Results 1 to 3 of 3
    Reputation: GDTRFB's Avatar
    Feb 2011
    Garmin 820 drops TBT, loses route during a ride
    Today I used my 820 with TBT on a 101 mile ride. At around mile 20, all I saw at the top of the screen was "End" or something similar. TBT disappeared. Soon after, the map page disappeared too. I had endless problems reloading the route and when I enabled correction to get me back, I didn't get any TBT prompts. When I did get back on the route, everything worked flawlessly.
    This isn't the first time something like this has happened. I don't use "Navigate to start". If I didn't have a Varia radar tail light, I'd cut my losses and buy a Wahoo.
    At least I'm enjoying the ride.
    Reputation: Srode's Avatar
    Aug 2012
    interesting, I've never had a problem with mine TBT, even over 200 miles in rural KS back roads - Did you do the recent upgrade to the firmware launched last week I think? Sounds like maybe the route file was corrupted some how when saved.
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Get me to In&Out
    Reputation: spookyload's Avatar
    I will tell you what they will tell you. Sync the unit to save your data, then do a hard reset. You can re-sync to put your settings back. I have had five different versions of Garmin, and each of them start to suffer from repeated firmware upgrades. The hard reset clears up the mess.
  1. Garmin 820 Maps
    By GDTRFB in forum General Cycling Discussion
    Last Post: 10-11-2016, 05:14 AM
  2. How do you follow a TCX route on Garmin Edge Explore 820?
    By Pierre in forum General Cycling Discussion
    Last Post: 09-04-2016, 03:59 AM
  3. New garmin head unit looks ideal for group rides. EDGE 820
    By pittcanna in forum General Cycling Discussion
    Last Post: 08-17-2016, 04:34 AM
  4. Garmin 820
    By Trek_5200 in forum Components, Wrenching
    Last Post: 07-13-2016, 07:18 AM
  5. Garmin 820
    By ozzybmx in forum General Cycling Discussion
    Last Post: 07-12-2016, 06:17 PM
