Results 1 to 7 of 7
    Converted Marathon Runner
    Reputation: 10kman's Avatar
    Nov 2002
    How does Specialized measure their frames?
    Does anyone know how Specialized measures their frames, specifically the top tube? They have everything else except that one measurement well-documented on their site.
    Center to center? Center to top? All it says is "measured horizontally".......
    TIA,
    10k
    PS - for an S-works E5
    Mar 2004
    I think they use a tape measure.
    Quote Originally Posted by 10kman
    Sorry, couldn't resist. Figured that if I couldn't be helpful, I could at least be annoying.
    Old and Fixed, Moderator
    Jan 2002
    TIA,
    10k
    I believe they are measure with a virtual top tube. A lot of compact frame are measured that way. Draw a horizontal line from the top of the headtube back to where the seat post would intersect. In other words, a "52cm" frame would have around a 45-46cm actual seat tube.
    Dave Hickey/ Fort Worth
    horizontal is horizontal...
    Just like any horizontal TT frame, the measurement of TT length is always from the center of the head tube/top tube junction, horizontally to the point where the seat tube and TT would intersect IF it was horizontal, like a standard frame.
    Some other brands call this a "virtual" TT length. Horizontal is the better term.
    Feb 2002
    Center to center, sort of
    Top tubes are measured ctc, unlike the various goofy concepts on seat tubes. The caveat here is with sloping top tubes, where some measure ctc on a horizontal line, and others (only a very few) measure the actual tube, ctc. You can be "virtually" certain that Specialized measures ctc on a horizontal line. Look for a geometry chart on their web site or catalog, where they will often have a frame graphic showing their measurement points.
    Reputation: Scot_Gore's Avatar
    Jan 2002
    Right off the E5 Geometry Chart
    for an S-works E5
    Size 50 52 54 55 56 57 58 60 62
    Stand Over Height 706 729 749 760 772 784 794 811 827
    Seat Tube Length (center-to-top) 430 480 500 510 520 530 540 560 580
    Top Tube Length (measured horizontally) 525 537 548 557 565 573 582 591 605
    It's not on the E5 chart but on others they have this note
    * TT is measured horizontally from center of HT to center of ST
    HTH
    Scot
    Scot Gore, Minneapolis
    Nov 2002
    Follow up.....
    FWIW, I followed up on this, and got 2 final words....
    Measured Center to Center, along a "virtual horizontal", much like the post above states.
    I wish they'd standardize this stuff, I mean seriously, why does everything have to involve more research than necessary??
    Thanks all for the help, and I hope this helps others in the future.
    10k
  1. Replies: 0
    Last Post: 08-15-2004, 09:52 AM
  2. Gunnar Rodie Vs Trek 2200 Vs Specialized Roubaix 105
    By chandne in forum General Cycling Discussion
    Last Post: 07-27-2004, 08:42 AM
  3. Giant OCR1 vs. Specialized Allez Elite
    By KyloWms in forum Bikes, Frames and Forks
    Last Post: 07-01-2004, 10:39 AM
  4. Why the movement toward full carbon and away from carb/alu frames? (Fondriest?)
    By dawgcatching in forum General Cycling Discussion
    Last Post: 06-28-2004, 09:56 AM
  5. Scattante or Leader - question of the low budget frames
    By bscruz in forum Bikes, Frames and Forks
    Last Post: 04-23-2004, 02:17 PM
