http://www.magellangps.com/products/...25&prodID=1910
How is this compare to the Garmin Edge 705?
Product Number: 980942-01
# 2.7" color touch screen control - The latest touch-screen technology is built in to the large brilliant color display. Control navigation and advanced features with a touch
# Amazing ease-of-use - Reinventing handheld GPS™, simple menus, instant access buttons, intuitive keypad and crystal clear graphics let you navigate without the need for a PH.D.
# 2 MP camera - Take clear beautiful pictures of your adventure as you navigate to attach them to waypoints so you can easily find your way back to the same spot or just to share with family and friends
# Voice recorder - Microphone and speaker enable you to record audio notes for waypoints to share with friends and family or easily find your way back next time
# Flashlight - Light your way with a powerful LED flashlight. Low power consumption helps maximize battery life.
# 3-axis electronic compass - Get an accurate compass reading even while standing still and no matter how you hold the unit
# Barometer - Sensitive barometric pressure readings offer advance notice of changing weather and assists in providing accurate elevation
# SD-card expansion - Use your own SD memory cards to upload unlimited detailed maps and store routes, waypoints, geocaches and more
# Built-in maps - Basemap of the 48 contiguous United States, Alaska, and Canada (major highways, city centers, bodies of water and more) plus worldwide geographic boundaries
# Add detailed maps - Upload optional marine cartography, topographic maps, and more, including the highly-detailed and feature-packed National Geographic TOPO! State series and Weekend Explorer 3D maps to your OWN SD cards
# 3-meter accuracy - SiRFstarIII™ chipset and integrated multidirectional antennae offer superior GPS accuracy using the Wide Area Augmentation System (WAAS)
# Digital music player - Upload your digital music to your OWN available memory or own SD card and enjoy a customized soundtrack as you explore. Plug in any standard headphones for clear private listening
# External antenna connector - Simply plug in an external antenna in your boat or off-road vehicle for enhanced GPS signal reception
# Audio jack - Plug in any standard 1/8" headphones to enjoy clear private listening of your digital music, voice notes and other recordings
PHYSICAL
Case Rubber armored impact-resistant plastic, water-resistant seal, IPX-7
Pre-Loaded Maps Built-in basemap of Contiguous U.S., Alaska, Canada and Worldwide Geographic Boundaries
Size 5.75" x 2.5" x 1.13"
Weight 8.0 oz (227 g) - w/ battery
Screen Size 2.7" (6.86 cm) diagonal, QVGA (240X320) resolution and touch screen (LED backlit)
SD RAM SD Card
Memory available for map storage Secure Digital (SD) Card
Antenna Type Built-in multidirectional patch (or optional external antenna)
Keypad Nine direct-access keys
Operating Range 14 to 140°F (-10 to 60°C)
PERFORMANCE
GPS SiRF Star III™ 20 channels, WAAS/EGNOS
Acquisition Time Hot: 20 seconds, Cold: 60 seconds, Initial: 2 minutes
Update Rate Once per second
GPS Accuracy 3 to 5 meters (10 - 16 feet) - WAAS/EGNOS, < 7 meters (15 feet) - GPS only
Languages English, French, German, Dutch, Italian, Spanish, Danish, Norwegian, Swedish, Finnish, Portuguese.
Coordinate Systems Latitude/Longitude, UTM, OSGB, Irish, Swiss, Swedish, Finnish, German, French, USNG, MGRS, Indian, Dutch.
POWER
Source Two AA Batteries (included)
Battery Life 10 hours
