't want them either. Not because of the "safety issues", but because of very practical considerations related to serviceability in a race. I've had brake rub in a 'cross race when I was forced to use a wheel that wasn't aligned with my calipers. I finished, but my race was over. You can't quickly remedy that on the fly like you can with a caliper brake. Even hydraulic calipers only self-adjust so much. Then there's different rotor standards (2-piece, 1-piece, centerlock, 6-bolt) which can throw a monkey wrench in things.
    We're at a transition point, and to expect rapid change without clearly-defined standards is stupid. We'll get there, but the last real advancement was the derailleur, and that's been a few years ago from what I recall. The rest has been refinements (some larger than others), that didn't require nearly the same effort to support. Unlike cassette changes (9 to 10 to 11 speed), this affects both front and rear wheels.
    Make a standard, come up with an accurate and easy-to-use jig for rotor alignment, and move forward. Don't let the manufacturers dictate this, because they're looking to push product with forced obsolescence and their own ideas.
    That said, disc brakes are spinning death blades.
  3. #28
    Forever a Student
    Mar 2014
    Quote Originally Posted by Alaska Mike View Post
    Get out of here with your thinking and sense... not welcome! Sad!
    You're missing the point.
    use a torque wrench
  4. #29
    flinty-eyed moderator
    Reputation: Coolhand's Avatar
    Jul 2002
    On the UCI front, this has become a political issue for the Riders Association to establish a seat at the table as they can see sponsors want to use the latest and greatest stuff. They feel (quite rightly) that the UCI, ASO and the other promoters have ignored them and general rider safety at times and that this is one of the few issues with real money behind it. Some of the better stories in this area allude to this. Given how dangerous some of the euro road furniture has become, and how bad fan control is at certain races I get the motivation.
  5. #30
    Nov 2014
    I agree that there needs to be a standard adopted to make neutral support manageable, I'd imagine it will be thru axles, 160mm front, 140mm rear, and a measured offset for the rotors themselves. The are all supposed to be in the same place, but there is some variance. If the support wheels were all calibrated at Xmm out from center, you can be sure your team mechanics would set yours at the same.
    Tolerances have gotten better over the years, I can swap wheels between bikes now without any rubbing, in the past that wasn't the case.
    I don't see why that has any bearing on swapping wheels? All that matters is the rotor thickness is the @ the same and in the same position.
  6. #31
    Apr 2011
    Now I see how Marcel Kittel dominated Tour of Dubai this year. During the final sprint, others didn't want to get too close his disc brake equipped bike so they let him pull away!
  7. #32
    May 2014
    Let's just start by saying I have no strong opinions about rim vs. disc brakes. They both have their strengths and weaknesses.
    So let's move on to this argument of disc brakes being inherently dangerous because in motion, they act like a circular saw ready to slice off unsuspecting body parts. Really?? I am really perplexed by this argument unless it is solely for humor. The shoe is the only thing that may inadvertently come in contact with the disc and as you all saw in the video, it took quite awhile just to penetrate the shoe. In reality, is sticking a body part in the way of a spinning disc any more likely than sticking it in between spokes? And I think we can conclude that sticking your shoe in between spokes while the bike is in motion could be much more catastrophic than sticking your shoe in the way of the disc. Do we need to ban spokes too? Seriously, if you are that stupid, nothing in the world is going to save you.
  8. #33
    Reputation: Notvintage's Avatar
    May 2013
    Nairo Speaks the Truth. .
    Disc brakes on road bikes is pure marketing gimmick. . .
    Quintana: Disc brakes are heavier, less aero, and dangerous | Cyclingnews.com
  9. #34
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by Notvintage View Post
    One only need to look as far as the long history of severed limbs and the rampant trend of disc-brake based murders, in both MTB and CX, to see the wisdom of tiny little Nairo.
  10. #35
    Feb 2012
    Agreed.
    In before the old and frail 50+ year olds complain about their week hand strength riding their slow ass Ti bikes.
  11. #36
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    LMAO
    Firstly because they don't actually brake all that well.
    CLEARLY he has no clue what he's talking about.
    Secondly, it makes the bike less aerodynamic.
    Yet riders keep winning races on bikes with disc.
    Thirdly, they're much heavier.
    Again.... CLEARLY he has no clue what he's talking about. They're not "much" heavier. And with the UCI weight limit, it's irrelevant. Most bikes are under the limit and weight is added to make them compliant.
    Lastly, there's the danger they pose in a peloton of more than 100 riders.
    Myth that keeps getting busted.
  12. #37
    Forever a Student
    Mar 2014
    We'll see at the Giro.
    Been saying this for two years now.
    The Giro has the bad weather, it has the nasty descents, it has the three week long, every second counts nature, it has it all. The Giro is the perfect showcase for disc brakes and those riding discs will make their advantage very clear come May.
    use a torque wrench
  13. #38
    disc brakes sound like a great pairing with carbon clinchers
  14. #39
    Forever a Student
    Mar 2014
    Quote Originally Posted by Speed_Metal View Post
    You are very correct. For sure the strongest argument for them.
    use a torque wrench
  15. #40
    Reputation: BCSaltchucker's Avatar
    Jul 2011
    he speaks out of his butt .. again and again actually. He's way more respected speaking with his legs, finishing with a smile. Too often a silly whiner, like in the article, or when he complains about power meters, or spews excuses for his Tour performances, and complaining about the Tour de France organizers because it was too windy (stage 11)
    tlg is right on
  16. #41
    Jun 2008
    It's a fantasy to think the UCI will not come up with another excuse just prior to the Giro. As in the past, it will not matter how lame it is. Campy clearly has not got their sh!t together on discs and they own the UCI's decision making process.
  17. #42
    Forever a Student
    Mar 2014
    Quote Originally Posted by SwiftSolo View Post
    I have a thread just for you in the pro forum.
    use a torque wrench
  18. #43
    Reputation: velodog's Avatar
    Sep 2007
    According to this news report disc brakes look to be quite dangerous.
    Too old to ride plastic
  19. #44
    a real member's member
    Jul 2016
    ^ "cyclist looses control"?
  20. #45
    Jan 2005
    according to this news report disc brakes look to be quite dangerous.
Name:	disc brake 2.jpg
    lmfao
  21. #46
    Apr 2013
    Pro cyclists still against disc brkes in peleton
  22. #47
    Mar 2013
    hehe, nice one
  23. #48
    Jun 2014
    Agreed. He is a great rider who I wish would just stay quiet. His constant whining is a big let down and counter intuitive given his stoic expression on the bike.
    Quote Originally Posted by BCSaltchucker View Post
    tlg is right on
  24. #49
    Here's what I know: I don't care what some pro rider thinks or uses. When I have ridden bikes with them, I like them.
  25. #50
    Jun 2008
    In this case you're right. He rides for a team that is sponsored by campy--the one component manufacturer that has yet to figure out how to make and market disc brakes.
    He's likely paid well to hate disc brakes.
  1. Disc brake review...not debate
    By Opus51569 in forum Components, Wrenching
    Last Post: 02-22-2017, 09:42 AM
  2. Debate: Will tonight's GOP/FOX debate be softball?
    By troutmd in forum Politics Only
    Last Post: 11-15-2015, 09:07 AM
  3. The great disc debate
    By Rashadabd in forum Cyclocross
    Last Post: 11-10-2012, 02:25 PM
  4. POTUS debate #2 pre-debate thread: what strategies?
    By QuiQuaeQuod in forum Politics Only
    Last Post: 10-16-2012, 10:53 PM
  5. Replies: 0
    Last Post: 03-16-2012, 07:38 PM
