Results 1 to 25 of 35
    Jun 2011
    Estimates of power without a meter?
    So, I've been trying to figure out if I'm any good. I've been using this to estimate power at the moment, but it would be great if you all would tell me whether or not this amounts to anything other than an estimate with a 50% error bar.
    I started working on getting in pretty decent shape a couple months ago, starting at a weight of 197 pounds. I weigh 175 now, but I'm aiming for more like 150-155. I'm 5'9".
    I just use various times where I pay close attention to the wind based on how it feels both directions (often I will look at hourly weather data and even calculate the head wind using trigonometry), use Map My Ride for elevation.
    It's also unclear on aerodynamics because the stem on my bike is higher than on a bike one would prefer for racing.
    Reputation: Pirx's Avatar
    Aug 2009
    I looked at the site you linked to, and this looks like it gives you as good an estimate as possible with the limited amount of information available. Those numbers should be in the ballpark, and certainly better than within 50%. I would guess that chances are you're going to be within 10%. Whether or not that helps you figure out if you're "any good" is a very different question.
    Mar 2006
    It looks a little high to me. I ride with a power. I plugged my numbers in and at 200 watts it said I'd be going 17.3 mph. In my experience I'd be right around 20 mph at 200 watts. I'll have to go back and check my logs but I think I'd only be putting out 150 - 160 watts at 17ish mph.
    So I'd say it's within 25%.
    Reputation: DaveWC's Avatar
    Sep 2012
    It calculates too much power (as much as 25% too much) for my rides even when assuming zero wind.
    Oct 2009
    I wonder if this is how Strava does it. I do not have a power meter, but Strava figures something on my rides. I always wondered were they got those numbers from.
    Quote Originally Posted by dougclaysmith View Post
    they get your height, weight bike type straight from the government databases. From there on it's easy.
    Blows your hair back.
    Moderatus Puisne
    Reputation: Argentius's Avatar
    Aug 2004
    We all want to figure out if we are "any good," but, non-metered guesses at power, even with some of the cyclometers out there which have a "power" feature, but no strain gauges, are pretty bad.
    It's mostly just guessing. It will give you a ballpark in the right significant figure -- you know, if they say 300 watts, you're probably not doing 150 or 600 -- but not close enough to compare with other cyclists.
    OTOH, if you know you've reduced your time by, say, 30 seconds, on a given climb, you might be able to roughly figure out how much power INCREASE that represents.
    Quote Originally Posted by Argentius View Post
    or pick a steep slope >8%. ride next to one with a power meter and ask how many watts it reads and ask about the persons weight.
    Apr 2006
    I've been using Sportracks software with this plugin and my Garmin 800. A bit futzy to set up, but the results seem to be internally consistent and I can track over time.
    It doesn't account for drafting, through, which makes me look like I'm putting out more power on group rides than on solo rides.
    Master debator.
    Reputation: nOOky's Avatar
    Mar 2009
    Power is highly over-rated. Just look down at your speedo when you're going fast and use that as you average speed and go from there.
    Quote Originally Posted by nOOky View Post
    we really don't want people cycling in a speedo pair do we?
    Oct 2009
    Quote Originally Posted by den bakker View Post
    hmmm, I thought they got it when you loaded it in.
    no that would be the current regime just checking your honesty. if the numbers you provide are not true it is noted for further use. Who knows what else people would be dishonest about then.
    Master debator.
    Mar 2009
    Visit any triathlon...
    ok. _I_ don't want to.
    YMMV.
    Reputation: looigi's Avatar
    Nov 2010
    Why does it matter if you're any good? Ride often, far, hard and fast. Train systematically if you want. Ride with others. Race. It's all fun. The only time it really matters if you're "any good" is if you're a pro or aspiring to be one.
    ... 'cuz that's how I roll.
    Jun 2011
    It adds a layer to the enjoyment if you are a strong rider and riding a bike is a little bit more like riding a motorized vehicle due to sheer manpower.
    Jun 2011
    If power could be measured accurately and precisely, it wouldn't be overrated. It's the direct measurement of performance. Average speed is affected by elevation, wind, tire pressure, body weight, height, the friction in the bike's mechanisms, the height of your handlebars, the position you're riding in and probably more.
    The power your body exerts can be constant.
    Oh, and nice Kung Fu Hustle avatar.
    Reputation: nhluhr's Avatar
    Sep 2010
    Quote Originally Posted by Alkan View Post
    That's what racing is for.
    Jun 2011
    Quote Originally Posted by nhluhr View Post
    Yes, and that's my end goal. I'm just trying to gauge how I am right now. I'm not ready to enter competitive races just yet.
    Sep 2010
    Well, you might not be ready to win but there's no reason you can't go try a Cat5 road race and see how you do. Besides, if you like it, you'll wish you started sooner so you can have more upgrade credits under your belt.
    Master debator.
    Mar 2009
    Whoooosh
    Reputation: spade2you's Avatar
    May 2009
    Then keep training, have a training plan, and get a power meter when you can regardless of racing status.
    Feb 2002
    So, I've been trying to figure out if I'm any good. I've been using this to estimate power at the moment.
    That site gives notoriously high numbers. Go to analyticcycling.com for accurate estimates.
    Jul 2007
    Here is some benchmark:
    http://app.strava.com/762361261
    First 4 guys have power meters.
