Results 1 to 17 of 17
    Aug 2003
    Lightning and Carbon Fibre
    Can I ride my CF bike without worrying about lightning durin a storm?
    Just an thought I had while I was watching a storm go past my house. I hate not riding because of yuky weather.
    rock n rolling resistance
    Reputation: 6was9's Avatar
    It's not the material...
    Quote Originally Posted by Caadrider
    of your bike that you should worry about but rather whether you are the tallest thing in the surrounding area. Unlike handling AC charge, non-conductivity of your bike material or shoes won't save you from a lightening hit. Lightening is powerful enough that the current will simply jump from you to the ground even if you are on a non-conductive bike.
    Lightening is basically arcing between two opposing field of electrical charge: atmoshpere and ground. You don't want to be near any tall conductive structure such as a big tree or be that tallest structure yourself. If you will, in the eyes of lightening, you are just a part of a large mass it is attracted to. You just don't want to draw any attention by sticking out higher than your surrounding which is hard to do on a bike unless you are in a city near many tall buildings. Also you can't always predict exactly how a lightening/arcing will behave. My advice: avoid riding in thunder storms.
    New Member
    Reputation: divve's Avatar
    May 2002
    What if you wear this? Will the lightening still be able to find you?
    Attached Thumbnails Attached Thumbnails Lightning and Carbon Fibre-assos.jpg
    Reputation: russw19's Avatar
    Nov 2002
    Quote Originally Posted by divve
    That's a Ninja Suit if I have ever seen one! Next will be Campy throwing stars and Shimano swords!
    Russ
    Arrogant roadie.....
    Reputation: Dave_Stohler's Avatar
    No, but......
    Neither will the traffic!
    Is that the "Johnny Invisible" costume from that old SNL skit??
    We are the 801
    We are the central shaft
    hi, I'm Larry
    Reputation: bimini's Avatar
    Jul 2003
    Carbon is an excellent conductor of electricity.
    Probably better than steel.
    Nov 2003
    Good decision
    not to ride not because the lightning is finding you, but simply because of nasty weather condition. Basically the charge is looking for the shortest path possible to pass through, so as 6was9 had pointed out, if you are not the highest object around, chances are the lightning wont find you. Also the currect in a lightning bolt is so enormous that, materials of your bike does not matter : whether you ride a styrofoam or platinum bike, you are still toast.
    As a matter of fact, You have better risk of getting a lightning strike driving under a thunderstorm than riding. The car will save you becos it is a faraday cage; it conducts current around you, so you wont get jolted.
    Oct 2003
    Cool I love these little weather discussions you guys have. They're cute really.
    Okay. The last thing you need to worry about is the conductive properties of carbon fiber. What we should be discussing here is tensile strength, and what happens when thin carbon fiber tubing explodes; because that's what will happen if lightning strikes you while you are riding your carbon fiber frame. The gases inside the bike will superheat and the frame will explode. Shrapnel injuries are a definate risk here. I am wondering which would kill you first, the current or the explosion of metal. We need the input of some metalurgists here. I know plenty about lightning and nothing about CF. I think we also need a field test, and for that I nominate Akirasho. I bet he's got some old CF laying around not being ridden.
    Banned forever.....or not
    Aug 2002
    Wink Only if you are wearing a faraday cage.
    Or you could go the cheap way and wrap your helmet with Aluminum foil. This has the added benefit of protecting you from alien mind control.
    Dogbert.
    I>U
    Aug 2002
    Does this come in the Anti-Shark Mesh too?
    Probably a bit sqeaky, but at the water drains out, not that it matters after you've been struck.
    Perhaps aliensporebomb...
    Quote Originally Posted by MR_GRUMPY
    could enlighten us about a best way to shield ourselves from Alien Mind Control while riding in a thunderstorm and its effect on carbon fiber. Electrical arcing in atmoshpere is one thing but I definitely don't have any working knowledge regarding AMC...
    I don't know about the aluminum foil theory though. For one thing you'll have to replace the foil quite often since it'll develope stress facture sooner than other material. My 2 cents....
    Nov 2002
    Got caught out in a Thunderstorm a few weeks ago....I noticed that most around me (there were 4 or us together at this point) were on CF, and I assumed that me being on Ti was a disadvantage...then I noticed that I was a bit shorter and could really be lower if I rode in the drops, so I opted to go the "don't be the tallest thing around" and rode the drops for the last 10 miles or so.
    Luckily no one was hit, but I felt a lot better keeping low...and not mentioning this fact to my partners!
    UHA! uhg?
    Reputation: lsnfa's Avatar
    Oct 2003
    That's low...
    Quote Originally Posted by morkm
    it's a good thing that no one got hit... Imagine the guilt you'd feel....
    Aug 2003
    What a cool way to go though...
    "He was killed by exploding Carbon Fibre!!"
    I like it.......
    hi, I'm Larry
    Jul 2003
    Tend to agree
    I use to work for a public utility where the linemen had to work out in the lighting around tall grounded poles.
    At least once every couple of years someone died (or wish they would of died) due to lightning striking them or near them. Feet almost always explode, legs and arms do also. Then the lightning tends to tunnel through the center of the person burning everything in it's path. Normally it is a close hit not a dirrect hit. In these cases the voltage goes into one foot through the legs and out the other foot. What happens to the soft tissue in between? Yeck!
    After the training films, I am certain you would not catch me out on a carbon fiber bike (or any bike) in a thunder storm. Me, I run for shelter.
    Quote Originally Posted by Free2Pedal
    A few years back, one of the testers at one of the MTB rags had a related experience.
    He was using a CF-framed bike, and a bit of the clearcoat had chipped off the top frame tube during rigorous testing. He was in a mountainous area, and as happens, a quick thunderstorm blew up. He was standing, straddling the bike, and could feel heavy-duty static electricity building. He was just about to find a place to hide when a healthy spark jumped from the frame via the chip in the clearcoat to the closest available location.....Ouch.
    Not really a lightning strike, but it does give one pause.
    Strained coccyx etc etc
    Reputation: haiku d'etat's Avatar
    Apr 2001
    LOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!! nm
    no massage
    One morning I shot an elephant in my pajamas. How he got into my pajamas I'll never know.
