Results 1 to 20 of 20
    Apr 2008
    How many calories burned on 25 mi ride?
    Any idea how many calories would typically be burned on a 25 mi ride assuming flat terrain and ideal conditions?
    Reputation: logansites's Avatar
    Jan 2007
    google a calorie calculator. the couple I have seen need you to enter time, activity level, and weight.
    Gee willikers, it must be obvious day at Camp Stupid. - Shake
    Reputation: abiciriderback's Avatar
    Jun 2005
    You have to narrow down all the variables. terrain ( Flat, rolling, Hills) wind. etc etc if you want to get a half way correct estimate.
    Ray Still
    Reputation: BluRooster's Avatar
    Sep 2006
    Depends on your speed and effort. It could be anything from a leisurely 5- 600 calories to a fast 1200 cal.
    Quote Originally Posted by Bruce Rodgers
    Apr 2008
    Thank's for the replies. Here are two calorie counters I found on google. I've now learned that 1 hour of biking is equivalent to 10 hours of sex. Just in case to needed to know.
    http://www.caloriesperhour.com/index_burn.html
    http://www.kreuzotter.de/english/espeed.htm
    Jun 2007
    so basically a meal or two.
    Feb 2002
    Round numbers
    Some rough numbers (flat road, no wind):
    10 mph, 15 calories per mile
    15 mph, 20 calories per mile
    20 mph, 30 calories per mile
    25 mph, 45 calories per mile
    30 mph, 60 calories per mile
    Now with a 5900SL P1
    Reputation: 99trek5200's Avatar
    Jan 2007
    Quote Originally Posted by Kerry Irons
    Rider weight (and likely age) plays into it as well. Here is a link that adds weight into the equation. This chart is more in line with what my Garmin and Polar HRM's calculate. (Roughly 55-60 calories per mile at 18-20 mph . ( I tip the scales at 195-200 lbs.)
    http://www.nutristrategy.com/activitylist.htm
    AH1
    AH1 is offline
    Reputation: AH1's Avatar
    May 2008
    I think that the only way to calculate accurately is with a powermeter. Comparing calories burned with my Garmin 705 calculated, 25 miles, vs Powertap actual, there can be a 600-800 calorie difference (Garmin always reads higher). All dependent on hills and wind conditions.
    Insert amusing tag line here...
    Feb 2002
    Way-off numbers
    Quote Originally Posted by 99trek5200
    The numbers I quoted assume a 200 lb rider + bike combination, and use the very commonly quoted 24% metabolic efficiency for a fit person. 20 mph requires about 175 watts, so to get 55 calories per mile would mean a metabolic efficiency of 14%. This would mean a very out of shape couch potato riding a beach cruiser with underinflated tires.
    The numbers you quote are rediculously high, and that topic has been discusse here repeatedly. 55 calories per mile at 20 mph would mean burning 1100 calories per hour, so a 100 mile ride would consume 5500 calories. I regularly do that kind of distance and only need to eat about 1600 calories, which, after including about 1000 calories from fat metabolis, would suggest that I am running a 3000 calorie deficit during that 100 miles. Not possible.
    No HRM can calculate caloric expediture, and those that attempt to do so, routinely report numbers that are way high. Same with most exercise equipment found in fitness centers. Presumably this is to make the customer feel better about how many calories they're buring, but it has nothing to do with reality.
    Reputation: walter2007's Avatar
    Nov 2007
    "15 mph, 20 calories per mile"
    So 20 miles or 1 hour of riding would only burn 400 calories. Seems low too me especially at 200 lbs.
    ok I've had a cocktail, new math
    So 15 miles or 1 hour of riding would only burn 300 calories. Seems VERY low to me.
    Knives, Guns, and Booze
    Reputation: Leopold Porkstacker's Avatar
    If you’re riding from San Jose, CA northbound to Palo Alto, CA then for sure you are burning a lot more calories than you might expect to, since there’s always a headwind going in that direction.
