Results 1 to 8 of 8
    your text here
    Reputation: weltyed's Avatar
    Look Keo Sprint Elle
    So, does anybody know the difference between the standard Look Keo Sprints and les Elles? The blue color matches the new build, but they are called "women's specific" pedals. How are they women specific (aside from the name)? Would my hairy 165/170 kill these pedals?
    I don't normally "do people." - Dr. Roebuck
    I think the only difference is the color...REI has them in black for $99.00....the graphics are powder blue..
    Probikekit has the black Elle's for $62.93
    Descender
    Oct 2005
    If they use the same Keo cleat for them - you are good
    your text here
    PBK doesnt have the blue i am looking for. there are some shimano gerolstiener ones witha blue that is cool too.
    now i have to figure out if:
    a) i wanna try something other than crank bros
    b) i want look or shimano
    c) i care that my pedals say "elle"
    i have seen some pink CB quattros...
    Deliciously Ironic
    Reputation: Rollo Tommassi's Avatar
    Spring tension
    There is less spring tension, need less force to disengage the cleat. The Elle pedal is equal to the Classic Keo tension range of 8-12nm. Both pedals are designed for riders new to clipless, non-competitive or for those who have an issue with side-loading the ankle.
    The Sprint Keo is 9-15nm, the Carbon Keo is 10-18nm
    Quote Originally Posted by weltyed
    mohair_chair: And everyone knows that a menstruating woman attracts bears
    buy my old bike stuff: https://sites.google.com/site/carbonscyclingcloset/
    my playlist on Blip.fm: http://blip.fm/rollotommassi
    Carbon Fiber = Explode!
    Reputation: CleavesF's Avatar
    Dec 2007
    You can always mod the bodies to higher end keo springs and axles if you must.
    '09 Voodoo Wazoo
    '08 Pedal Force RS2
    '06 Raleigh Cadent 5.0
    '01 Trek 4300 MTB
    '93 Norco Nitro MTB Touring
    '88 Schwinn Prelude Fixie
    1 hour of running = 1 hour of wasted time when you could have been riding. - Alaska Mike
    your text here
    thanks, rollo! i knew i could count on you.
    i do side-load a bit, so maybe these chick pedals would work...
    Quote Originally Posted by Rollo Tommassi
    Spring tension should be fine...8-12 is what some of the old Delta pedals had, I'm still using them. Only time I pull out is when my cleats get worn really bad.....
    Nashbar has the blue Elle's for $79.99
Contest
Tour De France
