Results 1 to 23 of 23
    Jun 2018
    Unhappy How to save the Bike when frame integrated seat post clamp fails - BMC SL01 Road ?
    Hi,
    Advice sought on how best to save my BMC SL01 Road Racer. It is a favourite cycle and recently the seat post felt odd at the end of a ride.
    Quick check revealed that the frame - integrated seat post clamp had given way.
    What is the best way to recover and restore the bike to full capability?
    Any responses resulting in recovering this bicycle hugely appreciated.
    A few pictures to illustrate:
    How to save the Bike when frame integrated seat post clamp fails - BMC SL01 Road ?-img_4392.jpgHow to save the Bike when frame integrated seat post clamp fails - BMC SL01 Road ?-img_4394.jpg
    Nov 2009
    Send it to a carbon bike frame repair shop or buy another frame.
    Oh wait, is that Aluminum frame, if so, trash it.
    Dec 2006
    You're out of luck. As factory feel observed, the frame is aluminum. That seat lug area is not replaceable or repairable.
    Have you tried getting the frame warrantied? If for whatever reason it's not covered under the warranty, then it's time to get a new frame.
    Nov 2014
    If you do try to get it warranteed, I have to wonder what they will say about that top bolt. Looks to have been over torqued or at least tightened with the wrong size hex.
    Sep 2011
    Quote Originally Posted by GKSki View Post
    how would you go about proving that a bolt is over torqued?
    Darling of The Lounge
    Reputation: Retro Grouch's Avatar
    Apr 2002
    I would be interested to know the rider's weight and how far out the seat post protrudes out of seat tube.
    Between the possible over-torquing of the seat clamp hex bolts, and how little of the seat post might be inserted into the frame, that area may have been subjected to a lot of flex.
    Jul 2012
    You could always ask Frank The Welder is it's fixable (probably not, or probably $$$$ if it is). I didn't really think about repairs to aluminium frames till I saw him resurrect a few old Yeti ARC frames...but replacing head/seat tubes is maybe a bit different to the seat cluster on that frame, there's a whole lot going on there.
    All the gear and no idea
    Dec 2008
    Quote Originally Posted by mik_git View Post
    That's most likely not fixable w/o some serious re-working of the frame due to BMC's stupid overly designed lug that integrates the seatstays/seat/top tubes. I've seen these frames fail there, especially on their mtb frames. Talk about overly complex for form's sake.
    Dec 2006
    Quote Originally Posted by Retro Grouch View Post
    Good observation.
    Jun 2018
    BMC SL01 Road Racer - Integrated Seat Post Clamp Split, how to remedy?
    [QUOTE=MattCole;5239145]Hi,
ID:	322875Click image for larger version.
    It appears as a forum that there is no answer, Many have noted the BMC design as over complex. Several have commented if the frame is aluminium that it should be trashed.
    Rider weight is c80kg and the seatpost extends a long way into the seat tube.
    Best non-forum response has been to fabricate a stainless steel ring, given the complex shape this seems a challenge.
    Would be very grateful if there any practical suggestions that do not involve loosing the frame?
    Jun 2018
    BMC SL01 Showing Seatpost Length
    How to save the Bike when frame integrated seat post clamp fails - BMC SL01 Road ?-img_4393.jpg
    Approx 80 kg
    Dec 2008
    Quote Originally Posted by MattCole View Post
    I'm really curious why you think there haven't been any real answers, or maybe you're just not happy with the answers you've gotten? That crack cannot be fixed by welding and welding will create even more problems. The frame cannot be easily heat treated again with those carbon stays glued into that mess of a seat collar lug. There's just way too many difficult things connected to that seat collar lug. Did you try contacting BMC for repairs, officially? The obvious thing to do is to replace that lug. But as I wrote, doing that is far from easy.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Nothing lasts forever. Part it out, mount it on a wall as a memento...and buy a new bike or frame.
    Quote Originally Posted by thesmokingman View Post
    ^That^
    Nov 2009
    Why was a frame like that ever built is my question.
    Jan 2005
    Quote Originally Posted by factory feel View Post
    BMC sold a ton of them because of it...I will admit it is a cool looking joint design, and very memorable from a branding standpoint. Seriously, you see that seat-cluster-lug and you *know* who made those bikes even if the frame was media-blasted and anonymized.
    Over-engineered and problematic long-term...but cool looking.
    'brifter' is a lame word.
    If it's not covered by warranty it's finished. There is no way to fix that, trust me.
    I work for some bike racers
    and a bunch of skateboards
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    Ditto what cx said.
    Also, in my opinion, that's a sketchy design for attaching the seatpost to the top tube and the seat stay. I would have anticipated failure in that area at some point in the life of that frame.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Incorrect. There's been numerous definitive answers. That frame is 1000% trashed. You can't fix it.
    It's a 10+ year old frame and BMC has a 3yr warranty. You've gotten your life out of it.
    No. None. Nada. Nein.
    Any attempt to try and fix that would be a hack job at worst, and at best would cost significantly more than buying a brand new frame of better quality.
    You could cut it off. But I don't know if you'd have enough seatpost tube left showing to fashion a clamp or not. And diameter could be a problem.
    I'd ask a frame builder that deals with alloy.
    Sep 2007
    If I had to ride the bike until I got a new one, like to get to work or something, I might jury rig 2 or 3 hose clamps to hold the seat in place.
    One on the seat post to keep it from sliding down beyond where you want it, and at least one on the broken collar on the frame.
    Oct 2013
    Hose clamps are not going to hold that....
    You can fix it using auto muffler clamp around the area where the crack is, use one or two if possible.
    There you go, you can fix it!
    BANNED
    Jun 2018
    Thank you all for advising. Some very wise words, it appears that the BMC original design presents too many obstacles. Such a great pity to loose such a lovely bike - it has worked perfectly until this fracture.
    My trusty steel first race bike is still going strong - perhaps there is a lesson in there somewhere
    Sep 2011
    just wait until all the carbon bikes with their proprietary aero shaped seatposts crack, then good luck trying to find a replacement seatposts! By then, these owners will also harbor the same sentiment as you: "pity that a whole bike is trash due to unavailability of a seatpost!"
  1. BMC seat post clamp
    By Bearcat in forum General Cycling Discussion
    Last Post: 09-20-2016, 03:13 AM
  2. 2009 SL01 vs 2007 SL01
    By Alaska Mike in forum BMC
    Last Post: 05-17-2010, 10:12 AM
  3. BMC SL01 Road Racer Frame- whats it worth??
    By punkpeddler in forum Bikes, Frames and Forks
    Last Post: 02-13-2009, 08:22 PM
  4. seat clamp damaging seat post
    By toyota in forum Cannondale
    Last Post: 12-12-2006, 10:51 PM
