Results 1 to 16 of 16
Thread: Helmet Skins ??
    Oct 2009
    Helmet Skins ??
    Hi all,
    Watching the wet Giro d'Italia stage today, I'm sure I saw a BMC rider wearing a giro ionos helmet with a clear polycarbonate skin/cover. Is there somewhere where these can be acquired? Or is there an aftermarket company producing them? I'd be keen to use one on wet, cold and windy days.....
    Reputation: looigi's Avatar
    Nov 2010
    Quote Originally Posted by HarryV View Post
    Hi all,
    IDK about the clear skin. WRT the Giro, UCI has outlawed removable skins that "modify" helmets, but helmets made with them are legal. I use a water/windproof lycra cover, which is just as effective, IMO, and stashable in a pocket. Some BMC riders are wearing Giro Air Attack helmets.
    ... 'cuz that's how I roll.
    Reputation: JCavilia's Avatar
    Sep 2005
    I didn't see it, but was it flexible? if so, it wasn't polycarbonate, which is a very tough rigid plastic (Lexan is a common brand name).
    If all you want is somethinbg to block the cold air and rain from going in the vents, a cheap shower cap works quite well.
    Eppur si muove.
    Oct 2009
    Re: Helmet Skins ??
    Quote Originally Posted by looigi View Post
    It was a quick glance, but it appeared to be an ionos covered in some transparent material. It appeared to be rigid given it's transparency... But I coukdve been seeing things as well.
    Thanks for the shower cap idea! Very wet down here this week, I could've used a shower cap on my training rides, or even some scuba gear for that matter!
    #dreadingwinter!
    Apr 2011
    Been brought up before. The possible future in road helmets.
    Reputation: Bill2's Avatar
    Oct 2007
    +1 on shower caps- saved me on many a cold wet commute
    Nov 2010
    I carry a hotel polyethylene shower cap for unexpected weather. They tend to flap and make quite a bit of noise. IMO, they're OK for "emergencies" but not something I'd use full time in cool/cold/inclement weather.
    Feb 2002
    I carry a hotel polyethylene shower cap.
    No, you don't. You carry a hotel PVC shower cap. Polyethylene is what milk jugs are made of - a rigid or semi-rigid plastic. Polyvinylchloride is what things like clear shower curtains, shower caps, etc. are made of. While PVC is rigid at lower temperatures, it's formulated with a bunch of plasticizers to keep it flexible.
    Reputation: DocRogers's Avatar
    Feb 2006
    Helmet Skins ??
    I used to put a skin on my helmet, but now I'm married.
    Reputation: mann2's Avatar
    Oct 2012
    not sure about Giro, but Lazer sells 'em skins.... for their helmets of course.
    check my review page below!
    www.roadiemanila.com
    Oct 2009
    Helmet Skins ??
    Yeah I wasn't aware giro producing them so I though it must've been an aftermarket production... Good opportunity for someone who can heat plastic and use vacuum moulds! :-)
    Dec 2012
    I use a welders hat or cycling cap under my helmet?
    I generate enough heat and the cap acts like a scuba wet suite, wet yet warm and no wind.
    Oct 2009
    Helmet Skins ??
    Quote Originally Posted by Bevo View Post
    I understand there's lots of alternatives to the aero covers and ventless helmets, personally I use a skully and that does the job nicely... I was just surprised to see what appeared to be a transparent hard skin over a giro ionos, which obviously isn't a marketed giro accessory. I might try wrapping my helmet in glad-wrap this winter :-)
    May 2013
    Ya I like your post. you talk about such informatics news here i also want to know.
    I also use giro ionos helmet some times.I feel comfortable by wearing it.
    Nov 2010
    Pretty sure it's polyethylene, not PVC. Thick, both are rigid (think PVC water pipe). Polyethylene film is quite flexible and somewhat stretchy, but doesn't cling like PVC food wrap film can. The shower cap plastic is is slightly milky, not transparent like PVC food wrap (Saran wrap). Either way, it doesn't matter much.
    Here are some polyethylene shower caps: https://www.google.com/search?q=poly...=1547&bih=1017
    Here are examples of polyethylene film: https://www.google.com/search?q=poly...=1547&bih=1017
    Feb 2002
    You are confusing the highly plasticized food wrap with the often translucent formulations used in shower curtains, shower caps, old-style cycling rain capes, etc. - think of the old portable hair dryers women used to use - PVC. Flexible PE is like garbage bags - it stretches once but it doesn't rebound. PVC water pipe is rigid because it is not plasticized, not because it is thick. Milk jugs are rigid because of the grade of PE (molecular weight and degree of long chain branching).
  1. Compression: Skins vs. 2XU?
    By RyanM in forum General Cycling Discussion
    Last Post: 06-26-2011, 02:23 PM
  2. Lizard Skins anyone?
    By mikagsd in forum Components, Wrenching
    Last Post: 06-17-2011, 10:03 PM
  3. Skins and Knicks
    By effekt in forum General Cycling Discussion
    Last Post: 01-13-2009, 04:12 AM
  4. Do you guys get SKINS over your way?
    By Cycle_Spice in forum General Cycling Discussion
    Last Post: 07-18-2006, 06:50 PM
Sea Otter Classic
Contest
