Results 1 to 21 of 21
    Jan 2018
    Gears shift ok on stand but not on road
    I have a Shimano Altus 9 speed rear. With the bike inverted I have set the limits and indexing and it works fine. When on the road it sometimes misses a cog going up the cassette and also down. I have replace the inner and outer cables but no change. With the "B" screw fully retracted there still seems to be about 15mm gap between the largest cog and the jockey wheel. Any advice would be appreciated. Thanks Keith
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Quote Originally Posted by keithjohn View Post
    https://www.parktool.com/blog/repair...icle-section-5
    Sep 2015
    Presuming mtb or hybrid bike....age/mileage of groupset?...in particular age/mileage of chain, cassette and chainrings? Chains stretch over time...faster under higher load and dirty conditions and therefore don't engage with cassette as well if too worn.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    I have a Shimano Altus 9 speed rear. With the bike inverted ......
    You don't ride your bike inverted so it goes without saying that testing it inverted may produce different results. The RD springs are now working against the gravity of their own weight. Plus the drivetrain isn't under nearly the same tension as when on the road.
    Is it always the same cog getting missed or random?
    Jan 2010
    I'm having trouble reconciling the title "on stand" with it being inverted.
    Unless it's a stand that holds the bike upside down?
    There's sometimes a buggy.
    One.
    Sep 2015
    I will take some exception to what bikerjulio said OP. Will share my personal opinion of building bikes for over 4 decades...don't believe bj is young either FWIW...lol.
    Having the bike inverted versus upright on the stand should be no different in derailleur adjustment. Force of gravity is negligible relative to force of rotory derailleur spring under cable tension.
    Second point about about shifting under load. I hope you know again bj's advice should be irrelevant, because the bike shouldn't be shifted under load. So only relevant if you are shifting the bike with significant pedal pressure.
    Historically adjusting a bike to index properly on a stand, this should replicate real world ride shift quality. One thing you can look at over and above chain stretch and cassette condition is...rear wheel bearing preload. Under load if your wheel is laterally moving over, you will lose indexing adjustment.
    Other factor is...bending the frame under load. If you are a Clyde, this can be a factor versus adjusting the bike on a stand unloaded. An elastically displaced frame aka bending...this will change cable tension...and btw can cause a bike to phantom shift out of the saddle....but a different dynamic than you describe.
    Some further perspective to consider and if you want to respond, I will try to help.
    Jan 2010
    Comprehension fail yet again.
    I said nothing negative, just asked a question.
    Anyway it's good to know that there's an expert on the case.
    One.
    Oct 2013
    What kind of shifters are you using?
    BANNED
    Sep 2015
    Quote Originally Posted by bikerjulio View Post
    Your question was irrelevant. You just did it again, wasting bandwidth about my comprehension. It is you bj who failed to comprehend. A bike adjusted while inverted versus adjusted on the stand makes NO DIFFERENCE. Your comment about gravity mattering is BOGUS.
    Sorry to be blunt. You should have understood the first time I corrected you.
    Sep 2015
    You can ask but if correct indexing is achieved with the bike on the stand or inverted on the ground, type of shifters shouldn't be relevant. Shifter pull ratio has to be correct if proper indexing is achieved in any state.
    Reputation: Lombard's Avatar
    May 2014
    15mm, are you sure? That is quite a gap.
    When you say "outer cables", can I assume you mean housings?
    -- Warren Buffett
    Jan 2018
    Thanks for all your comments. The bike is my son's and was purchased in the UK Voodoo Marasa hybrid. It is about 18 months old covering about 20 miles per 5 day week so guess it has covered about 8,000 miles. The chainwheels and chain are original, the cassette is recent due to rear wheel being stolen but was functioning ok. Yes by outer cables I mean housings.
    I have compared with my own bike the lateral movement on the derailleur mounting bolt and there is more movement on my sons. I am not sure how much movement is tolerable. The "sticking" does occur on the same cogs each time which is toward the smaller range. Hope some of this helps. Thanks Keith
    May 2014
    Aha! New cassette, old chain. Over a period of 8000 miles, a chain and cassette effectively "marry each other" due to wear. As the chain rollers wear, the distance between each link becomes longer and they grind away material in the cassette. So you now have a "mismatched pair". If you continue this way, besides having lousy shifting, you will prematurely wear out your new cassette.
    Replace the chain!
    -- Warren Buffett
    Oct 2013
    You said it was over shifting, was that your observation? Or just a general comment like GaGa would say "There's something funny going on down there"?
    Sounds like it was actually skipping? Completely different thing. A worn chain will not make it overshift.
    BANNED
    tka
    tka is offline
    Jun 2014
    Replace the chain!
    This. Replace the chain and then see how it shifts.
    All the rest is, as one poster said, wasted bandwidth.
    .je
    .je is offline
    Old man yells at cloud
    Aug 2012
    To my ears, your B-screw is putting your RD too far from your cogs, and that might be OK at the big end, but at the small end, chain positioning is harder to control so shifting suffers, so you'll at the very first have to take care of that.
    It can also be the condition that your cable tension is very high for the springs. Your adjustment could be wrong, or your derailleurs might have a lot of dust and dirt jamming them, so the springs aren't able to pull all the way down - but you were able to compensate for that on the high end, by cranking up the tension. Maybe this is your situation, it has been mine at some point in the past. I just cleaned it with WD-40 and it was smooth afterward.
    I've also had the situation where the small gears all skipped, and replaced the chain, and even the cassette, with new parts, and it still did the same thing. After I replaced the cable outers (well actually I just oiled them), it didn't do that anymore. It wasn't the chain, at least for me, that time. It sounds that you've done that. So, my suggestions of free things are those.
    I've also had this situation occur when the gear cable needed replacing because it was coming apart where it attaches to the head. At least this is only $2 or so.
    So that's all close to free, and you can do them this afternoon, as normal ongoing easy-to-forget maintenance. If it doesn't do it after that, replace the chain and then see how it shifts. I bet you weren't expecting all the preceding firefight with your small trivial problem, were you??
    Russian Troll Farmer
    Sep 2016
    Also, inverting your bike for repairs is something only teenagers do.
    "L'enfer, c'est les autres"
    Reputation: velodog's Avatar
    Sep 2007
    It's his sons bike, so a teenager may have inverted it.
    But that don't matter because if he doesn't have a stand he does what works for him.
    Too old to ride plastic
    Nov 2009
    could be so many easy things.
    Jan 2018
    Thanks for that. I had the same feeling regarding the B-screw but it is fully retracted and still leaving a large gap. I have cleaned everything with WD40.
    May 2014
    Quote Originally Posted by factory feel View Post
    How profound.
    -- Warren Buffett
  1. Di2 won't shift to top gears sometimes
    By aabbas in forum Components, Wrenching
    Last Post: 01-13-2017, 05:21 AM
  2. Lost 1/2 my gears! (slack in my shift wire)
    By toasted in forum Components, Wrenching
    Last Post: 06-23-2012, 06:37 AM
  3. Convert Campy Power Shift to Ultra Shift?
    By JLane in forum Components, Wrenching
    Last Post: 01-16-2012, 07:25 AM
  4. FD that works on the stand but not on the road
    By Fishbike in forum Components, Wrenching
    Last Post: 09-11-2010, 05:28 AM
  5. How do you shift gears? Looking for advice
    By BaileyHV in forum Beginner's Corner
    Last Post: 04-06-2009, 07:29 AM
