How important is a hot weather base layer?
I mean, we spend this money on jerseys that are made of a special fabric that is ment to keep you cool and wick sweat. I can think of a base layer keeping your jersey drier from sweat making it more breathable, is that why?
thanks!
Bikes:
Felt F95 2011: my main road ride
Jamis Dragon 29 Sport 2011: my main MTB(Steel is Real)
Raleigh Record 1976: Single speed in the making
Possible Fuji cross frame I might get... and paint...
I do not like wearing any sort of base layer during the warm weather months...not many up here.
They are a god send for the rest of the riding seasons.
Descender
Never wear a base layer in warm weather - too hot.
Wear them at other times of the year.
I wear a base layer during the entire riding season.
Base layer in the summer is not going to help keep you cool, but some wear it to save skin in the event of a crash while racing. The idea is for the two layers to slide against each other.
No base layer for me in the summer. You want to get rid of body heat as fast as possible.
For winter I've got tons of different base layers as the temp creeps down.
I think a lot of the supposed performance benefit of base layers in the heat vanishes if you ride in high humidity. I live in Bermuda and the rel humidity rarely drops below 80% in the summer. Even now with the temp around 75F, I am dripping at the end of a ride. There is no way that a base layer would do anything other than heat me up. It's all about getting airflow over the skin, so for me it's sleeveless jerseys with no base during the height of the summer.
In places with low humidity, I could see the structure of a base layer getting the chance to do what it was designed for since your sweat would evaporate so much quicker. But here, the base layer so quickly gets saturated with sweat that it just becomes a sponge.
I ride with an under armour compression base layer top all the time. It definitely keeps me cool and it is comfortable.
I can't imagine why I'd want more insulation in the heat.
I wear a base layer in heat up till the 80's or so. Then it really depends on the humidity. If it's dry heat I'll still wear a base.
I find that thin skin tight base layers really help cool me off.. Plus I wear full length sleeves for added sun protection.. I'll take a little more heat and save my skin any day.
Old, slow, and fat.
I'll wear one till it gets into the mid-90s with that much humidity.
Until then, I'm wearing something under my bibs.
M
I've moved back to NoVA. PLEASE change the weather!
I don't wear a base layer in the warmer months. Even with the low humidity here in Colorado Springs it would be too warm for me. Sleeveless jerseys work best for me.
I live in South Carolina where we get heat and humidity (high today will be in mid 90's). I got a very sweet deal on a Giordana summer sleeveless base layer so I picked one up and for the first time I have used one in the heat. I was VERY skeptical at first. It seems so counter intuitive that ANOTHER layer in the heat could actually cool you. Than I talked to an army buddy of mine who served in Iraq (120 degreees in summer). He said they all wear summer base layers there. Army issue. He was adamant that it helped in the heat. So I gave it a try. My original plan was to use it only this spring and then relegate it to the drawer once temps approached the upper 80's. Well, first of all I found it very comfortable. It is ultra light, and fits tight and is soft on the skin (this really sounds like I'm getting in touch with my feminine side, lol!). At any-rate, because of this I have just kept it on. Rode the other day with it when it was in the low 90's and felt great. I think even in the humidity it helps wick sweat and more importantly for me it keeps my sleeveless jersey from clinging to me. So far I will say that I am a believer.
I'll wear a base layer for long climbs in the mountains (temps in 80's). Not much warmer but it sure keeps the annoying killer horseflies and bugs away for most of the ride.
I would say I don't wear a base layer because a cyclist is generally moving and has the advantage of convection to help remove heat from the skin. If you were standing or walking then the additional layer might keep the water next to your skin which helps cool you much like the body's own natural process. However not having that layer against your skin with air flow over it allows the sweat to be taken away that much faster thereby cooling you more efficiently.
(I think?)
Cooling
 Originally Posted by nOOky
I would say I don't wear a base layer because a cyclist is generally moving and has the advantage of convection to help remove heat from the skin. If you were standing or walking then the additional layer might keep the water next to your skin which helps cool you much like the body's own natural process. However not having that layer against your skin with air flow over it allows the sweat to be taken away that much faster thereby cooling you more efficiently. (I think?)
Actually, it is evaporation that provides nearly all of the cooling for a bicyclist at speed. Convection losses would be very small, especially as ambient temperature approaches body temperature. Evaporation of sweat is a far more important source of cooling. I'm agnostic on base layers and I don't use them, but convection cooling is not the issue.
You are right I used the wrong term!
You only need one layer. If a "base layer" is doing something your jersey isn't, then fix your jerseys.
Riding up hills in the summer around here is an exercise in pouring water on onesself so riding speed isn't limited by overheating. Adding a base layer is just ludicrous.
Your skin is the most effective cooling "base layer" possible. Everything else is just sleight of hand and inaccurate advertising. No amount of "wicking" can evaporate sweat more effectively than exposed skin to provide a cooling action.
It is possible to wick away moisture faster, but this gets rid of the cooling effect from evaporation, defeating the purpose of the wicking action in the first place. This is in fact the idea behind base layers for COLD conditions.
_______________
"I haven't @#&$ed like that since I was an altar boy."
I sort of disagree..
When riding my trainer all winter long I wear the same skin tight full sleeve base layer but no additional layers. I've found that when wearing the skin tight shirt in front of a fan I cool off BETTER than I do without a shirt on. If I ride shirtless I still feel hot. With that layer on it gets soaked after a few minutes and the fan chills that so I feel cooler. I've also watched my heart rate increase a few beats when wearing no shirt at the same effort..
So I don't believe wicking base layers are hype at all..
Partially true
Wicking fabric takes the sweat to the surface of the fabric for evaporation and when it evaporates, you feel the cooling effect. Does a fabric provide a slight insulating effect? Yes, but you certainly can feel the cooling and if the sweat is dispersed across the fabric you will get more cooling effect than if you let the sweat drip off your bare skin (no cooling effect). A base layer does result in a slight additional insulation effect, so it is hard to see how it would be cooler than a quality jersey made of a wicking fabric.
I think the main potential benefit of a base layer is to reduce road rash because the jersey and the base layer slide agains each other rather than the jersey sliding against your bare skin.
Baltic Scum
From personal experience, i.e. many years of riding in 90+degrees from late May to at least mid-September, I agree to the above. I wear sleeveless DeFeet undershirts for every ride and have never felt them to be hotter than riding with a jersey only.
One aspect which has not received much attention is the fact that a summer-weight underlayer used in very high humidity (eastern NC) prevents the discomfort of having your completely soaked jersey slap against your skin. The effect is magnified after leaving an air conditioned gas station after a rest stop. Lastly, the crash protection, probably aided by wearing bibs, has been helpful in the odd sprint pile-up.
Was juckt es die stolze Eiche, wenn sich ein Schwein an ihr kratzt?
eeeh. no way I would use a base layer on hot days. It gets upto 43C where I live.
By carsnoceans in forum General Cycling Discussion
Last Post: 04-04-2011, 04:22 PM
By username in forum Hot Deals
Last Post: 03-14-2011, 10:48 AM
By jobster in forum General Cycling Discussion
Last Post: 05-22-2009, 07:31 AM
By tarwheel2 in forum General Cycling Discussion
Last Post: 11-13-2007, 08:53 AM
By The Moontrane in forum Hot Deals
Last Post: 06-25-2006, 08:26 PM
- You may not post replies
- You may not edit your posts
Forum Rules
