Results 1 to 15 of 15
    Aug 2012
    Numb groin on trainer
    OK so I finally bit the bullet and got a trainer and a Zwift account to try to stay fit through the New England winter. However I have noticed that about a half hour into my rides, my groin (I'm a man) has gone scarily numb. I typically will ride for another 20-30 mins and then have to quit lest anything be permanently damaged!
    I checked the saddle angle before my last ride and it was right where it usually is -- just a tiny bit below level.
    I never have this problem riding outside for rides of any length.
    Anyone have any idea why this is happening? Perhaps just being in the exact same position for the entire ride without any movement on the saddle as opposed to the road where there is some shifting depending on the terrain.
    Anyone have a suggestion for how to fix it?
    Many thanks!
    Quote Originally Posted by El Bishop View Post
    You got it.
    Naturally standing and moving around more helps. A saddle with a cut out would likely help with that too. If you want to try messing with saddle height it's much more likely that going down would help then going up.
    I haven't been able to totally solve it myself. 2 hours is my max on a trainer before the pain gets pretty bad despite 6 or more being no problem on the road.
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    Although you're not outside you still need to stand up every so often, if you're doing intervals then during the recovery periods, and if just plodding along make a note to stand up for a few seconds once every 5 or 10 minutes.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    Reputation: Srode's Avatar
    Aug 2012
    Yep, stand up and move around more and you will be much more comfortable. Longer intervals make that more obvious, like multiples of 20 or 25 minutes.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Reputation: El Scorcho's Avatar
    Dec 2005
    It's a sign from God herself, that trainers are stupid and you should have used that money to purchase better cold weather gear.
    Dec 2006
    All the above advice is good.
    Check the angle of your saddle WHILE IT'S ON THE TRAINER. If the bike isn't level, your saddle isn't in its customary position. It wouldn't hurt to change your saddle angle if you'll be on the trainer for many winter sessions. This is especially true if you ride rollers because most rollers tilt the front end of the bike up slightly. Riding the hoods or drops while on these rollers can cause discomfort.
    Dec 2005
    Quote Originally Posted by Peter P. View Post
    I appreciate that.
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    Not to be a total shill, but if your bike in the trainer is causing numbness and damage, you're probably also causing damage on the road, too. It does add up.
    Consider adjusting your saddle nose down, or get a more modern saddle that takes your weight off of your groin and puts it on the pelvic bones where it belongs.
    Apr 2014
    Most likely your floor is not level.
    Aug 2012
    Bingo! I rode out of the saddle for two minutes for every ten minutes in the saddle and no more numbness. Many thanks!
    Reputation: Veloptuous's Avatar
    Oct 2017
    This is ne of the reasons why I could never really get into using a trainer...so I ended up selling mine, but then again I was not in New England
    Aug 2004
    Oct 2013
    Yep, works for me too. I usually shift gears 2 notches harder before standing.
    Aug 2015
    Yes standing now and then is a must.
    Also, they make front tire blocks with different front wheel height settings. I have the Kurt Kinetic one and it does make a difference in groin sensory depending how high your front wheel is off the ground. Sort of the same thing as adjusting your actual seat angle.
    Try different front wheel heights.
    Slowski
    Reputation: eboos's Avatar
    Mar 2011
    Many thanks!
    Wow, I just experienced the exact same circumstances and results. As was suggested already, try making sure the saddle angle is correct while on the trainer. Because your rear wheel is elevated, even if you have a block for the front wheel, it may not be correctly level. Build up the height of the front with books or magazines if needed to get it level.
    I also got a fitting on Saturday. We moved my saddle slightly forward and angled it down a tad. I was still feeling numb in the drops so I tried a new saddle. So far, after two days of intervals, everything seems fine.
  1. Groin pain (due to saddle mistakes)
    By serottacolorado in forum General Cycling Discussion
    Last Post: 09-26-2007, 04:21 AM
  2. lump in groin area
    By gibsonra in forum General Cycling Discussion
    Last Post: 04-08-2007, 06:23 PM
  3. Inner thigh/groin area pain
    By matty in forum Beginner's Corner
    Last Post: 10-10-2005, 08:56 PM
  4. Pulled groin last night ... huge ride tomorrow ...
    By lange79 in forum General Cycling Discussion
    Last Post: 07-30-2004, 12:43 PM
