Results 1 to 17 of 17
    Oct 2018
    my tire is too big
    I bought new Gigantex carbon rims for my road bike. The tires are about 2 months old and the front one keeps slipping out of the rim. Is there someone with a lot of experience with tires that knows which tires have a tight fit? There is a thread that explains that Michelin tires are tight fitting but that thread was 6 years old. They might be different now.
    Reputation: Srode's Avatar
    Aug 2012
    what tires are you using that are popping out of the rim?
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Oct 2018
    Continental Grand Prix 4000 s2 23 mm
    'brifter' is a lame word.
    This forum has different sections that are set up by the owners for different types of subject matter. There is a 'wheels/tires' section for questions like yours. In the future please use the correct section.
    As for your question, it's not a problem w/ the tire or them, or it shouldn't be. More likely a problem w/ how the tire is being installed.
    I work for some bike racers
    and a bunch of skateboards
    Quote Originally Posted by Louis Stamos View Post
    I'm assuming identical rims and the same tire in the back and the back combo is okay. Don't be afraid to actually apply some thought here.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    What does that mean, slipping out of the rim? While you're riding? While you're installing?
    Have you tried other tires?
    Have you tried swapping the front and rear tire?
    Reputation: Akirasho's Avatar
    Oct 2018
    Installation goes good, then about 1 hour into the ride the front tire slips out a little, I feel a bumpy ride. The inner tube does not blow out. I lower the pressure, push the tire back in, and pump up to 80 psi, and finish the ride.
    tlg
    tlg is offline
    May 2011
    What kind of rim strip is on the front wheel?
    Reputation: Lombard's Avatar
    May 2014
    My first thought would be a defective bead on your tire.
    What is the INTERNAL width of your rims? Which rims are these?
    Oct 2013
    I would change that tire out immediately after finishing the ride, are you crazy?
    BANNED
    Sep 2011
    I get the feeling that this particular Gigantex rim is defective, either its diameter is a little small or its bead hook is weird. It would be helpful if you could compare the diameter of the front vs the rear Gigantex rim. Take a piece of sewing thread/string and stretch it across the diameter of both rims and see if their diameter are the same.
    Nov 2009
    The obvious thing to do is switch the front and rear tires. Then you'll know if it's a problem with the tire or rim.
    Your next decision is completely uninformed until you try this, and any other input is useless.
    Sent from my Moto G (5) Plus using Tapatalk
    Out riding.
    Reputation: 1500SLR's Avatar
    Sep 2018
    Either your rim is defective or your tyre is defective. One or the two, or perhaps even both. You might have noticed that the rims aren't the same width, or your tyre is defective. It should be one of the two and you should be able to work it out. If the tyre is defective take it back and get a new one. If the rim is defective either get it replaced or buy a new one.
    Nov 2009
    Quote Originally Posted by 1500SLR View Post
    You forgot to log in as Lombard.
    Such lame advice that is utterly useless.
    Oh my, a troll who doesn't know the difference between your and you're. What will they think of next?
    May 2014
    Quote Originally Posted by factory feel View Post
    And do you have any good advice to add? As usual, no. You're just trolling with insults and cornball jokes that nobody thinks are funny.
  1. big .... Big .... BIG GOP News of the Day
    By troutmd in forum Politics Only
    Last Post: 05-19-2015, 08:57 AM
  2. CLOUT: Big Beer, Big Banks, Big Government and Aluminum
    By TerminatorX91 in forum Politics Only
    Last Post: 07-23-2013, 08:15 AM
  3. Replies: 25
    Last Post: 07-03-2009, 10:33 AM
  4. big big BIG snow in memphis!
    By haiku d'etat in forum The Lounge
    Last Post: 02-14-2006, 01:02 PM
  5. Too small? or Too big?
    By mtbroadie in forum General Cycling Discussion
    Last Post: 03-19-2005, 06:29 PM