    What up, dog?
    Reputation: axebiker's Avatar
    Aug 2003
    Quote Originally Posted by walter2007
    I was thinking 10 miles at 20mph = 300 calories??? No way.
    Frog Whisperer
    May 2003
    back to the hour of sex...10 hours of riding...OH...it was the OTHER WAY AROUND?.......
    Either way..it ALL depends on who's doing the WORK
    For riding though sport tracks does a reasonable job of calculating from GPS data. Personal data and terrain data are both considered as well as speed and distance. If I cared about heart rate and rode with a monitor it would probably be more accurate
    Of course I'm sure...that doesn't mean I'm right.....
    "There's no sense being stupid unless you show it."
    "that was like trying to teach a goldfish how to play basketball over the phone."
    Feb 2002
    How hard is it?
    "So 15 miles or 1 hour of riding would only burn 300 calories. Seems VERY low to me.
    15 mph on flat roads with no wind is a VERY low effort ride. About the same effort as walking at 3 mph, which is, coincidentally, 300 calories per hour.
    Feb 2002
    Which way?
    Quote Originally Posted by axebiker
    So why is 600 calories per hour at 20 mph "no way"? Do you have some solid numbers to disagree with this rough estimate? You'll find it referenced in Bicycling Science, 3rd Edition, David Gordon Wilson, MIT Press.
    What up, dog?
    Aug 2003
    If I rode 20, but I was talking 10 - even though I usually ride 25-40 most days.
    "20 mph, 30 calories per mile" according to you. So if I rode average 20 mph (which I consider a pretty fast average speed) for 10 miles, ACCORDING TO YOUR QUOTE equals about 300 calories. If I got out (using a Polar HRM) and ride and average of 17-18 mph over 25 miles, I usually come in more along the lines of 1200-1500 calories. According to your figure, I'd burn more like 750. I think that data is flawed, and I don't care who your source is. If I was only burning 600 calories over a 20 mile distance at 20 mph, I'm going to quit cycling as a fitness tool.
    And who rides absolutely flat, no wind conditions anyway? Come on...
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    "20 mph, 30 calories per mile" according to you. So if I rode average 20 mph (that's moving for 10 miles, that equals ACCORDING TO YOUR QUOTE about 300 calories. If I got out (using a Polar HRM) and ride and average of 17-18 mph over 25 miles, I usually come in more along the lines of 1200-1500 calories. According to your figure, I'd burn more like 750. I think that data is flawed, and I don't care who your source is.
    I'd trust Bicycling Science BTW. It is a *very* analytical and thorough book.
    Making a computation like you're wanting is a *very* tricky thing. Everyone's body is different, and reacts differently to different kinds of stress--flat conditions and no wind are ways of coming to a reasonable conclusion by eliminating as many variables as possibe. If vou ever study the calculus equations for air resistance and speed--they are a nightmare, even with simple systems without worrying abot pedaling technique or frame stiffness to worry about etc etc.
    The other factor to remember is that a Calorie, the standard of unit used to measure food energy in the US, is in fact a "large calorie"....it is a standard convention that 1 Cal=1000 calories. 1 Calorie is a great deal of energy. 1 Cal is enough energy to raise 1 Kg of water 1C. 300 Cal is enough energy to boil 3kg of water starting from just above freezing. I don't have my copy of Bicycling Science handy--but I presume the figure cited by Monsieur de Irons is large calories not small calories.
    NeoRetroGrouch
    Reputation: TurboTurtle's Avatar
    You're basing this on the numbers from an HRM? I think it was Zinn who refered to them in his review as random number generators. They sinply do not have enough data to calculate Calories. With a working/calibrated power meter, you can get to within plus/minus 10-20%. Anything else (HRM, GPS, etc.) is just marketing. - TF
    "Don't those guys know they're old?!!"
    Me, off the back, at my first 50+ road race.
