I am looking to reduce my stable of bikes from 4 to 3. I will keep my hardtail 29er and my Trek Madone for road racing and fast group rides. Therefore, I'm looking to replace an old cx bike, which I use for, in the order of importance:
1. indoor training/zwifting, both on the rollers and trainer.
2. road riding when the weather isn't ideal. I ride the cx outdoors pretty much exclusively from November-March because of the salt in MN. I never ride the madone if there is rain forecasted either.
3. Gravel races. I do some long 4-7 hour gravel races every year with a lot of climbing and some pretty steep hills.
4. Slow road rides, like B paced rides and rides with my wife. The madone doesn't like to go slow.
5. Cyclocross races. I've never done one, but they look fun and I might jump in this fall. Not good for my motor though.
Budget is about $1,100, and I need a 61cm or above, since my inseam is 37 freaking inches. Would prefer to buy used for better value.
I think I'm looking for aluminum, because carbon is too expensive and doesn't mesh well with hours on a trainer, and steel melts in the salty MN roads and under my sweat from said indoor trainer. I would like something as light as possible. Clearance for at least 35-38mm tires is a must.
I think something like the bmc gf02 disc would work, but I don't know what else to look for. I found a 2015 61cm gf02 disc 105 used for $1,100. I also have a good friend who is also 6"4, and has ninja status on Trek U. The crockett 5 disk is therefore in my price range, or I could get a crockett frame and transfer the parts from my old cx to it.
A Crockett doesn't have a lot of clearance for a gravel bike in my opinion, but it depends on what your gravel looks like I suppose. To me a gravel bike needs to be capable of 40mm tires with clearance for mud build up.
Apologies for resurrecting an old thread, but that hasn't been the case with me. Just putting someone else's experience out there just in case anyone is looking at the Crockett for a gravel bike. I say go for it. I have mine set up with 45mm WTB Riddlers on WCS i19 rims...no problem. This bike has more clearance than most CX bikes...eyelets for fenders too. I think it makes a great frame for gravel. The only area where the clearance is tight with the 45mm Riddler is just inside the chain ring dimple, where the inside of the stay dimples inward a bit too. I had about 1.5-2 mm there, but I re-dished the wheel slightly and now I have about 4mm. A little tight still for a muddy CX race for sure, but for me its a non-issue for gravel/single track/rain/snow/shine/etc. Re-dishing isn't typically the best approach on a disk wheel for me, its not a problem at all. Therefore, 40mm tires would have PLENTY of clearance without re-dishing. Some tires measure wider than stated compared to others of course so your experience may vary. Mine is a 2015 Crockett 7, so perhaps other Crockett models have tighter clearance.
Other than that little area, there is LOADS of clearance in the rear triangle. Tons of clearance with the fork too...you could run a 1.95 mtb tire in there if you didn't have the space issue between top of the tire hitting the underside of the fork crown... Great candidate for 650B with a REALLY fat tire. In fact, I just bought some 650B wheels. Can't wait to try them with some 47mm WTB Horizons
Yeah, I would agree, but my priorities are such that I can't have a dedicated gravel bike, and I mostly ride my cross bike on the road. I've only ridden gravel on 35mm, at 45-55 psi, because a 38mm won't fit in the rear of my current cross bike, and that's been fine for me. Greater clearance is certainly good, but MN gravel isn't too bad- we don't have super chunky fire roads, and even if we did, and I did a ride on them, I'd use my 29er. Not sure I'd even use a 40mm for gravel here if I had the choice; some guys do, but they're usually slower than me
What about the specialized Diverge? I guess I'm looking for a reasonably fast endurance road bike that can fit 35mm tires.
I have the Diverge DSW with Tiagra, I run 32s with no problem, plenty of room for 35s. It retails for ~$1400, so you should definitely be able to hit your price point.
Rear wheel is a standard(?) QR, so you should be ok with the trainer as well.
I ride my Niner on the road all the time in bad weather, including snow during the winter, and on the trainer - so it's not a dedicated gravel bike but it is certainly a very capable serious gravel bike when I want it to be. It doesn't hurt having extra clearance, and it's got good endurance geometry. If you really get bit by the gravel bug you may end up riding outside MN in gravel where you want bigger tires. Not trying to talk you into big clearance bikes, just pointing out its not limiting and may open options you want later.
i vote crockett. it can fit 40mm tires no problem. i currently have mine set up 1x11 with a 40t up front and 11-36 in the rear. gevenalle shifters, wtb cxi19/dt350 wheels. super fun bike, quicker than youd expect. i use it basically as you intend to you use, it goes on my trainer, it goes outside when salt is on the road, i train on it, do tempo rides on it, hob curbs, ride down stairs. its really a sweet bike. trek just released the 2018 crockett yesterday so you can probably get a deal on a 2017 if you poke around
How stiff is the crockett around the bb area compared to a 700 series carbon frame? Does the fork transmit every vibration to your hands or is it more forgiving?
I'm 6'4" and use a 64cm frame emonda sl6 road. I'm also leggy like you and have about the same inseam. I picked up a trek crossrip 3. It's about $2k new, but it's aluminum, disk brakes, 105 components, and I've put 40mm tires on it with room to spare. It's a 61cm (largest size) and my fitter was able to give me the same fit on the crossrip as I have on the emonda. I haven't had much time on it yet as I bought it late season last year, though.
Ended up scoring a 2016 bmc GF02 disc 105 off ebay for 707 bucks including shipping. It's a 61cm, and the geo looks like it should fit. This one has hydraulic disks too. Pretty excited for it to come.
I have the Motobecane Omni Strada Comp from Bikes Direct for $1K. I've rode 3 rides with it (about 100 miles) and it's been great. The Motobecane has 105 components, aluminum frame and hydraulic disc brakes. After I received it from Fedex, I took it to the LBS (still in the box) to have it assembled and fine tuned. My Moto is a 55cm, but they are available in 61cm. Also.... it has clearance for 45c tires, but I really like the 40c WTB tires that came with it.
For 700 bucks, this was a steal. Full 105 group with TRP hyrd brakes, less than 400 miles, and it even fits. It's pretty responsive and not the cushiest bike ever, and there is definitely not going to be clearance for 40 or even 38mm knobbies, but for my needs this should be great.
I'm the OP. I've actually ridden this BD bike though, as a friend has it. It's super heavy, and super flexy, but for long endurance gravel rides and touring (what he uses it for) it works well. I'd still rather have my BMC gran fondo disc 105 though, as it's compliant on the rear end, about 5 pounds lighter than his motobecane, and much, much stiffer when standing up and climbing. I couldn't buy steel for this bike because of my excess zwift usage November-March. Steel doesn't like sweat.
BTW, the BMC GF 02 disc easily fits 38mm knobbies. I've done a bunch of riding in the chequemegon national forest with 38mm front and rear and it's pretty cushy. I've even done singletrack, though no 'cross races yet.
That BMC is really great bike, and you did get a steal. I would love to find the same bike.
I have the rim brake version, but it's relegated to trainer duty due to lack of tire clearance for gravel ( I have a Roadmachine 01 for tarmac surfaces).
BMC engineers a great bike, even in aluminum. Compliant in the right places, stiff where it needs to be.
I really wish they were still making the Gran Fondo. Still one of my all time favorite bikes.
Sent from my Pixel using Tapatalk
Related Threads
Road Bike, Cycling Forums
5.4M posts
205.1K members
Since 1990
