Results 1 to 20 of 20
    Oct 2018
    Glue for carbon ???
    Seatpost carbon slippage problem, NEED HELP!
    Carbon frame on Carbon post, I tried to clean it up nice with an anti-greaser and then lathered some anti-slip goo on it that I bought special for this reason, BUT ITS STILL SLIPPING!
    AM I TOO FAT? Cant fix that without riding the bike more!
    So I'm resigned just to epoxy it together and forget about it. I'm very happy with my easily replaceable generic Shimano pedals and Sella Italia seat, and know exactly what height the seat post should be, I'm looking to WELD THIS PUPPY IN PLACE.
    What do I use? How do I do it?
    Also, screw BMC for not responding to my cries for help!
    Thank you.
    Oct 2013
    Stainless Steel Clamp. Done!
    BANNED
    Reputation: Akirasho's Avatar
    Darling of The Lounge
    Reputation: Retro Grouch's Avatar
    Apr 2002
    Before you go "completely nuclear" and epoxy your post in place, stop by the store and go to the section where they keep the travel-sized toiletries. Pick up a small spray can of ladies hairspray. After cleaning the outside of your carbon seat post and inside of your seat tube with alcohol, let it dry and spray a good amount on to seat post and insert it. Tighten the clamp down and let it sit a few hours.
    This worked for me on both my carbon frames. In fact, I had to remove the seat post to put one of my bikes in a storage case. I needed to enlist the help of my wife for a game of tug-o-war. She held the frame, while I had to muscle the seat post out.
    Quote Originally Posted by retro grouch View Post
    i needed to enlist the help of my wife for a game of tug-o-war. I held the frame, while she had to muscle the seat post out.
    fify...
    Oct 2018
    +1 +1 +1
    Dec 2005
    Are you sure you have the right diameter seat post? You should not have to come close to using epoxy. If carbon compound and maybe turning the seat clamp 180 degrees and torqued to specs doesn't hold it in place I think something else is happening.
    .je
    .je is offline
    Lizard Person
    Aug 2012
    Drill a hole through the seat tube and post, pin it with a bolt and nut.
    Quote Originally Posted by Akirasho View Post
    Well you can do that too. I've used this and it works very well.
    The hairspray idea has worked for me too I'd suggest that first.
    'brifter' is a lame word.
    If it's a BMC the chances of the frame having a round post are very slim.
    I work for some bike racers
    and a bunch of skateboards
    Dec 2005
    True. Probably no conventional clamp either but, until the op clues us in
    pmf
    pmf is offline
    Gluing it in seems really drastic and irreversible. Try roughing the finish of the seat post up. I had the same problem with a carbon Colnago and it worked for me. This was over a decade ago, I'm still riding the bike, and no, the post never assploded on me.
    gazing from the shadows
    Jan 2003
    To expand: a stainless steel hose clamp, on the post so that it is right above the clamp collar. Can't slide down that way. It can still twist though.
    Put a bit of tape around the post to protect it first. Tape MIGHT be enough to keep from sliding without the clamp, but probably it would just slow it down.
    Oct 2013
    Quote Originally Posted by QuiQuaeQuod View Post
    CX sayes it isn't round, so I'm still in the mix!
    BANNED
    Pooped a refrigerator.
    Reputation: SauronHimself's Avatar
    Nov 2012
    If you have a large enough gap, see if you can slide in a thin piece of rubber gasket.
    Ghurarmu shirkush’ agh azgushu. Zant ya apakurizak. Gűl-n’ anakhizak.
    Oct 2018
    One guy has come close with some park tool compound, which looks very similar to the crap I've already tried.
    So I'll just buy some epoxy at Home Depot and see how it goes.
    Jan 2003
    Quote Originally Posted by fatnsassy View Post
    Do what you want, but trying epoxy before a hose clamp seems ill advised.
    As a general rule, you should try things that are easy to remove FIRST, and go with the epoxy as a last resort. What if your seatpost cracks or breaks down the line? Have you thought of how you would replace one that had been glued in?
    You might still wanna play the "fat" card before you remove what could be considered a critical option (while most of us prolly keep the same height for years, age or injury might call for a change plus it could be a deal breaker if U ever wanted to sell the frame).
    PONR
    Feb 2005
    If it is a round seatpost, you could always try a double bolt clamp.
    https://www.ebay.com/p/Java-FEROCE-F...5862888&chn=ps
    Reputation: BlazingPedals's Avatar
    Apr 2013
    Along the lines of Retro Grouch's, I once used Scotch77 spray adhesive on a problem carbon/carbon clamp area. It was removable, but only after applying a heat gun and lots of elbow grease.
    If there's enough room, you could also put a piece of self-stick 600-grit sandpaper on the post,, then clamp it down. Lots of options to try before the epoxy solution.
    May 2012
    Measure the insertion depth and put a piece of tape around the seatpost as a reference point. Mix up a batch of JB Weld and apply a very thin coat with a chip brush below the tape to increase the diameter. Let cure completely and sand/add additional coats as needed to get a better fit.
  1. Replies: 31
    Last Post: 03-12-2016, 07:03 PM
  2. Removing glue from carbon rims
    By cx&xc in forum Cyclocross
    Last Post: 11-21-2007, 10:18 AM
  3. Why not glue in a star nut for a carbon steerer?
    By Tahoe Gator in forum General Cycling Discussion
    Last Post: 07-16-2007, 07:08 AM
  4. Glue for carbon?
    By metricEee in forum Components, Wrenching
    Last Post: 04-19-2007, 03:03 PM
  5. 4 layers of glue on carbon tubular rims WTF?
    By fringale37 in forum Components, Wrenching
    Last Post: 01-21-2006, 05:29 AM
